Author Topic: Petcock leak  (Read 802 times)
Offline acollin
Petcock leak
« on: December 11, 2013, 12:41:05 pm »
1974 cb 750 all stock
My petcock appeared to be leaking and overfilling the float bowls. I had another new--still in the wrapper packing washer -- the 4 hole kind. I replaced the packing washer and the leak is now worse. It now leaks outside the petcock from the lever area. -- right where I put the new packing washer. Before the leak was only inside the petcock.
I cleaned the mating surfaces and there does not appear to be any special way to fit things that I know of or can see.
Don't you just love it when you try to fix one thing and something else jumps up.
Please advise-- thanks in advance for your help.
Re: Petcock leak
« Reply #1 on: December 11, 2013, 01:29:22 pm »
fuel resistant pipe (teflon) tape.
works great if you're leaking at the threads.
replace any o-rings or seals with new viton or buna rings.
Re: Petcock leak
« Reply #2 on: December 11, 2013, 01:53:55 pm »
Sure you put it back together correctly and did not put the wavy washer in the wrong spot ?
Offline acollin
Re: Petcock leak
« Reply #3 on: December 11, 2013, 02:17:44 pm »
Ekpent gets the prize.
I came back in and studied the parts books-- which I should have done before i panicked and ran to the forum.
Wavy washer in the wrong spot. When I took it apart, it sort of all sprung off-- I put it back in a way that looked right but did NOT make any sense-- wavy washer should be placed next to a flat surface that would not flex.
This forum is like a good drug-- the problem is the good drug and the forum works. I should have gone back to the book first.
Sorry for the alarm and grateful for the help.
Re: Petcock leak
« Reply #4 on: December 12, 2013, 10:37:49 am »
Been there done that also with the "wavy' washer  :D
Jay Ace
Re: Petcock leak
« Reply #5 on: December 12, 2013, 11:16:28 am »
I have NEVER put that washer in the wrong spot ... EVER ...  :P
