Author Topic: CB750K2 Bionic Mongrel Build  (Read 139505 times)
0 Members and 8 Guests are viewing this topic.
Re: CB750K2 Bionic Mongrel Build
« Reply #25 on: December 23, 2013, 10:46:44 AM »
Fast forward to October this year and the tank was completed (and gorgeous).  It is fitted with a vented Monza cap and a Pingel petcock.  It fits snugly, and clears the forks, trees and clip-ons perfectly.  Here are some pictures Denis took prior to shipping it out to me:
« Last Edit: December 23, 2013, 02:58:30 PM by CB750 Cafe Racer Fan »
« Reply #26 on: December 23, 2013, 10:49:22 AM »
Fitted onto MY K2 frame and CBR600RR Front End:
« Last Edit: December 23, 2013, 02:37:18 PM by CB750 Cafe Racer Fan »
« Reply #27 on: December 23, 2013, 02:39:25 PM »
Some detail shots of the underside mounts and petcock bung:
« Reply #28 on: December 23, 2013, 02:45:47 PM »
Since I sprang for an aluminum tank, it would seem fitting to source an aluminum seat, as well.  I was really pleased with Ian Halcott's (Twinline founder and http://caferacerseatandtank.com/) fine work on my K7 seat that I called him to fabricate a new aluminum seat for this project.  I am also thinking about having him fabricate an oil tank in a fender to replace the stock oil tank and open up the triangle underneath the seat.  For those of you in the market for a metal seat, I encourage you to contact Ian.  Not only is he a cool guy with great ideas, he also does a first rate job (and relatively quickly too).  I'm hoping to have the seat complete when he gets back from vacation at the beginning of the year so mock-up can be finished.
Offline BPellerine
« Reply #29 on: December 23, 2013, 06:26:34 PM »
that tank is gorgeous!man you are going to have a showbike when you are done!bill
1978 CB 750K ard and webers
another anfob
« Reply #30 on: December 23, 2013, 11:42:02 PM »
Thanks, Bill.  Whereas my K7 is more show, this K2 build is all go.  The emphasis is for the bike to have enough performance (handling, power and braking) to spare.  The engine should produce somewhere above 80 bhp.
I think that the aluminum tank and seat will be the jewel or highlight of the bike, since they are one-off and unique from production pieces out there, but my inclination is to give the aluminum a uniform brushed finished, with maybe a off-side black racing stripe and some sort of clear coat (maybe satin).
« Last Edit: December 24, 2013, 07:19:13 AM by CB750 Cafe Racer Fan »
« Reply #31 on: December 23, 2013, 11:47:39 PM »
Okay, for all of you too young to know where the term "bionic" comes from, here's the cultural reference:
http://youtu.be/HoLs0V8T5AA
"Gentlemen, we can rebuild him, we have the technology. . . . Better, stronger, faster!"
Of course, this build is NOT going to run $6M!
« Last Edit: December 23, 2013, 11:55:15 PM by CB750 Cafe Racer Fan »
Offline BPellerine
« Reply #32 on: December 24, 2013, 09:38:11 AM »
maybe a version of the ko striping?the tank shape looks right.bill
another anfob
Offline KrautKoffin
« Reply #33 on: December 24, 2013, 12:16:52 PM »
Scribed!
74 cb550
I now have Beastie Boys "Sabotage" stuck in my head after seeing your avatar.
« Reply #34 on: December 27, 2013, 11:44:28 PM »
Another trick bit I am looking to include into this build is an oil tank/fender to replace the stock oil tank reservoir.  The tank/fender will mount in place of the inner fender and allow the triangle under the seat to remain open.
Ian Halcott (http://caferacerseatandtank.com/) sent me some pictures of one he previously made:
« Reply #35 on: January 06, 2014, 10:50:17 AM »
I just picked out the color for the powdercoating on the engine cases.  I'm going with a darker/medium gray cast aluminum color for the cases and valve cover, with the cylinders and head to be painted black, and black billett Joker covers for the alternator, clutch, points, starter, and tappets.
I'm leaning toward using a single bold racing stripe (or a bold combined with a thin stripe) offset on the tank and seat -- to be overlayed on the brushed finish -- and then clear coated.  Waiting for the aluminum seat and oil tank to finish mock up.
