Author Topic: Low Buck 750 Cylinder Head Project  (Read 25215 times)
Offline TurboD
Re: Low Buck 750 Cylinder Head Project
« Reply #100 on: January 06, 2014, 02:02:50 PM »
I got the chance today to work on the intake a little more, I mainly worked around the guide area. I thinned and streamlined the guide a little more, I did not reduce the length. I also very slightly took more material from the roof on both sides of the guide area. This little additional work helped to bring the numbers up more, I'm sure that with even more work in this area the numbers should continue to increase some.
Here is progress so far.
Flow CFM @ 10 Inches
          Before     Basic Clean   Light Reshape   Latest work
.100    24.7              24.7              25.0                    25.1
.200    46.1              46.2              46.8                    47.0
.300    52.1              56.6              58.4                    59.2
.400    54.3              57.7              60.0                    61.5
.500    55.1              57.9              60.1                    62.0
« Last Edit: January 06, 2014, 02:19:40 PM by TurboD »
Offline EnginebyAdam
« Reply #101 on: January 06, 2014, 03:05:28 PM »
With the guide reshape, did you basically taper it by hand? If so how much guide thickness did you leave at the tip of the taper?
Better Rodded Than Rotten
Offline TurboD
« Reply #102 on: January 06, 2014, 05:43:49 PM »
Yes it was by hand, I slightly tapered the guide and then put a small radius on the end. I would say the tip is still half thickness, nothing to radical.
Offline dragracer
  • CB750F Dragbike
« Reply #103 on: January 06, 2014, 06:21:00 PM »
Great tutorial with good numbers. Still above my pay grade- lol. I'll leave the porting to you guys and do what i do best and thats  building the motor from the parts and pieces the experts prepare for me to the best of their ability.
Thanks for sharing this venture with the forum. We do appreciate knowing how each change brings about increased flow.
Offline dusterdude
« Reply #104 on: January 07, 2014, 09:39:47 AM »
Do what you do best?i thought gladys was the engine builder?
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline johno
« Reply #105 on: January 07, 2014, 01:13:46 PM »
Turbo,
time for the simplest thing of all, 3 angle valve seat and back cut valve, lets see what happens to the low lifts ;)
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
« Reply #106 on: January 07, 2014, 02:24:09 PM »
Turbo,
I'd bore that seat/throat too.....the F2 head can definitely use it.
Offline dragracer
  • CB750F Dragbike
« Reply #107 on: January 07, 2014, 08:21:28 PM »
Damn, you would give up the truth. Some friend you are-lol.
Offline johno
« Reply #108 on: January 08, 2014, 04:01:29 AM »
just in case your not sure what I meant .......30 deg back cut from 45 seat edge
In conjunction with a 3 angled seat it forms a nice venturi which maximises  the flow past the seat
Turbo try this first then bore to .9 ( as per Mike) and do again , it will surprise everyone I'm sure.
ciao johno
Offline johno
« Reply #109 on: January 08, 2014, 04:04:08 AM »
3 angled valve seat the other half of the venturi effect
Offline turboguzzi
« Reply #110 on: January 08, 2014, 09:24:11 AM »
interesting discussion indeed... kevin cameron, who's been tech inspector in AMA and peeked into plenty of works motors wrote once that he saw everything, from full blended, through 3or 5 angle to even "single angle" (just a 45 cut) seats on the podium at the end of races....
Johno, I like your approach. dont know if this story is true, but some say that john britten developed his ports simply building them up from the valve seat with plasticine while running them constantly on the flow bench and going with the path of least restriction.
If i had the time, i'd build a mock head out of silicone and check any porting changes there before doing anything on the real one. toyed with the idea of building a flow bench once, but realized i better build running bikes i can race  rather than fine flowing heads that sit on a bench with the time i have!
BTW, this is the only way to really know how your ports look IMHO.... your finger is NOT a 3D scanner :)
http://forums.sohc4.net/index.php?topic=82510.msg928138#msg928138
« Last Edit: January 08, 2014, 09:26:46 AM by turboguzzi »
« Reply #111 on: January 08, 2014, 11:45:40 AM »
Anyone have a 3D printer to play with?
