Author Topic: 1157 LED Bulb — yes I searched  (Read 3381 times)
Offline SKTP
« on: December 20, 2013, 01:47:38 PM »
$30 seems like a lot for a bulb...but I am OK with it, if it is REALLY bright and makes me more visible
I have an LED taillight bulb right now (around 9 bucks from Autozone), but it is fairly dim. Especially the difference between REGULAR and BRAKE-ON
Does anybody actually have this bulb?
http://www.superbrightleds.com/moreinfo/s-series-bulbs/1157-led-bulb--dual-intensity-36-high-power-leds/1689/
If so, are you happy with it?
Thanks
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Re: 1157 LED Bulb — yes I searched
« Reply #1 on: December 20, 2013, 01:52:42 PM »
Offline Powderman
« Reply #2 on: December 20, 2013, 02:06:14 PM »
this one has twice the lumens...
http://www.superbrightleds.com/moreinfo/s-series-bulbs/1157-led-bulb--dual-intensity-28-high-power-led-/1644/3767/
be sure to buy red...
I don't see an option for red in that listing. Why would you need a red bulb if it is housed in a red lensed housing?
Offline SKTP
« Reply #3 on: December 20, 2013, 02:07:48 PM »
That one is only in "Cool White".
Shouldn't that be OK since the taillight plastic is RED and regular bulbs are white?
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #4 on: December 20, 2013, 02:14:43 PM »
Nah, with LEDS the bulb color should match the cover color.
« Reply #5 on: December 20, 2013, 02:17:24 PM »
"For best results the LED color should be the same as the lens color or if bulb is behind a clear lens, use the appropriate color for turn and brake light functions. As an example: a red lens will filter out all but the red portion of the light so if the light is all red, none or very little light will be blocked by the lens. The light from a White LED contains very little light in the red portion of the visible spectrum so most of the light would be filtered out by a red lens"
http://www.superbrightleds.com/carbulb_notes.php
Offline SKTP
« Reply #6 on: December 20, 2013, 02:19:59 PM »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline Garage_guy_chris
« Reply #7 on: December 20, 2013, 09:16:02 PM »
If you use a red bulb in the tail light your not gonna have a clear licence plate light it will be red, Use a clear one. this is one of the mods im planning too
Offline fdbrat
« Reply #8 on: December 20, 2013, 11:47:56 PM »
Should I start popping the popcorn?
1975 CB750F
4-4, Dyna S and box
5 ohm coils / 5k ohm caps
In- .05 / Ex- .08
San Luis Obispo
« Reply #9 on: December 21, 2013, 08:18:37 AM »
His plate is not mounted under his tail light.
It's a little more important to be seen by he cagers behind you.
Stick with red for the tail/brake light.
Add led license plate bolts if you want plate illumination.
« Last Edit: December 21, 2013, 08:21:01 AM by flybox1 »
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #10 on: December 21, 2013, 11:55:47 AM »
+1  This total makes sense!
Take the advise from Superbrightleds and get a red one.
Check BrandEn's build for the build I just received.
http://forums.sohc4.net/index.php?topic=103818.575
Offline SKTP
« Reply #11 on: December 21, 2013, 12:12:56 PM »
Thanks! Ordering now...
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline SKTP
« Reply #12 on: January 06, 2014, 10:27:39 AM »
Put this one in the bike over the weekend. Very Happy. I feel like an idiot for driving around with my old cheap Autozone LED bulb
Old LED bulb (running) (it was like $10 for a 2 pack.)
NEW SUPERBRIGHTLED (running)
NEW SUPERBRIGHTLED (brake)
Huge improvement...it is SO BRIGHT  :)
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #13 on: January 06, 2014, 10:34:17 AM »
yeah...thats good visability!
« Reply #14 on: January 06, 2014, 10:51:39 AM »
 Good job. I've got a pair of those autozone bulbs too. Not worth the trouble.
