Author Topic: CB750K2 Bionic Mongrel Build  (Read 76462 times)
Re: CB750K2 Bionic Mongrel Build
« Reply #150 on: December 08, 2014, 03:02:19 PM »
Frame mods in progress for: frame kit, bracing, detabbing, mounts for seat, oil fender/tank, steering damper, battery and electronics.   ;D
Offline Trad
« Reply #151 on: January 21, 2015, 03:36:13 PM »
Jeez Don, I just read through the build, had not seen prior. My mouth is watering; The tank, Cbr front end, everything really. Super clean work and nice job on the piecing together. It has a very consistent look.
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
« Reply #152 on: January 21, 2015, 03:40:48 PM »
Thanks, Jared.  I really want this bike as light as reasonably possible, to take advantage of the increased power/torque and modern suspension.  I know it's not period correct, so some people may not like it, but it's what I want for this particular build.
Offline Riceman
« Reply #153 on: January 21, 2015, 06:00:38 PM »
Whoa! first I've seen of your build,bike is turning out really nice!
What size rims are you going with?
« Reply #154 on: January 21, 2015, 06:04:07 PM »
Thanks!  Most likely 18" F & R. I was thinking of 17" too, but will likely go with 18s - custom one-off Morris Mag style billet aluminum.
Offline Trad
« Reply #155 on: January 22, 2015, 11:17:25 AM »
With something like this you need to throw out the idea of "period correct"; If someone cant appreciate it for what it is, that's their loss.  You are making the ultimate riding machine with a vintage frame. This is bad ass,  it's going to haul ass and handle on rails.
« Last Edit: January 22, 2015, 11:33:39 AM by Trad »
« Reply #156 on: January 22, 2015, 11:32:18 AM »
Thanks, Jared.  The motor is nearly identical in spec to Doctor D's 750SS.  The main difference is that I will be running a MGP 4-1 instead of Dave's AWESOME 4-4 Megaphones.  Dave's bike is on the lighter side (he shaved significant weight from stock), but mine will have also have a lighter modern front end, wheels, gas tank, seat, oil tank -- so I should be shedding some additional weight.  They say every 6 lbs you save is equivalent to an extra hp, but along with power, you also get a more nimble platform, and lighter wheels should create less gyroscopic effect and ease turning.
« Reply #157 on: January 22, 2015, 11:40:13 AM »
At least that part didn't cost an arm and leg! It did, however cost me about 3 hours in the shop, cutting, extending, welding and re-milling my bracket to make room for the darn thing!
Motogadget-Master Cal,
Does your gauge require only one button for operation or does it need two (one for mode selection; one for zeroing out, etc.)?
Offline calj737
  • I refuse...
« Reply #158 on: January 22, 2015, 01:12:18 PM »
Just one, Grasshopper. Just one. The momentary button can function in different modes dependent upon which menu you select, which submenu option you choose, and whether there is a "Reset" variable available.
If you're sticking with the stock CBR controls, may be able to wire one of the momentary features of it to be the MENU button to alleviate another button or switch... Or you could use a micro momentary installed on the bar in a discreet location to operate it.
BTW, you also have the option of how many menu lines you can display. I've set mine to 2 (ODOMETER permanently on top, and Voltage or MPH as toggles below) lots of variables and programming available in that gauge (RPM limit, Gear position, Shift flash, etc). Not to mention IDIOT lights built in and light sensitive LED backlight.
I can't stand their stuff...absolute junk and rubbish-  ::)
« Reply #159 on: January 22, 2015, 01:45:04 PM »
Wow.  I didn't realize it was so open to customization.  I think I will just run the single accessory button (since I already bought it) and mount it either on the bars or discretely on the mounting bracket (maybe on the side).  MG electronics are pricey but they sure are quality stuff.
« Reply #160 on: January 22, 2015, 01:56:09 PM »
All this talk and no pictures..!!    ;) ;D
Offline calj737
  • I refuse...
« Reply #161 on: January 22, 2015, 02:18:22 PM »
What do you want a picture of Retro?
« Reply #162 on: January 22, 2015, 03:21:27 PM »
Sadly, this build has been moving like molasses.  It is not so easy to find someone to machine you custom one-off wheels at a reasonable cost.  I've also been squandering my time with my other projects.  Distractions!!  The wheels are a key element to the mock up.
PLUS, I've quietly engaged Denis Curtis to make me a chrome-moly boxed swingarm (in place of my Carpy Dresda replica).  It should be completed in about a month.  It will be very similar to the one he made for Brent Waller:
« Reply #163 on: January 22, 2015, 03:48:20 PM »
Boobs, i mean bikes, i mean, well pictures.... ;D ;)
« Reply #164 on: January 22, 2015, 03:50:06 PM »
Don, what size {width} 18 inch wheels are you after mate...? I have some awesome 18 inch wheel links from Japan in a number of sizes and configurations if you are interested....?
« Last Edit: January 22, 2015, 03:53:30 PM by Retro Rocket »
Offline calj737
  • I refuse...
« Reply #165 on: January 22, 2015, 03:50:44 PM »
I was coveting that swing arm when BW posted a pic earlier, now I'm really admiring it. I especially like the tapered bearings and the collar he fabricated. But, what is the function of the steel plate in the picture? I see it has spool lugs on the underside, a very nice touch!
« Reply #166 on: January 22, 2015, 03:54:04 PM »
The gusset in the bend or the nylon chain guide..?
Offline calj737
  • I refuse...
« Reply #167 on: January 22, 2015, 03:56:03 PM »
must be the chain guard. Suspected it might be that. I saw where he gusseted the weld for added strength.
« Reply #168 on: January 22, 2015, 03:57:06 PM »
Retro is correcto.  The plate at the front of the arm is a HD nylon chain guard.  The welding at the bend is a reinforcement gusset.
Offline pn2501
« Reply #169 on: January 22, 2015, 04:01:46 PM »
That Swing arm :swoon:
following this thread.
Offline slikwilli420
  • Master of Disaster
« Reply #170 on: January 22, 2015, 07:25:21 PM »
Outstanding collection of parts you are gathering. You mention custom wheels, what are you thinking for a design?
« Reply #171 on: January 22, 2015, 08:35:47 PM »
Up to now, I've been leaning toward 18" wheels front and rear with a Morris mag style. I'm also considering 17" wheels.
Offline pn2501
« Reply #172 on: January 22, 2015, 11:27:16 PM »
Just a quick question how much would you part with your replica for? you can pm me if you like.
Offline Restoration Fan
  • My wife will never call me
« Reply #173 on: January 23, 2015, 03:30:37 AM »
Holy smokes, what a thread!  I can't wait to see how this bike turns out!
« Reply #174 on: January 23, 2015, 05:09:51 AM »
When much longer shocks are installed it adversely changes the swingarm angle and the chain will touch the front there on over run so the delrin pad protects it.
You'll be happy with the new arm Don. Any change in the length compared to stock?
