Author Topic: Propane powered 750?  (Read 1694 times)
Offline lone*X
« on: December 20, 2013, 09:08:42 AM »
Found an interesting short video of SOHC 750 running on propane.   He has a ways to go but its a start.  Making a tank for propane is going to be tricky.
https://www.youtube.com/watch?feature=player_detailpage&v=cAKhiZ2gpIU
« Last Edit: December 20, 2013, 09:47:39 AM by lone*X »
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
Re: Propane powered 750?
« Reply #1 on: December 20, 2013, 09:20:27 AM »
I like it. 8)
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: December 20, 2013, 09:25:43 AM »
Interesting little engineering exercise but I have to wonder about the safety of propane (tank, lines, etc.) and how you would protect them well enough should you have an accident on the bike..  heaven forbid.  ???
Offline fdbrat
« Reply #3 on: December 20, 2013, 09:43:45 AM »
Rad!
1975 CB750F
4-4, Dyna S and box
5 ohm coils / 5k ohm caps
In- .05 / Ex- .08
San Luis Obispo
« Reply #4 on: December 20, 2013, 11:57:54 AM »
 Sounds, well it makes sounds.
Offline vrm
« Reply #5 on: December 20, 2013, 07:33:34 PM »
Gasoline isn't that safe either.
Ride it like you stole it from your ex-wife's new husband.
Iron Butt Association membership number 49866.
Offline bjbuchanan
« Reply #6 on: December 20, 2013, 08:32:31 PM »
Propane is used in other applications guys, branch out. Truck guys run propane. Propane powered gas grills sure seem safe to people...
Offline brewsky
« Reply #7 on: December 21, 2013, 01:22:55 AM »
How about burning grease dropping on the rubber supply hose under the grill? And I thought everything was going fine till the grilled burgers started to smell like burning rubber!
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline K3Owner
« Reply #8 on: December 21, 2013, 04:42:58 AM »
High pressure gas is just fine when the tank is protected from accidents. Leave it to UPS and big buses. No matter what - you can't protect yourself on a bike from it. The tank as it is can fly away and has a valve to keep the fuel from spraying. If you want the same with pressurized gas, it will be thick metal and heavy like any other tank and you'll have to take care to be sure that the valve is 'approved' as these things have regulation in some countries. Like sitting over a bomb. Not to forget mention that the weight raises the center of gravity dramatically.
That's just me - great engineering exercise and exciting to do - to get it to idle and accelerate and cruise perfectly. Not my cup of tea but fine in my old 70s Oldsmobile  ;)
1978 CB550K4 - yeah, I'm not a K3 Owner - my bad
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #9 on: December 21, 2013, 07:05:15 AM »
Well aware of propane powered four-wheelers, but those fuel systems are far better protected in these applications. As for gasoline being not much safer, sure is. It's not stored in a pressurized container and it doesn't explosively and instantly vaporize if the pressure is released. And few barbecue grills travel down the road at 75 mph.
Offline bjbuchanan
« Reply #10 on: December 21, 2013, 09:20:41 AM »
I just mean don't just say it doesn't sound safe for no reason. Practically speaking on a motorcycle, forget that, I think its hung out a little too much. Should have said more before
Offline tlbranth
« Reply #11 on: December 21, 2013, 10:16:43 AM »
Check bike of the month (only good through December)
http://www.ngwclub.com/
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #12 on: December 21, 2013, 10:26:57 AM »
Whoa! Not the most attractive, but I bet it was a fun project.  ;) It brought to mind this scene from Dr. Strangelove...
« Last Edit: December 21, 2013, 11:15:10 AM by Bob Wessner »
