Author Topic: Ugly Duckling CB750 K7 ***updated pics 02/07/14***  (Read 9660 times)
Offline blue collar
« on: December 11, 2013, 04:49:37 AM »
Hello Gents.
This is the first time I've posted pics of my build. Been a slow process but a fun one.
The bike started out pretty rough. Got it for a song, but i had to go over everything.
This is how she looked the day I picked her up.
And how she looks now. Far from done.
Not for everyone/the purists, but it'll do.
« Last Edit: July 02, 2014, 07:13:31 AM by blue collar »
Re: Ugly Duckling CB750 K7
« Reply #1 on: December 11, 2013, 06:22:52 AM »
I dig it immensely! I am purist in the sense of "design dictates style". Obviously shows the level of workmanship and thought you put into the bike. Some great techniques employed to provide solid structure with minimal metal. Really respect that in people's work.
Would love to see more pics, especially those from along the way...
If I could be so bold... Did you consider making your steering bars? You could turn a larger diameter tube down at the top clamp end to fit the tree, but use oversized tubing at the control ends to allow use of more modern controls, levers and switches. If that is your direction ultimately, it would have been a very clever modification.
Love the raw, utilitarian vibe!
Most modern controls for sportbikes are sized for 7/8" bars.
Offline blue collar
« Reply #2 on: December 11, 2013, 07:03:36 AM »
Thanks for the kind words. It's been a process for sure. Lots of staring at the bike and thinking. While some aspects may not be as perfect as I would have liked, the are the best that my hands can create.
As for the controls, I've not had a problem finding what I need in 7/8... :-\
Offline SKTP
« Reply #3 on: December 11, 2013, 10:37:37 AM »
looking good
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline KrautKoffin
« Reply #4 on: December 11, 2013, 11:23:18 AM »
74 cb550
I now have Beastie Boys "Sabotage" stuck in my head after seeing your avatar.
Offline blue collar
« Reply #5 on: December 11, 2013, 11:44:30 AM »
looking good
Thanks man. I've followed your build this past year. Very inspiring.
Offline blue collar
« Reply #6 on: December 11, 2013, 11:45:25 AM »
Now put all of the crap back on it.
Not sure what you mean. But i'm avoiding the 'crap'.
Offline KrautKoffin
« Reply #7 on: December 11, 2013, 11:46:39 AM »
you might want to install pedals then because it wont run without that oil tank hooked up, coils, spark plugs, carbs installed, filters on those, some sort of ignition and wiring :) That's the "crap" I was talking about.
74 cb550
Offline blue collar
« Reply #8 on: December 11, 2013, 11:58:06 AM »
It won't work without all of that? Ok, got it, thanks!  ;)
Offline SKTP
« Reply #9 on: December 11, 2013, 12:03:38 PM »
Rear fender idea that I am liking. Might be really good for you since you most likely will not run the inner plastic fender
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline KrautKoffin
« Reply #10 on: December 11, 2013, 12:19:07 PM »
 ::) Everyone's a comedian.
74 cb550
Offline blue collar
« Reply #11 on: December 11, 2013, 12:28:19 PM »
Ya that looks fantastic. good call.
« Reply #12 on: December 11, 2013, 12:29:30 PM »
BC,
I like the aesthetic so far.  You correctly assume that you will be able to find a wealth of 7/8" controls -- basically every modern sportbike uses 7/8" bars.
It looks like you swapped in a DCC upper triple tree.  Are you going to run stock gauges or something modern?  Have you modified the engine at all?
Offline blue collar
« Reply #13 on: December 11, 2013, 02:11:09 PM »
BC,
Yah went with the DCC upper. The K7 is hard to make 'pretty'; I need all the help I can get lol. I'm not too sure what gauges, not stock though; they're enormous.
The engine was fully torn down. Nothing modified really. Just some stuff to help the top end (new valve guides, valves, rings etc)
Offline blue collar
« Reply #14 on: December 12, 2013, 03:54:23 AM »
Rat fender idea: molded plastic that runs from top of tire, forward to swing arm (concentric to tire) that is then bracketed to swing arm (along pivot bolt line). Plastic will be lightweight and very durable. Flat black paint, and it disappears!
Gauge: MotoGadget Tiny with an M-unit. Super clean, super cool. Shame to adorn that beauty with less than the coolest stuff!
That is sexy, you're right! Who sells them in the US/Canada?
Offline blue collar
« Reply #15 on: December 19, 2013, 11:53:56 AM »
Revival Cycles. I'm definitely going this route on my pending build. Their wireless start solution is ultra cool. Pricey purchase, but value beyond the expense. All control wiring connects up at the bars to a concentrator, then a single wire back to control unit. Fuses are a thing of the past. Converts all signals to digital from the concentrator, even removes need for relays for indicators and brake lights for LEDs and lowers electrical draw.
http://store.revivalcycles.com
Wow nice stuff for sure, but those are pricy! Maybe if i had a nice Ducati Sport Classic or something but the K7 is worth less than the instruments!
Offline blue collar
« Reply #16 on: January 18, 2014, 12:46:12 PM »
So I've progressed in putting the "the crap back on it". Finding the time has been hard.
Controls installed on the bars, clutch hooked up,  throttle connected to the carbs etc.
Next on the list is wiring.
here are a few pics, for those who care.
Chris
And a couple of 'different' angles
Thanks for looking.
Offline KrautKoffin
« Reply #17 on: January 18, 2014, 12:55:26 PM »
Looking good!
74 cb550
Offline blue collar
« Reply #18 on: January 18, 2014, 01:15:04 PM »
Offline snowman
« Reply #19 on: January 18, 2014, 01:58:29 PM »
Looks great. Given me ideas for my K7 build. I like the seat you chose, homemade or did you buy it?
Sent from my iPad using Tapatalk
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #20 on: January 18, 2014, 02:36:33 PM »
Taking shape. That's a cool looking bike mate, well done.
If I had to take issue with any of it, not that I have a right to, it'd be the seat. The old form over function debate. My sorry ass needs some padding under it!
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline BPellerine
« Reply #21 on: January 18, 2014, 04:39:35 PM »
very nice a good look for the k8 tank that I usually don't like I have a k8 as well.what kind of battery and where are you putting it?bill
1978 CB 750K ard and webers
another anfob
Offline blue collar
« Reply #22 on: January 18, 2014, 05:49:19 PM »
When you say seat i'm assuming you mean the "cafe" tail section? Yes i did make it. I made a 1/4 inch round bar "frame" and then covered it in sheet metal. I wanted to mirror that (not so pretty) K7 tan by using 5 panels. The main focus was having a flat top to mirror the flat top of the tank.
Offline blue collar
« Reply #23 on: January 18, 2014, 05:51:58 PM »
Thanks!  And you totally correct, I've not covered the seat pan yet. If you look closely the dimpled portion is a flat pan that also goes up the 'slope' of the tail section. That'll be padded and coved with leather eventually. All the pretty stuff comes last  ;)
Offline blue collar
« Reply #24 on: January 18, 2014, 05:57:07 PM »
I'll be using an Antigravity battery. Ive designed that tail section to hold the battery, fuse box, reg/rec, and other odds. Nothing is by accident.
and i agree, not a pretty tank. But it's rust free and i'd rather use that than battle with a rusty and leaky F/ sub K6 tank just for the look. ;)
