Author Topic: CB750K2 Bionic Mongrel Build  (Read 129496 times)
Offline RJ CB450
Re: CB750K2 Bionic Mongrel Build
« Reply #125 on: June 26, 2014, 02:10:19 PM »
One issue with a sight glass is able to tell how low if it starts getting low.  Course, just need a bigger one then
74 CB450 K7 Supersport, 82 CB650sc Nighthawk, 1982 CBX 1000, 2015 Tiger XCx.... And some ol minibike with a 5hp Briggs.
« Reply #126 on: June 26, 2014, 02:28:29 PM »
http://www.monstercraftsman.com/gas-tank-sight-glass-kit-with-steel-weld-in-bung/
All you need is Aluminium bung, also these sight glasses are very common on machinery hydraulic tanks and come in different shapes and sizes. On some at work we round oval and rectangle. The rectangle are good as they give a broader range level that is visible.
Good idea Timbo.
Offline sethdhawkins
« Reply #127 on: June 27, 2014, 04:01:19 AM »
At my work, we have the type with the tube of glass and these little pink flippy things that tell you when the tank is full. They're the cause of many a spill during fuel transfers.
All a man needs in this world is someone to love, if you can't give him that, give him hope, if you can't give him hope...just give him something to do!
1972-ish CB750K
1974 CB450
1974 CB360
1976 136' Ocean Going Tug
« Reply #128 on: August 21, 2014, 11:46:34 AM »
Hey, that's right, I do have a pending 750 project that I've been neglecting.
I sent my oil tank/fender back to Ian Halcott for mods.  He's installing a stainless steel sight glass.
After I get it back, I'm hoping to have the bike mocked up.
« Reply #129 on: August 25, 2014, 06:58:00 PM »
That's what I'm talking about!
1972-ish CB750K
1974 CB450
1974 CB360
« Reply #130 on: August 29, 2014, 02:19:47 PM »
Damn McMaster or I should say the post office lost my Sight Glass.  Have to wait for a replacement.
« Reply #131 on: September 03, 2014, 11:28:18 PM »
Sight glass welded in place by Ian (Halcott) and on its way back to me!
« Reply #132 on: September 03, 2014, 11:32:15 PM »
Nice ^^  ;)
Offline BPellerine
« Reply #133 on: September 04, 2014, 05:56:27 PM »
you are buiding the bike of the month!bill
1978 CB 750K ard and webers
another anfob
« Reply #135 on: September 04, 2014, 11:11:34 PM »
Thanks, guys!  :D
Offline RobbyD
« Reply #136 on: September 06, 2014, 05:23:02 PM »
Bikes looking great cb!!
Ian sure does some awesome work
« Reply #137 on: September 06, 2014, 11:19:19 PM »
Thanks, Robby.
Yes, Ian is an artist and a really cool guy -- aside from toying with this bike addict and trying to convince me to undertake another project.  ;)
« Reply #138 on: October 30, 2014, 04:21:00 PM »
Noice!
1972-ish CB750K
1974 CB450
1974 CB360
« Reply #139 on: December 08, 2014, 03:02:19 PM »
Frame mods in progress for: frame kit, bracing, detabbing, mounts for seat, oil fender/tank, steering damper, battery and electronics.   ;D
Offline Trad
« Reply #140 on: January 21, 2015, 03:36:13 PM »
Jeez Don, I just read through the build, had not seen prior. My mouth is watering; The tank, Cbr front end, everything really. Super clean work and nice job on the piecing together. It has a very consistent look.
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
« Reply #141 on: January 21, 2015, 03:40:48 PM »
Thanks, Jared.  I really want this bike as light as reasonably possible, to take advantage of the increased power/torque and modern suspension.  I know it's not period correct, so some people may not like it, but it's what I want for this particular build.
Offline Riceman
« Reply #142 on: January 21, 2015, 06:00:38 PM »
Whoa! first I've seen of your build,bike is turning out really nice!
What size rims are you going with?
« Reply #143 on: January 21, 2015, 06:04:07 PM »
Thanks!  Most likely 18" F & R. I was thinking of 17" too, but will likely go with 18s - custom one-off Morris Mag style billet aluminum.
Offline Trad
« Reply #144 on: January 22, 2015, 11:17:25 AM »
With something like this you need to throw out the idea of "period correct"; If someone cant appreciate it for what it is, that's their loss.  You are making the ultimate riding machine with a vintage frame. This is bad ass,  it's going to haul ass and handle on rails.
« Last Edit: January 22, 2015, 11:33:39 AM by Trad »
« Reply #145 on: January 22, 2015, 11:32:18 AM »
Thanks, Jared.  The motor is nearly identical in spec to Doctor D's 750SS.  The main difference is that I will be running a MGP 4-1 instead of Dave's AWESOME 4-4 Megaphones.  Dave's bike is on the lighter side (he shaved significant weight from stock), but mine will have also have a lighter modern front end, wheels, gas tank, seat, oil tank -- so I should be shedding some additional weight.  They say every 6 lbs you save is equivalent to an extra hp, but along with power, you also get a more nimble platform, and lighter wheels should create less gyroscopic effect and ease turning.
« Reply #146 on: January 22, 2015, 11:40:13 AM »
At least that part didn't cost an arm and leg! It did, however cost me about 3 hours in the shop, cutting, extending, welding and re-milling my bracket to make room for the darn thing!
Motogadget-Master Cal,
Does your gauge require only one button for operation or does it need two (one for mode selection; one for zeroing out, etc.)?
« Reply #147 on: January 22, 2015, 01:45:04 PM »
Just one, Grasshopper. Just one. The momentary button can function in different modes dependent upon which menu you select, which submenu option you choose, and whether there is a "Reset" variable available.
If you're sticking with the stock CBR controls, may be able to wire one of the momentary features of it to be the MENU button to alleviate another button or switch... Or you could use a micro momentary installed on the bar in a discreet location to operate it.
BTW, you also have the option of how many menu lines you can display. I've set mine to 2 (ODOMETER permanently on top, and Voltage or MPH as toggles below) lots of variables and programming available in that gauge (RPM limit, Gear position, Shift flash, etc). Not to mention IDIOT lights built in and light sensitive LED backlight.
I can't stand their stuff...absolute junk and rubbish-  ::)
Wow.  I didn't realize it was so open to customization.  I think I will just run the single accessory button (since I already bought it) and mount it either on the bars or discretely on the mounting bracket (maybe on the side).  MG electronics are pricey but they sure are quality stuff.
« Reply #148 on: January 22, 2015, 01:56:09 PM »
All this talk and no pictures..!!    ;) ;D
« Reply #149 on: January 22, 2015, 03:21:27 PM »
Sadly, this build has been moving like molasses.  It is not so easy to find someone to machine you custom one-off wheels at a reasonable cost.  I've also been squandering my time with my other projects.  Distractions!!  The wheels are a key element to the mock up.
PLUS, I've quietly engaged Denis Curtis to make me a chrome-moly boxed swingarm (in place of my Carpy Dresda replica).  It should be completed in about a month.  It will be very similar to the one he made for Brent Waller:
