Author Topic: fmctm1sw '83 GL650 Interstate  (Read 17636 times)
Offline fmctm1sw
Re: fmctm1sw '83 GL650 Interstate
« Reply #75 on: August 17, 2014, 04:30:04 PM »
I figured the best way to work the cranking issue was to try to isolate as much as I could.  I figured it would be pretty easy to isolate the top end from the bottom end.  Right under the valve cover are the four bolts that hold the head on.  Those bolts also hold the rocker assemblies.  I just took the 4 bolts out of each head, lifted up the rocker assemblies, took out the pushrods and tightened the heads back down.
I started with no plugs in it and it cranked over much like it did before.  Next I put plugs in it an lo and behold it cranked over fine.  Not only that, the oil pressure built up as evidenced by the oil light going out.  Some more cranking and I saw oil flow at the heads/rockers.
So with the valve train disconnected, it seems to work fine.  Now all I have to do is figure out how to make it run on only a compression and power stroke   ::) ::)  The valve train is pretty heavy duty.  There's 4 valves per cylinder and the valve springs are doubled.
That's where I'll have to leave it for next weekend.
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fmctm1sw
« Reply #76 on: October 18, 2014, 05:49:44 PM »
I decided after I got back from Barber's that I was going to start this thing or die trying.  I put the pushrods back in and bought a battery.  I even bought another motor off a guy up there in Moody while I was up there.  In the case I did something wrong during the rebuild, I'd have a whole 'nother motor to work with.  The game plan was to defeat the starter safety switch and help it along by pushing it while I hit the starter button.
Of course I'd find it leaking antifreeze but I think I have that under control.  One of the tubes from the thermostat to the cylinder head is chewed up so I'm trying to epoxy it smooth.  Tomorrow I'll smooth it up and get it back on.
So I got my battery today and after all that angst, the damn thing started right up when that battery was put in it.  I figure my jumper cables weren't making a tight enough connection.  It never had a battery, just my jumper cables clamped to the + and - leads.  I guess it wasn't enough.  It's a real lesson learned for me and  now I have a CX650 motor that I won't be using.
I'm working on getting the exhaust back on it and cleaned up now.  I'm not sure I bought new float bowl gaskets either so I may need to do that, one was leaking.  But yeah... started right up.   :)
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Mcwilliams570
« Reply #77 on: October 18, 2014, 05:55:59 PM »
Awesome man good to hear you got it going I know it was bugging the hell out of you. Now about that 650 motor you wont be using :)
Matt
My CB550 project http://forums.sohc4.net/index.php?topic=101182.0
Project UFB Cb550 http://forums.sohc4.net/index.php?topic=112143.0
Like a 10 dollar hooker on Friday night its going to be ridden.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline fmctm1sw
« Reply #78 on: October 18, 2014, 06:48:37 PM »
Matt
That ain't the half of it.  I even bought a GL650 output shaft for it.  According to the CX/GL compatibility document, that's the only difference between the CX and GL 650 motor so I went ahead and bought one so I wouldn't have to take mine apart to use it.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline grcamna2
« Reply #79 on: October 18, 2014, 07:40:18 PM »
That's GREAT news sir !  ;D That was a Lot of trouble to go through;it would have been tougher w/o anybody else to get  feedback from either  ::) I was pulling for you the whole time man and I'm glad you can finally take a 'Victory lap' around the garage once you get'er all buttoned up  :D ;)
Offline fmctm1sw
« Reply #80 on: October 19, 2014, 04:59:53 PM »
I actually rode it to the end of the block and back a few times.  Now I can start looking for the little things may not be right.
I noticed another antifreeze leak.  This time from the other tube from the thermostat to the left cylinder head.  The valves seem a little noisy on the left side so I'll check the tappet clearance again.  The speedo doesn't work and the temperature gauge doesn't either.  I noticed the fan does kick on though.
