Author Topic: All Balls Tapered Bearing Kits: Where is the kit with both bearings tapered.  (Read 1450 times)
Offline edwardmorris
  • Youngish
I've been having trouble finding All Balls tapered bearing kits for the 750 where both the top and bottom bearings are tapered, as shown in Hondaman's book. Been looking on ebay and the only kit from All Balls that fits a K2 is
This one
and the ones that have both top and bottom ones tapered aren't from All Balls like
This one
So the question is, has anyone found a kit from All Balls with both bearings tapered? If so, where can I grab one of those from?
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Yuhaaahhhh....The inner face of the races (bearings too) are tapered. The outer face of the races (top, bottom, sides) are flat. Find your favorite tapered wheel bearing (automotive, trailer, truck) and place the tapered bearing into it's outer race and all of the outer faces are flat, yet the bearings are still tapered.  ???
How's that work?  ???
(Hint: The outer faces must be flat to fit the steering neck and steering stem...)  :o
 ;) ;D
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Jay Ace
^ what he said.
I ordered these today for my '72
http://www.amazon.com/gp/product/B000GZQ3XW/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
They don't look tapered when assembled, but they are.
^ what he said.
yuup...thats the one.
Offline Bailgang
  • Scott
  • Indiana
Uhm uh the reason the 1 bearing looks tapered and the other not in the all balls ebay ad is because the one bearing is setting in it's outer race covered by the grease seal that comes with the kit. The bearing that you can actually see is tapered would look the same once you set it in it's outer race. :)
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline FunJimmy
  • Who you calling
  • Vancouver
Read the description under the pretty picture!
Kits come complete with both upper and lower taper bearing cups, cones, and most kits include top and bottom seals
ALL BALLS tapered roller bearings provide decreased maintenance along with less wear, smoother operation and longer life
Designed as a drop-in replacement to upgrade ball-type bearings to taper bearings, or a high quality replacement if your machine comes with tapered bearings stock
Condition: BRAND NEW KIT!
Quantity: (1) One complete Bearing & Seal Kit
Look what you got yourself into now  :)
  • Youngish
LOL
DUUUUH for me on this one.
I can only hope this doesn't go down the drain like the part removal thread ;)
Offline FunJimmy
  • Who you calling
  • Vancouver
I might have missed that one. Link?
Offline Jayelwin
I agree the picture looks confusing. But rest assured the bearing itself is tapered. They are two different sizes but they are conceptually identical.
