Author Topic: how to save a cb750 from the garbage dump  (Read 57717 times)
Offline JohnK6
  • I'm NOT Crazy, says the crazy man
Re: how to save a cb750 from the garbage dump
« Reply #75 on: September 08, 2006, 01:43:13 PM »
new contact ;D
The former owner had no key's for the bike, so i had to mount a new contact, i could get thisone very cheap from my cbfourparts dealer where i buy most of my parts for a CB four, because it was damaged.
Also in this picture you see on the back my new chokecable (thisone was for free, the cable and the part you screw in the holder was lose, i repaired it with a little of schrinkinghose (you heat it up and it schrinks )
the reason that it was cheap, a lip was broken of, but on my old contact (with no keys) that part was okay so i changed them
by doing these kind off things the costs stay low ;D
« Last Edit: September 08, 2006, 02:19:35 PM by JohnK6 »
owner of: cb750k6(76), cb750k7(78), cb750K7(79)(sold), zwolle, netherlands
Offline JohnK6
« Reply #76 on: September 08, 2006, 01:53:40 PM »
new gascable's (the old ones were so rusted even after a week in a oilbath they didn't went smooth)
same for the clutchcable
also checked the timing off the contactbreakers :)
« Last Edit: September 08, 2006, 01:55:43 PM by JohnK6 »
Offline JohnK6
« Reply #77 on: September 08, 2006, 02:07:39 PM »
time to lose the bolt and let the chaintensioner to do it's work
I do this cil 1 inletvalve and outletvalve closed  and than 15 degrees after the topmark(cil 1-4) (that one you see behind the contactbreakerplate) the camchain is than on a point were the chain has the most slack, and the tensioner can do it's work ;D
lose the bolt , wait a few minutes and than tightening it
time to check the clearance of the valves (inlet 0.05 mm, outlet 0.08 mm)
when i checked it :
cylinder 1 inlet to narrow, outlet way to much
cylinder 2 inlet to much, outlet correct
cylinder 3 inlet to narrow, outlet to narrow
cylinder 4 inlet correct, outlet to much
Offline JohnK6
« Reply #78 on: September 08, 2006, 02:11:28 PM »
sometimes on the pictures you can see that i did some things earlier, i wanted to get the subjects that I'm posting as much as possible to be related at each other,  ;D
John
« Last Edit: September 08, 2006, 02:13:33 PM by JohnK6 »
Offline JohnK6
« Reply #79 on: September 08, 2006, 02:45:00 PM »
next thing was to do something about this:
and
in the primer
the result ;D
there are three cleared(immaculate coating???, that word i get from a translationmachine on google  ???) coatings on  now ;D
Offline cben750f0
« Reply #80 on: September 08, 2006, 04:42:08 PM »
again great post... keep 'em commin... :P
peace
Offline Raul CB750K1
« Reply #81 on: September 09, 2006, 06:43:53 AM »
Well, I'm involved in a CB350 resto and still have to take my hat off this guy. The reason? I would have never think of reusing many of the parts he has saved. That's where the merit is. It's fun to do an eBay search, the thrill of the hunt, and finally finding a replacement, but being able to take a rust bucket and turn it into a good-looking bike -even if not pristine- is definitely praiseworthy.
This guy killed me with the paint removal of the wheel. Having into account the price of a second hand wheel, I would have never take the annoyance to strip the paint, with all the nooks and crannies of the spokes. And what about reusing the rear fender? Well, it's painted, it's not chrome, but there is definitely a lot of merit in reusing those parts. In my opinion, that's actually restoring a bike; what I've been doing until know is just rebuilding and engine, polishing some parts, taking parts to the painter and chasing the parts missing or in bad condition. It's a lot of fun though, but I've spent more than 3k euros...
Please moderator, sticky this post. John, you speak german, don't you? If you have trouble translating just write the german term and I will tell the english term that refers to.
Two thumbs up!!!!