It shifts perfectly smooth but I'm wondering if those longer clutch springs are going to be necessary, the handle is really easy to pull in and it seems like it slips in third gear.  The battery is definitely charging too and I synced the carbs.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fmctm1sw
« Reply #81 on: October 25, 2014, 12:32:10 PM »
One thing I noticed is that it made way more racket than my CX500 did.  I figured I needed to adjust the tappets.  Adjust them?  No...  How about put them back in after they shook out.  I must have not tightened them down real good when I adjusted them.  The bike is much quieter now, just like my old CX.
I worked on the other water pipe and there are no more leaks from up there but I still had a spot form underneath it.  It's coming from way in the front so I took the radiator off and there was no coolant anywhere on the motor so I'm guessing my radiator is toast.  So I'm off today to find a radiator tester to make sure.
I rode it around a while before I took the radiator off.  Apparently I'm missing a 7VDC regulator these bikes used for the temperature gauge too.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline grcamna2
« Reply #82 on: October 25, 2014, 01:32:27 PM »
You're really working through a lot of stuff with this one  :o ! I'm glad to hear you tightened the tappets back up. The radiators in them are all brass,right ?
Offline fmctm1sw
« Reply #83 on: October 25, 2014, 09:18:55 PM »
Yeah, this has been a real PITA for sure.  I rented a pressure tester from Autozone and can't seem to find any leaks in my radiator.  I put it in my sink and submerged it.  I have a post on the CX forum about it.  I should be able to solder it...  if I can find any leaks.  Maybe I'm just not looking hard enough on the bike.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline grcamna2
« Reply #84 on: October 26, 2014, 05:51:54 AM »
Well,after doing this one you should be able to handle Any motorcycle repair  ;)  8)
Good Work  :)
Offline fmctm1sw
« Reply #85 on: November 02, 2014, 01:51:50 PM »
The brakes were dragging pretty bad.  I hoped bleeding them real good would help but with this bike of course it wouldn't.  I realized dual caliper brakes are a PITA, especially when there's dual pistons.  It took some wrangling to get the pistons out.  They have to come out at the same time and then I had to get creative to block the left brake line while I worked on the other side.  I pulled it off with a penny, a washer and an inner tube clamped with a pair of vice grips.
You can see in the picture one was really gunked up.  There was an o-ring of some sort smashed in there too  ???  The caliper seals and the dist seals appear to be available so I'll get new ones.  The pistons themselves didn't look too bad after some cleaning.
I also changed out the clutch springs with the longer ones that came with a clutch basket I ordered.  I'm sure I had the right springs in it but the clutch slipped.  It was especially bad with the dragging brakes.  I rode a few rounds to the end of the street and it goes pretty good now.  Then I had to pull the clutch cover back off since the gasket wasn't put on right and it leaked oil.    ::)
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fmctm1sw
« Reply #86 on: November 02, 2014, 07:13:57 PM »
The speedometer gear was chewed up.  The gear was plastic in this bike but still available thankfully.  It looks like I'm missing a dust seal and a washer too.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fmctm1sw
« Reply #87 on: November 15, 2014, 10:41:13 AM »
It's fast approaching the time to put this on the road.  I got all my brake parts and rebuilt the calipers last night.  This morning, I resolved an issue with the temperature gauge.  They had a 7VDC regulator in these bikes that powered the gauge.  Initially I thought I was missing the regulator but I found it in the harness box behind the fairing.  Everything was fine on that end, it turned out to be a really corroded wire from the sensor itself.
Lights and signals are good all around now and I ordered an electronic speedometer sensor last night based on trueblue's nice electronic gauge thread.  Once I pick out a speedo from speedhut, I'll have that resolved AND have an odometer set at 0.  That's a nice touch for a completely rebuilt motor with many NOS parts in it.
I never did pinpoint the radiator leak but after I changed the radiator hose form the thermostat to the top of the radiator, I haven't seen any drops.
