Author Topic: CB750K2 Bionic Mongrel Build  (Read 76450 times)
Re: CB750K2 Bionic Mongrel Build
« Reply #200 on: March 17, 2015, 04:16:22 AM »
 8)
Offline Restoration Fan
  • My wife will never call me
« Reply #201 on: March 17, 2015, 04:52:54 AM »
Don,
Does customs hold up parts for a period of time when they come from Canada?  Never ordered any parts from Canada but I had the opportunity a while back to bid on something from eBay that was from Toronto.  I passed on it because I needed the part fairly quickly and was afraid that customs might hold up the process.
Offline calj737
  • I refuse...
« Reply #202 on: March 17, 2015, 05:53:33 AM »
Note ally Customs does not delay inbound shipments, depending upon what it is. IF the Declaration lists items as chemicals, electronics, etc that are on high inspection list, then it's possible. Most consumer transactions between private parties fly right thru.
Shipping into other countries from the U.S. can cause delays as many countries require inspection further to evaluate Duties and Fees, even on private transactions. So it becomes a balancing act of insurance, Duty and risk to ship some items abroad. Every time I've done it,  assume the risk of replacement becuase with shipping manifests it's reasonably easy to track and locate packages.
« Reply #203 on: March 17, 2015, 06:06:21 AM »
Parts usually clear in a day or so.
« Reply #204 on: March 25, 2015, 01:51:04 PM »
I received the swingarm and it looks damn good.  I also bit the bullet and ordered a set of custom/increased 50mm offset triples from Devin at Cognitomoto, since the stock CBR600RR triple has so little offset.
http://cognitomoto.com/collections/new-products/products/cbr600rr-cbr1000rr-fixed-offset-triple-tree-conversion-45mm-50mm-55mm-60mm
They will look like the following but not have the eccentric offset adjuster -- just a fixed offset.
Offline sethdhawkins
« Reply #205 on: March 25, 2015, 02:03:08 PM »
I wish these were available when I did my swap :( Very nice.
All a man needs in this world is someone to love, if you can't give him that, give him hope, if you can't give him hope...just give him something to do!
1972-ish CB750K
1974 CB450
1974 CB360
1976 136' Ocean Going Tug
« Reply #206 on: March 25, 2015, 09:10:12 PM »
Only 2-3 week production time. Get on the bus, Seth!
« Reply #207 on: April 01, 2015, 09:46:03 PM »
I cannot say enough good things about Denis Curtis/CMR and his workmanship.
I spent a few minutes ogling my new swingarm.
« Reply #208 on: April 01, 2015, 11:45:54 PM »
Very nice... ;)
Offline calj737
  • I refuse...
« Reply #209 on: April 02, 2015, 03:39:18 AM »
Gosh darn sexy, Don! I'd love some dimensions off that pivot rod  :)
« Reply #210 on: April 02, 2015, 06:34:54 AM »
What dims are you interested in? OD? The inside has races for the tapered needle bearings.
Offline calj737
  • I refuse...
« Reply #211 on: April 02, 2015, 06:35:38 AM »
is that the axle shown or the pivot rod?
« Reply #212 on: April 02, 2015, 06:37:23 AM »
Ah. That's the new axle.
« Reply #213 on: April 02, 2015, 12:08:07 PM »
Picked up another bike porn part.  Since I am not running the stock hub and Brembo snowflake rotors, I ordered a pair of Galfer wave rotors (fitment for CBR600RR wheel) -- not the insane superbike ones but the petal rotors (still cool).  They will look like this:
Offline Trad
« Reply #214 on: April 02, 2015, 02:00:01 PM »
This thing is insane Don!
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
« Reply #215 on: April 02, 2015, 02:09:40 PM »
I knew I had to get rotors, since I was no longer using the larger Brembo snowflakes, so I could buy some used CBR600RR rotors or pay a little extra and get something befitting the rest of the bike.
Offline Trad
« Reply #216 on: April 02, 2015, 03:07:56 PM »
When do you expect to have this project finished?
« Reply #217 on: April 02, 2015, 03:39:10 PM »
Hah! Finished? They are never finished!  ;)
My next step will likely be sourcing shocks.  I am between choosing Works, Race Tech or Fox.  I am leaning toward Fox, but have to make up my mind.  Much thought and consultation has gone into revising the triples and swingarm to maximize handling.  I may also need to re-spring the forks when I have a final wet weight.
The biggest stumbling block is getting custom Morris mag replica wheels sourced.  I have a manufacturer in mind, but I'm trying to figure out cost and production time.  I also need to sort out what type of rear brake, since I want a rear disc brake (not sure if I will go with a F-type or some type of hybrid-modern like the front).  That needs to be sorted first before I can get wheels produced.  Well before that time, Devin will be done with my new triple trees, and the only thing left to source will be carburetors (likely Mikuni RS34s).
So who knows.  It's a journey!  Once the wheels are in production, things will go pretty fast, since everything else (except those things above) are already sourced and waiting.
« Last Edit: April 02, 2015, 05:14:25 PM by CB750 Cafe Racer Fan »
Offline BPellerine
« Reply #218 on: April 02, 2015, 05:07:33 PM »
this will be a bike to see!!!bill
1978 CB 750K ard and webers
another anfob
Offline Blackfin5
« Reply #219 on: April 02, 2015, 09:27:18 PM »
Don, have missed the last few pages of this thread.  I'm right behind you in a CMR swingarm for the F1.  Will be following with great interest.  Nice build you have going!!
« Reply #220 on: April 02, 2015, 09:42:05 PM »
You will not be disappointed.  I thought it looked good in pictures.  I about crapped myself when I opened the box.  The craftsmanship is awesome.  Weldporn worthy, too.
« Reply #221 on: April 08, 2015, 09:49:09 AM »
Just got me Galfer Wave brake rotors from Riders Discount.  Mike Van Wieren at Riders is awesome to deal with and always seems to make a better deal than anyone on stuff like this (Brembo MCs, etc.).  The rotors look freaking amazing, and these are just the base models (not the crazy superbike racing ones).
Now to sort out the rear brake issue and the wheels!
Offline Trad
« Reply #222 on: April 08, 2015, 11:03:48 AM »
Dayum! you have quite the horde going for this bike.  :P
« Reply #223 on: April 08, 2015, 11:19:37 AM »
If I am going to say goodbye to the Nine Lives bike, it is because this bike will be so much more.  I have been trying to incorporate the lessons from my trial and error with the Nine Lives bike and make this one a restomod on steroids -- hence the name Bionic Mongrel.  I don't feel a twinge of regret, either, because this bike started off as a non-runner looking like this (and, yes, the 4-4 pipes were completely roached):
« Last Edit: April 08, 2015, 11:26:27 AM by CB750 Cafe Racer Fan »
Offline calj737
  • I refuse...
« Reply #224 on: April 08, 2015, 12:28:27 PM »
Any chance you still have that seat?
Kidding!
