When do you expect to have this project finished?
Hah! Finished? They are never finished!
![Wink ;)](http://forums.sohc4.net/Smileys/default/wink.gif)
My next step will likely be sourcing shocks. I am between choosing Works, Race Tech or Fox. I am leaning toward Fox, but have to make up my mind. Much thought and consultation has gone into revising the triples and swingarm to maximize handling. I may also need to re-spring the forks when I have a final wet weight.
The biggest stumbling block is getting custom Morris mag replica wheels sourced. I have a manufacturer in mind, but I'm trying to figure out cost and production time. I also need to sort out what type of rear brake, since I want a rear disc brake (not sure if I will go with a F-type or some type of hybrid-modern like the front). That needs to be sorted first before I can get wheels produced. Well before that time, Devin will be done with my new triple trees, and the only thing left to source will be carburetors (likely Mikuni RS34s).
So who knows. It's a journey! Once the wheels are in production, things will go pretty fast, since everything else (except those things above) are already sourced and waiting.