Offline turboguzzi
« Reply #112 on: January 08, 2014, 01:22:19 PM »
i do have an Objet 3D printer at work, but not the time to do the 3D modeling :(
That said, 3D printers have become such a commodity these days that you'd be surprised how cheap outsourcing the service is.  some engine developing companies use 3D prints directly as lost cores for castings.
Offline TurboD
« Reply #113 on: January 13, 2014, 07:31:47 AM »
Johno I am working on getting a 6.5mm pilot, of all the ones I have, I don't have the one I need.
For the time being, I have just about put all of the time into this head that I can. I still have the entire bike to build before spring, This one came home in boxes (to the point that I picked it up in my car). I am also in the middle of a Kawasaki Turbo build that I have fallen a little behind on. Possibly in the future (if time allows) I will take another head and pickup where I left off on this one.
Offline vbtravisd
« Reply #114 on: March 06, 2014, 06:34:47 AM »
Great thread man... it has inspired me to at least clean up the casting while I have my motor apart.  Probably wont take it as far as you have... but it will help a bit im sure.  I've done my fair share of sbc and bbc head porting... so im not totally new to the game.  Thanks for the info and pics man.
Offline TurboD
« Reply #115 on: March 06, 2014, 08:20:25 AM »
Thanks. My goal was to be helpful and give guys a little push on their own projects. Be it Sbc/BBC or SOHC, the basics are all the same, apply what you know and you'll be fine.
The first few steps is where the "biggest bang for the buck" are, after that the steps forward are more labor intense and costly.
Offline 01Thomas
« Reply #116 on: March 06, 2014, 01:31:23 PM »
Hi
I've tried going to this site but Norton's antivirus keeps on giving ma a malware warning. Has anybody else had the same experience?
regards
Thomas
Wow, port-shaping deja vu!
http://cb750k2.honda4.nl/Technical/porting/Porting_the_Honda_Head.htm
My book:
Chapter VI, pages A-9 thru A-15 .
SNIP
1971 Honda CB750 Four K1 [Engine: CB750E-1113521 / Frame: CB750-1113838]
1977 Seeley Honda CB750F (F1) [Engine: CB750E-2551214 / Frame No: SH7-655F]
'96 Yamaha YZF750SP & '81 Moto Guzzi SP1000 & '80 Moto Guzzi 850 LeMans II & '82 Bimota KB-3 [Frame No 49] & '66 Ducati 50 SL/1 & '53 Miele K-50 & '38 Miele 98
Offline FuZZie
« Reply #117 on: March 06, 2014, 01:46:51 PM »
The code on that page looks clean at this time Thomas
BUT I've only checked that one page, you should be fine but don't go elsewhere on the domain like I said I've checked one page!
Offline 01Thomas
« Reply #118 on: March 07, 2014, 11:00:04 AM »
Thank You! It went through this time without a hitch.
Offline DannyBhoy
  • Old and Slow
« Reply #119 on: March 22, 2014, 06:03:51 AM »
Many thanks to turbo for spending his time on this. It has been a great help. He kept to the basics, then slowly added more info and options. For most of you it was old news but for some it was perfect to give confidence to tackle basic performance mods.
For 5+ yrs I have be on again off again with months passing and not having the time, money or drive to push on.
I can honestly say that I have worked on the old girl every day for over a month and finally see some at the end of the tunnel.
Thanks again turbo and the rest of you who share your thoughts and ideas.
Cheers
Offline TurboD
« Reply #120 on: March 25, 2014, 07:33:48 AM »
Your welcome, happy be of help. :)
Offline hotdog
« Reply #121 on: March 07, 2015, 11:16:59 PM »
Johno - what book is that..?
Instagram - LUMPY CAM MOTORCYCLES
FB - LUMPY CAM Motorcycles
Offline scunny
  • don't call me expert
« Reply #122 on: March 09, 2015, 09:46:30 AM »
John Britten experimented with 4, 5 and 6 valve heads, have some crappy photos I took that I shall try and find.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline scunny
« Reply #123 on: March 12, 2015, 01:18:41 PM »
found them
4 and 5 valve heads
6 valve blank
« Last Edit: March 12, 2015, 01:20:24 PM by scunny »
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
