Author Topic: how to save a cb750 from the garbage dump  (Read 53384 times)
Offline Raul CB750K1
Re: how to save a cb750 from the garbage dump
« Reply #50 on: September 07, 2006, 06:53:49 AM »
Bump! This great thread was getting lost in the background, so I thought it would be good to take it back where it can get some more attention.
JohnK6 has given to this forum more information in less than 50 posts than I with more than one thousand!!!!!
Raul
Offline JohnK6
  • I'm NOT Crazy, says the crazy man
« Reply #51 on: September 07, 2006, 11:08:21 AM »
Raul
thanks for the bump ;D, yesterday I had to make overtime at work, when i got home i was buzzy with reading all the forums here, (damned what a information stands here  8)), and i was to tired to make a few postings on the thread :)
now I'm looking at OCC on discovery  8), i like that program,(I hate btw how they're putting in bearings, use a big plastic hammer and hammer it down  :-\ (I want to build a real caferacer out of a CB 750 four, with mono shock, upside down fork and a 822 cc borekit(the borekit is laying here for over a year at a shelf ;D))
« Last Edit: September 07, 2006, 12:10:30 PM by JohnK6 »
owner of: cb750k6(76), cb750k7(78), cb750K7(79)(sold), zwolle, netherlands
Offline JohnK6
« Reply #52 on: September 07, 2006, 11:17:45 AM »
the 822 kit is a bored original cylinder and for the pistons I'm using original pistons from a CB 900 bol d'or, that way it's a lot cheaper than a 836 wiseco kit  ;D, i will need to do someting on the head (pistons are a little bit higher than the original piston from a CB four) i can't do that myself,  but i know a man who can do it ;D
« Last Edit: September 07, 2006, 11:19:31 AM by JohnK6 »
Offline JohnK6
« Reply #53 on: September 07, 2006, 11:48:58 AM »
when i started with this bike, and got it fired up, the main fuse went out, replaced it and after a few minutes it went out again, same #$%* happend when i turned the headlight on, i measured the wire harness out, and tackled a few problems, but it still wasn't O.K, original cable harness was to expensive so i decided that i make my own new cable harness ;D
and
all electrical out  ;D
the #$%*ty looking electrical harness
Offline JohnK6
« Reply #54 on: September 07, 2006, 11:57:44 AM »
luckily making a new electrical harness, doesn't mean you have to do it in the garage so i went inside my apartment (nicely warmed ;D), and a great working coffee-machine  ;)
materials which will be used
a whole lot of collars  :P, butt i used mainly a big cable (stripped it off and so i got a lot of small cable's )witch is mainly black with on every cable a number (this one is numbered from 1 to 20)
made a big copy from the manual, notebook and pen needed to tell myself later wich number cable went were  :D
« Last Edit: September 07, 2006, 12:04:05 PM by JohnK6 »
Offline ChrisR
« Reply #55 on: September 07, 2006, 12:03:49 PM »
Jesus, now he's making his own wiring loom. My brain's hurting with the intensity of it all. What a guy. ;D
ChrisR
1977 CB550F
1975 CB550K
Offline dusterdude
« Reply #56 on: September 07, 2006, 12:06:52 PM »
john,would love to see the monoshock conversion,i bought a cbr 600 swingarm for my bike and am contemplating the monoshock as well.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline JohnK6
« Reply #57 on: September 07, 2006, 12:14:58 PM »
i've got a monoschock swingarm from a fzr 750(alu), good luck ;D to you,and i would like pictures from your project also ;D, mine project i'm hoping to start next spring
« Last Edit: September 07, 2006, 12:17:21 PM by JohnK6 »
Offline JohnK6
« Reply #58 on: September 07, 2006, 12:19:18 PM »
the period i done this was in the winter so i had a little time to spare  :D
damned and with this post i went from newbie to enthusiast 8) 8)
Offline JohnK6
« Reply #59 on: September 07, 2006, 12:29:15 PM »
so we went on ;D
the start
cable's i used:
earth 2.5 mm2(there are a lot of branching from earth)
all other 1,5 mm2
lot of soldering and schrinking
it's looking better ;D
after 9 hours of soldering schrinking and so on  :P
« Last Edit: September 07, 2006, 12:37:20 PM by JohnK6 »
Offline JohnK6
« Reply #60 on: September 07, 2006, 12:34:41 PM »
after a lot of work now i went fitting the cable on the bike so that i could tape the diverge
and in the headlight
Offline JohnK6
« Reply #61 on: September 07, 2006, 12:40:53 PM »
and after taping it all it looked this way  8) 8) 8) 8)
the cable harness took me in total about 16 hours of sparetime, and a whole lot of coffee  ::)
« Last Edit: September 07, 2006, 12:42:55 PM by JohnK6 »
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #62 on: September 07, 2006, 12:47:53 PM »
What did you tape it with?  I may be stripping my bike down and might want to re-wrap my harness.