Now it's just a matter of body parts.  I bought Honda silver paint that is very close but not perfect.  A couple bolts for the seat and rear cowl and that will wrap it up.  I rode it and it runs great, shifts perfectly.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline grcamna2
« Reply #88 on: November 15, 2014, 12:48:39 PM »
That is a Nice GL650 you've got there  :)  ;) 8)
 I had the GL500 Silverwing and it had a tailtrunk that I could swap out for the passenger seat which had a backrest that came in quite handy on those long rides. Does the GL650 have one ?
Offline fmctm1sw
« Reply #89 on: November 15, 2014, 03:33:14 PM »
The 650s came with the same thing.  Matter of fact I think the GL500 stuff fits but the bike didn't come with either.  I've found a seat cheap off ebay so that's what I went with.  I looked around at Barber's for Silverwing stuff but I didn't see anything.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fmctm1sw
« Reply #90 on: November 22, 2014, 09:15:42 PM »
I scored a couple of decent side covers off ebay and registered and insured it the other day.  It's officially road legal.  The tank is going to be painted with Nimbus Gray Metallic I got on ebay but it slightly different than the nimbus gray that the bike came with.  The rear seat cowl is painted that color too.  I'm chomping at the bit to ride it but my speedo is going to be another week or two...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline grcamna2
« Reply #91 on: November 22, 2014, 10:07:44 PM »
Nice  ;) 8) I hope after ALL that TLC restoration work you put into it that you take it on many long tours and really enjoy the sh*% out of it for years to come  :)
What part of FL. do you live?(I'm now doing long range planning to move there as soon as I can) Did you used to live in Johnstown,PA. ?
Offline fmctm1sw
« Reply #92 on: November 23, 2014, 07:44:28 AM »
yeah, I was born in Johnstown and joined the military right after high school.  We've lived on the Florida panhandle (Pensacola) since 2006 now.  If you plan on coming to this area, let me know.   can't wait to ride it, I need to look at that break in thread again.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline grcamna2
« Reply #93 on: November 23, 2014, 05:29:10 PM »
I was considering the East coast,Ormond Beach around there.
Offline MoMo
  • Ride like you're invisible
« Reply #94 on: November 23, 2014, 06:51:00 PM »
Was stationed at Eglin for 4 years back in the (when?? so long ago I forgot),  nice area but most of the locals sure hated servicemen back in the Viet Nam era...Larry
Offline fmctm1sw
« Reply #95 on: November 26, 2014, 09:15:25 AM »
Larry,
Times have sure changed.  The gulf coast is definitely military friendly these days.  It's a shame that guys were treated the way they were back in the Vietnam era.  I've never been treated with anything but respect (in the USA) and I'm thankful for it.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fmctm1sw
« Reply #96 on: November 28, 2014, 03:37:50 PM »
I got tired of waiting on my speedo, I just had to ride this thing.  I decided to do a break in today and pretty much followed what is discussed here:  http://www.mototuneusa.com/break_in_secrets.htm  My odometer ended up biting the dust along with the speedo which had already gone but I know I did at least 20 miles.  The tach is no good either.  It was bouncing between 4000 and 7000 RPMs most of the ride but the temp gauge works.
I changed the oil right after I got back.  Nothing major noted.  I adjusted the clutch, and that was it....
Oh, I painted the tank last night.  The color is a shade different but it's close.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline grcamna2
« Reply #97 on: November 28, 2014, 04:43:03 PM »
You sure are doing a FULL Resto on this bike Matt  ;) 8)
Offline fmctm1sw
« Reply #98 on: November 28, 2014, 05:44:04 PM »
I didn't have a choice.  Nothing worked!   ;D
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline grcamna2
« Reply #99 on: November 28, 2014, 07:16:38 PM »
and if it wasn't for you nothing would have ! you saved that one from the 'crusher'  8)  Good job guy  :)