« Reply #36 on: January 12, 2014, 05:38:21 PM »
Just got these robust billet engine mounts from Frank aka 754 for the build.  Bike porn!!  THANKS, FRANK!!  Awesome work.  He made some similar mounts for Dave Hiller aka Doctor D for his CB750F:
Offline BPellerine
« Reply #37 on: January 12, 2014, 05:47:15 PM »
the mounts look really neat up close!bill
another anfob
« Reply #38 on: January 12, 2014, 07:55:46 PM »
I stopped by the CMR shop in the fall and Denis showed me what the plan for your tank was. I didn't realize it was for someone here, it looks great. Denis & Byron did some fine frame work for me, plus built a tank as well.
You mentioned swingarms, they built one for me last year and it's very tidy piece. Tell him I sent you back!!
« Reply #39 on: January 12, 2014, 08:20:50 PM »
Denis and Byron did an amazing job on the tank and WOW what a swingarm!!
« Reply #40 on: January 12, 2014, 08:53:33 PM »
If you don't mind me asking, how much for the arm Brent..?
« Reply #41 on: January 12, 2014, 09:10:55 PM »
I must admit that I am curious as well.
Offline KrautKoffin
« Reply #42 on: January 12, 2014, 10:57:50 PM »
I'm guessing his first born.
74 cb550
« Reply #43 on: January 13, 2014, 05:23:59 AM »
It was under eight bills Cdn including tapered rollers and both axles, a year ago.
Here's my stock frame upgrade compared to the stocker. I wanted the entire pressed steel backbone/headstock replaced, plus increased rake. They're good at their jobs, great craftmanship and are very thorough. Denis builds & ships race frames around the world, many to Aus. Mick.
Sorry to drift off topic.
« Last Edit: January 13, 2014, 10:38:08 AM by bwaller »
Offline snowman
« Reply #44 on: January 13, 2014, 09:53:42 AM »
If you're interested, I have an aluminum seat that I won't be using. Changed the style/look that I am doing for my build.
« Reply #45 on: January 13, 2014, 11:49:02 AM »
Thanks Brent, great mods on the frame.... ;)
« Reply #46 on: January 13, 2014, 12:23:11 PM »
Brent,
The frame looks great -- much more rigid than a stock 550's pressed backbone.  The bracing and gusseting on the frame is first-rate.  I wish I had that kind of extra budget for a CMR swingarm.  What a stellar piece of hardware.  I think I'll have to make due with my Dresda knock-off replica.
Offline InAquaVeritas
« Reply #47 on: January 13, 2014, 12:39:44 PM »
This is starting to look like something insane! Really keen to see the finished result! Def will be following this!
Surf bum trying his hand at wrenching!
Past "bikes" ;)
1981 Honda MT 50cc - Torn apart, put back together and got run down on..
1994 Derby Senda R 50cc - Fell apart
2001 Derby Senda R 50cc - 13/45 changed to 15/70, hit 90 kph in under 150 meters! Undriveable fun!
1987 Suzuki GN250 - Sold
1977 Honda CB750 F1 - F2 engine, '05 ZX6R front end and wheels, '04 ZX6R shortened swing arm converted to twin shock. http://forums.sohc4.net/index.php?topic=133411.0
1987 Honda XR600 Supermoto conversion. CR250 forks and triple. SM wheels, discs front and back. Rebuilt engine. Loudest exhaust in the world: Leovinci X3
« Reply #48 on: January 14, 2014, 04:54:32 PM »
As soon as I get the aluminum seat from Ian Halcott, the mock-up can be completed.  I need to determine what length shocks to use in connection with the CBR600RR forks to achieve the best handling.
As stated above, I am leaning heavily in favor of Morris-style 18" wheels front and rear, with a disc conversion to the rear.  I might even consider going to 17" wheels to have a full range of sport tire rubber available.
One of the challenges is that the CBR600RR front brake calipers do not appear to have sufficient clearance for spokes.
Even if I remove some material from the monoblock calipers (on the inside), I still believe there will be clearance problems for the spokes.  I'm looking into having Morris-style wheels adapted from RSD or another manufacterer.  If necessary, I can switch to a narrower caliper to gain some additional clearance.
« Reply #49 on: January 14, 2014, 04:55:42 PM »
Frank does some nice work!