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
Offline JohnK6
« Reply #63 on: September 07, 2006, 01:00:44 PM »
Self fusion tape 19 mm x 5 m
great stuff 8)
Offline dusterdude
« Reply #64 on: September 07, 2006, 01:01:52 PM »
mine wont be until this winter or next spring too.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline JohnK6
« Reply #65 on: September 07, 2006, 01:27:53 PM »
ok , I'm curish what plan's you have :D
Offline JohnK6
« Reply #66 on: September 07, 2006, 01:57:28 PM »
picture time being :+
on that time it was freezing 15 degrees below Celsius or so  ???( 5 degrees F, i think)
« Last Edit: September 07, 2006, 02:16:35 PM by JohnK6 »
Offline JohnK6
« Reply #67 on: September 07, 2006, 02:22:37 PM »
mounting of the new cable harness
and
Offline JohnK6
« Reply #68 on: September 07, 2006, 02:30:35 PM »
and a few pictures of what i've done in the meantime :)
my own made covers for the headlight (RVS316) ;D 8)
turning signals mounted
headlight mounted
« Last Edit: September 07, 2006, 02:35:51 PM by JohnK6 »
Offline mkramer1121
« Reply #69 on: September 07, 2006, 04:05:17 PM »
 :o  My jaw literally dropped when I saw this thread.  This is simply amazing.  I bought a $150 US 750 K4 earlier this year that is being cafe'd.  Your posts are going to help me out big time when I get to putting it back together.  Nice work, very nice work on the harness as well.
Offline cben750f0
« Reply #70 on: September 07, 2006, 04:58:28 PM »
STICKY THIS THREAD!!!!
Bloody great post mate, this is exactly what should have been done a long time ago, instead of me making do with the not so good, old materials, you have done well, and thanks....
peace
Offline DiscoEd
  • Keeping it surreal!
    • My personal gallery is at:
« Reply #71 on: September 07, 2006, 07:02:27 PM »
JohnK6,
Excelent work! You should be entered into the SOHC4 Hall of Fame! ;D
Regards,
DiscoEd
1975 CB550 K1
1976 CB550
1974 CB360
2003 Suzuki Volusia Intruder
http://gallery.sohc4.net/main.php?g2_itemId=1954
Offline Roach Carver
« Reply #72 on: September 07, 2006, 07:30:59 PM »
fantastic and inspiring
Offline crp_iii
« Reply #73 on: September 07, 2006, 07:32:53 PM »
Wow .... I wish I lived in Germany still so I could go sit in your corner, watch, and learn.
72 CB350F With poor man drag pipes
77 CB750F
Offline JohnK6
« Reply #74 on: September 08, 2006, 01:30:41 PM »
thanks all of you  ;D
I'm already looking for a new bike in that state (I now I'm crazy ::)), this bike drives fine ;D
Here the cable harness is for 90% connected
the coils:
and ofcourse one of the screws breaks, so i drillid it out en put new screws on ;D
