Author Topic: Cool Blower engine concept  (Read 2119 times)
« on: December 15, 2013, 03:10:18 pm »
Just saw this somewhere, just got enough info to search it.
  Fellow by the name Bart Crauwells took a 1000 Ducati engine. Turned rear cylinder into a supercharger feeding the front cylinder,the net result. Being 102 hp from under 90.
 Now this makes me think, if you built a 750 to 1000cc, used the inner cylinders. (or 1 +3) as the blower , it would be a cool running motor.
 To see it search his name and supercharger.
  • Moderator
Re: Cool Blower engine concept
« Reply #1 on: December 15, 2013, 04:04:25 pm »
DKW did it in the 50s frank.
Sam. ;)
« Reply #2 on: December 15, 2013, 04:14:23 pm »
You mean on the v3......... The rough basis of the H1 motor...?
Offline afkrejci90
« Reply #3 on: December 15, 2013, 05:37:03 pm »
This is interesting, I wonder if it could work on car engines too.
'78 CB750K http://forums.sohc4.net/index.php?topic=105327.0
'80 CB750C - Sold
'06 CBR600RR
Offline H2Eric
« Reply #4 on: December 16, 2013, 05:59:50 am »
Sam. ;)
I think it was the mid 1930's Sam, a bit before my time, but surely you remember. Ewald Kluge won the 1938 lightweight (250cc) Isle of Man TT on one. A fiendishly clever idea and a two-stroke at that.
Eric
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
http://forums.sohc4.net/index.php/topic,94588.0.html
Growing old is mandatory, growing up is optional.
Offline Tintop
« Reply #5 on: December 16, 2013, 09:43:19 am »
Definitely the 30's H2Eric.  Inside of the 1936/38 IoM 250 -
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #6 on: December 16, 2013, 10:21:56 am »
I think they had a V3. Triple, the lone one in the centre, pumprd the Air to the other two..
Offline Tintop
« Reply #7 on: December 16, 2013, 11:28:08 am »
It's a two stroke 754.  The big piston laying horizontal pumped air into the crank case to feed a compressed fuel charge into the twin water cooled cylinders.
77 CB550 Cafe build
« Reply #8 on: December 16, 2013, 07:52:36 pm »
I think we are talking two different motors.
Offline Tintop
« Reply #9 on: December 16, 2013, 08:13:58 pm »
Probably, the picture is of the 1938 DKW that H2Eric referred too.
77 CB550 Cafe build
  • Moderator
« Reply #10 on: December 18, 2013, 02:48:25 am »
Yes, It's me getting at crossed purposes, the 30s 250 was the compressor, the 50s was just a V3 350.
Sam. ;)
« Reply #11 on: December 18, 2013, 09:34:22 am »
So the v3 all cylinder were Hot ?..was not sure but was aware that it influenced the H1. Design basis..
Offline Tintop
« Reply #12 on: December 18, 2013, 02:21:08 pm »
Actually it had more influence on Honda's V3 2 stroke GP bikes.  DKW 's were basically two vertical cylinders with rear mounted side draft carbs, and a horizontal front cylinder with a down draft carb.  We had a DKW car in the early 60's, similar shape to a VW Beetle.  It was a 2 stroke that would blow the doors off a VW. ;) ;D
77 CB550 Cafe build
Offline turboguzzi
« Reply #13 on: December 18, 2013, 03:17:01 pm »
the dkw v3 was a conventional, i.e. not supercharged two stroke twin  (Yamaha RD style) + an extra horizontal cyl added between the two upright cyls. + supercharging was banned after WWII .....
there's a pretty crazy guy named ellwood who raced a sort of "six stroke" single in supermono, essentially using the volume UNDER the piston as a supercharger for the top part. there was plenty o'tubing all over the place ....
Offline Tintop
« Reply #14 on: December 18, 2013, 04:00:16 pm »
Correct TG, we covered which where the DKW supercharged / NA versions a couple of posts back.  Super charged pre WW2 (banned after, along with the BMW super charged flat twin, and AJS twin), V3 from around 1952/3.
77 CB550 Cafe build
