Author Topic: Honda Heat Resistant Wire Sheathing?  (Read 1451 times)
Offline zeech
« on: December 12, 2013, 03:44:26 PM »
What is the black sheathing that Honda used OEM from the factory for the wires that run from the alternator, through and up the side cover? Also the smaller diameter white sheathing for the points? I can't seem to find heat resistant sheathing easily. Rewiring the bike from scratch and am just left with needing some of this. Thanks
Offline 74750k4
Re: Honda Heat Resistant Wire Sheathing?
« Reply #1 on: December 12, 2013, 04:19:12 PM »
« Last Edit: December 12, 2013, 04:31:20 PM by 74750k4 »
Online Don R
« Reply #2 on: December 13, 2013, 10:13:17 AM »
Offline zeech
« Reply #3 on: December 13, 2013, 10:37:37 AM »
That's close 74750k4, thanks I'll look into that.
Don, they don't carry anything like that...
Anyone else?
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #5 on: December 13, 2013, 12:29:27 PM »
Sold by the foot.
http://www.moddiy.com/categories/Cable-Sleeving/Silicone-Fiberglass-Sleeving-%28FSG%29/
Φ1.0mm ~ Φ22mm
Temp. Range: -60 ~ +200 celsius degree
Voltage Resistance Range: 1.2KV
Packaging Details: 500M Per Roll
Colors Available: White, Black, Blue, Red
Offline zeech
« Reply #6 on: December 13, 2013, 02:33:13 PM »
Excellent thank you both madmtnmotors and flybox1!
Offline tomkimberly
« Reply #7 on: December 13, 2013, 06:58:46 PM »
If you care to travel to Fullerton, Orvac will have eveything you need.
http://www.orvac.com/
Tom
