Author Topic: 78' 550 Cam Tensioner O'Rings  (Read 543 times)
Offline K_Kalynuik
« on: December 17, 2013, 11:31:24 AM »
Hey Everyone, just wondering if anyone could help shed some light as to why there is two part numbers listed for the cam chain tensioner O'rings that go behind the tensioner bolt. See the image below. According to the list, there are two part numbers with the tag '10' and they have two different sizes. As far as I can tell, there is only a spot for one o'ring as the diagram shows. Which is it?
91305-323-000
     or
91318-ME5-003
Thanks,
Kenny
78' CB592 - http://forums.sohc4.net/index.php?topic=121580.0
1996 Ducati 900ss
1983 Kawasaki GPz750 Track bike
Offline LesterPiglet
  • 1977 CB550F2
Re: 78' 550 Cam Tensioner O'Rings
« Reply #1 on: December 17, 2013, 11:35:02 AM »
The smaller one has superseded the larger one.
91318-ME5-003 it is.
Offline K_Kalynuik
« Reply #2 on: December 17, 2013, 11:47:47 AM »
Ok great! thanks a bunch for the quick reply.
1996 Ducati 900ss
Offline DustyRags
  • I'm not skilled, I'm just a
  • Just try it and see what happens
« Reply #3 on: December 17, 2013, 01:25:46 PM »
Might want to throw a washer in there too. Mine had a shaft that was a titch too long, and the nut would bite down on the end of the threads. The result was that you couldn't torque the nut enough to prevent it from spinning, because it only torqued against he shaft, not the engine case. Tossed a washer in there, and problem solved.
1976 CB550K- sold
2005 Kawasaki Vulcan 500- sold
2000 CB750 Nighthawk - sold
1975 XL350 - crashed
2004 Suzuki Vstrom 650 - sold
