Author Topic: Which dremel to buy?  (Read 1142 times)
Offline Carver
« on: December 16, 2013, 05:36:07 PM »
Alright I'm in the market for a dremel but Dunno which model I should get? Definitely a cordless one since the bike is a block away from me.
http://www.dremel.com/en-us/Tools/Pages/CategoryProducts.aspx?catid=2013&WT.ac=NHPC_2013_ProductCarousel
Is the 7300 too small? should I opt for a larger one?
Cb 750 k3
Cb 450 dohc k4
Offline 78 k550
Re: Which dremel to buy?
« Reply #1 on: December 16, 2013, 08:01:08 PM »
not sure about the cordless but i like the consistency of electric power. Have you ever tried to use a air cutoff tool with too small of a air supply. I would think it is the same with a cordless, Maybe not I might be way off. Like to see what others say.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline Mo
« Reply #2 on: December 16, 2013, 10:04:26 PM »
I bought a corded black and decker off of amazon. It was cheap, dremel accessories work just fine, and reviews were good.  I'm very pleased.
http://www.amazon.com/Black-Decker-RTX-B-3-Speed-Rotary/dp/B000MUSLCC/ref=sr_1_4?ie=UTF8&qid=1387260252&sr=8-4&keywords=dremel+tool
Offline Carver
« Reply #3 on: December 16, 2013, 11:20:06 PM »
I don't really have access to an outlet where the bikes are so cordless would be best.
Cb 750 k3
Cb 450 dohc k4
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #4 on: December 17, 2013, 12:55:48 PM »
A Dremel is one of those must haves. Bit like a motorcycle lift in the respect that once you have one, you can't imagine how you managed without one. If you need to go cordless so be it, just get it!
Build threads:
1977 CB750 F2
1958 Norton Model 99
« Reply #5 on: December 17, 2013, 01:17:27 PM »
Run an extension cord!!!
I have two, and use them equally
I have the cordless Minimite 7300  (6,500/13,000RPM) and the corded 200 Series (15,000/35,000 RPM)
I find the slower 6500 RPM very useful for the sanding attachments.   Many of the sanding buffs, wire wheels and discs work better and last longer at a lower rpm.
Cutting and grinding, 6500rpm is nice, but takes too long, especially w a battery not lasting that long.
35000rpm makes quick work of most things.
the EZ Lock shaft bit and its accessories are great, as well as the flex shaft attachment.
Offline Carver
« Reply #6 on: December 17, 2013, 03:33:50 PM »
It looks like the 7300 will be what im getting. The only cutting i really need it for right now is grinding a cam chain and them im going to be using it for polishing right now at least. thanks! I like corded stuff a lot but right now I live in an apartment complex and I would need to run 5 extension cords to get it to the bike. Dreaming of the day I have a garage.  ;D
Cb 750 k3
Cb 450 dohc k4
« Reply #7 on: December 17, 2013, 10:02:08 PM »
Get a second battery....
Offline Carver
« Reply #8 on: December 22, 2013, 03:05:15 PM »
Well I got the 7300 and it is really cool. Works for everything I need it to and is super compact. +1 on buying the extra battery so you don't have to wait for it to charge. I would recommend it if like me your bike is too far to use a plugged in one.
Cb 750 k3
Cb 450 dohc k4
Offline nccb
  • 1974 CB750 Four
« Reply #9 on: January 02, 2014, 02:54:54 PM »
I just got a Trio for Xmas from the inlaws.  I don't think it will work for a bike since the shank size is different but I am currently borrowing my parents 1100(? I think), the basic model, and its decent.  Would like one of those extension things that go on it so you can work in tighter spots.
Offline Carver
« Reply #10 on: January 02, 2014, 03:43:10 PM »
Just an update the model i got is NOT too great for cutting metal. It's doing it but got dang its taking forever.
Cb 750 k3
Cb 450 dohc k4
« Reply #11 on: January 02, 2014, 07:39:39 PM »
Yuuup  ::) said something like that in my first post.   ;D
Offline fmctm1sw
« Reply #12 on: January 04, 2014, 06:24:03 PM »
+1
+1.  I don't know how I lived without one.
I bought one a few years ago, can't remember the model (300 series maybe?).  I sawed an old car tire off a rim and cut through the steel belts with that little thing.  Little bits of burned rubber were flying here and there.  I burned up the brushes and bought another set off ebay and it's still going strong.   If you're going with a cordless, see if you can find someone with a CD welder and have a quality battery pack made.   A lot of tools use those 1.5VDC Sub C size batteries.  Even seemingly "quality" batteries can be dodgy.   I bought a new (aftermarket) 2400 m/Ah battery pack for my Roomba.  When I took it apart, they were all 1800 m/Ah.  That was when I vowed to build my own batteries....  then I got lazy and didn't do it  ::)
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline faux fiddy
  • bike in a box
« Reply #13 on: January 10, 2014, 01:04:54 PM »
I have three dremel type  tools, one was a harbor freight 12v cheapie that still works. Not much to cheer about as far as industrial, but I bought it to repair some furniture for my aunt when I was visiting and it got me through the job, still works today.  It came with a dozen or more attachments and cost in the 10 dollar range on special. Good for a budget if you just need something to use on a project.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #14 on: January 10, 2014, 02:19:24 PM »
I'd get a Rotozip for any long-term use, having just replaced the entire innards of my Dremel for want of a $3 bearing in it. Every Dremel I have seen is really a very light-duty tool, and in my case I ususally want/need a bit more power and sturdiness. YMMV
Very dubious about the longevity of a cordless one too.
I have a motorcycle problem.
Offline faux fiddy
  • bike in a box
« Reply #15 on: January 10, 2014, 03:07:24 PM »
I used another worker's roto-zip doing a sheetrock job one time and it was a good thing to have handy.