Raul
upperlake04
« Reply #82 on: September 09, 2006, 09:46:37 AM »
John - are you going to keep letting those guys call you German?  ;)  You'd make a fine Canadian ;D ;D
Offline JohnK6
« Reply #83 on: September 09, 2006, 12:36:48 PM »
I'm not German,
I'm Dutch,
 living in Holland ;D, speaks dutch,butt i speak German and English also
« Last Edit: September 09, 2006, 12:43:01 PM by JohnK6 »
« Reply #84 on: September 09, 2006, 02:20:21 PM »
I'm not German,
I'm Dutch,
I know he's dutch -he said so in the first post-, but I have read some german words from him, therefore I guessed he was able to speak german.
Raul
Offline JohnK6
« Reply #85 on: September 09, 2006, 03:52:12 PM »
I'm not German,
I'm Dutch,
Raul
;D you're right  8)
« Reply #86 on: September 11, 2006, 12:13:26 AM »
BUMP!!
DeLuxe
« Reply #87 on: September 11, 2006, 05:12:05 AM »
Oh man, that is one lucky bike to be brought back from the dead like that!
You've built up a great store of Karma with your tireless work...  may the God of Motorcycles forever smile upon you!
Offline JohnK6
« Reply #88 on: September 11, 2006, 03:39:45 PM »
next project was the fueltank.
before
at work i made my own dentremover, which i soldered on the tank, and with a counterweight i pulled the dent  out as much as possible, than i filled the hole which was left with led
after that just a little bit off this is needed
Offline JohnK6
« Reply #89 on: September 11, 2006, 03:45:09 PM »
first time in that stuff
sanded it off
second time with the stuff  ;D
and now it was time to sand it of with waterproof, and where is water at home????, right in the shower there's a lot of water when you need it  8)
and the result  8)
Offline JohnK6
« Reply #90 on: September 11, 2006, 03:52:00 PM »
my own spraying cabin  ;)
when you do things like painting, protect you're self
and yeah this is me  :P
and when youre going to paint were things like this, that protects you and also the object to be painted from human grease (for example from you're hands)
Offline JohnK6
« Reply #91 on: September 11, 2006, 03:59:20 PM »
I'm using spraying paint, (and yeah i now i now, butt my compressor failed, and at that time i didn't have the money for a decent one), butt this will the job,
ground layer
and done
this collar
« Last Edit: September 11, 2006, 04:28:56 PM by JohnK6 »
Offline JohnK6
« Reply #92 on: September 11, 2006, 04:03:59 PM »
tank in collar
and one more time
I wanted to get some striping on the tank and so i went on
Offline JohnK6
« Reply #93 on: September 11, 2006, 04:10:16 PM »
 i liked this
on the top of the tank Yeaaaahhh i'm satisfied 8)
butt on the side  :'(
i've made the striping to small, and i didn't liked it
I had an old original fueltank ( just a dent, and a little rost here and there, so i mounted that on the CB), this tank is still waiting for me to get some time  ;D
Offline JohnK6
« Reply #94 on: September 11, 2006, 04:50:29 PM »
and than she looked like this :P
time to get her started ;D, when i was trying to do that a few friends wanted to look, and what do you think the bike wouldn't start (she was getting no fuel, my own stupid mestake when i take a look at the carburetors (i had my floatings the wrong side up mounted)
on the picture you can just see the headlight of my Honda crx (imported from USA, by the former owner ;D)
and a few pictures made by a friend of mine ;D
and
« Last Edit: September 11, 2006, 05:07:21 PM by JohnK6 »
Offline JohnK6
« Reply #95 on: September 11, 2006, 04:57:44 PM »
back to the 70íes
and a short film of it :P, on the end set you're volume of the speakers at max  ::)(made by a friend of mine)
http://video.google.com/videoplay?docid=-8486573920432019224
« Last Edit: September 11, 2006, 05:06:13 PM by JohnK6 »
Ratfink
« Reply #96 on: September 11, 2006, 06:35:05 PM »
Good work man!
Offline cben750f0
« Reply #97 on: September 11, 2006, 08:11:25 PM »
M8 that pipe sounds unreal, you got to be happy with that... well done you must be suitably proud....
peace
Offline unkle fester
« Reply #98 on: September 11, 2006, 08:17:38 PM »
what exhaust is on there???????????  It sound wicked.......
« Reply #99 on: September 12, 2006, 06:07:14 AM »
Congratulations! This is a great post. I'm proficient at mechanics, but painting is not one of my strong points. Your tank looks great for being a home paint. Good work!
Raul
