Ok,
Got some work out of the way…
I was able to easily remove the Choke Butterfly from that old, dingy, corroded #3 and installed it on my new one.
Turned out to be very straightforward. I took a spare #1 Phillips that probably came as an installation tool for some kind of product – I have 2 matching ones, so I am assuming some sort of furniture. I checks its fit on the JIS screws and found it pretty good. To make sure, I filed down the tip so it was not so deep, and then it fit really good. A little bit of rotational pressure, and the screws came right out with no fuss.
I then removed the nut, washer and connector from the axle and slid the whole thing out.
I then put them into a small vibratory tumbler for a few hours to clean off some of the corrosion. And reassembled onto the good carb body. Following advice from the Forum, I put the screws in loosely, and worked the action of the butterfly before tightening fully. The result is a nice smooth action.
Speaking of the Vibratory Tumbler… I owe you guys some pics of my results. Here are some shots of various bolts and also the intake manifolds. All of this was the result of using Eastwood’s Dri-Shinell media with some Happich’s Simichrome added in. Times range from a half day to several days, depending on how fast I got the desired results.
It takes some time, but the results are great, and the process is totally safe and clean.
Next it was onto removing my Cam Shafts and Rockers from the head:
Again, following advice from the forum, 2 major points to follow:
1. Keep the components the same! i.e. the #1 Exhaust Rocker goes back as the #1 Exhaust Rocker on reassembly. The #1 & #2 Exhaust Cam Shaft must remain the #1 & #2 Cam Shaft on reassembly. Otherwise, your parts will have to spall which can lead to excessive wear and tear or even worse, failure. So keep very organized during this disassembly.
2. Protect the Cam Shaft Cotter Pins – they are not available!!!
So here goes…
First I labeled everything. On the CB550F, the exhaust side of the head is flat in the middle, whereas the intake side has an angle. So I labeled the head front and back (on retrospect, I should have named it Exhaust and Intake, but I digress….)
I then labeled all the Rockers as well. After my CB450 Project, I have a ton of Glad Freezer bags as well as small plastic bags from Western Hills Honda Orders. I will use them to excess to keep this build organized!
I then took a 6mm nut and put it on the cotter so it sat just proud of the top of the cotter. This is to protect the threads of the cotter.
I then used a 5/16 punch and hammer to tap out the cotter pin. I was careful, but had to use some force here.
And it came out with no drama.
I them went to pull the Cam Shaft in order to remove the rockers. At first I did not realize that they were tapped on the open end for a 6mm bolt (one from your engine case will do just fine…) so I struggled a bit to get the first two out. Once I realized that the shafts are tapped, it was breeze to remove the other 2!
Here is where the cotter pin lives…
Ahhh – so much easier when done correctly!
A nice empty head (much like mine…) ready for vaporblast
Everything in its place awaiting a quick clean and lube before reassembly
These are then put in the big Bag labeled #1 & #2 Exhaust which contains the appropriate Cam Shaft and Cotter Pin. I have the Washers and Nuts for the Cotters tied together with a zip tie as I polished them in the tumbler.
I then wanted to move back to the carbs. Since I now have a really nice working set, I wanted to really clean them up. I took the old corroded #3 as a guinea pig and put it into my 18lb Vibratory Tumbler. At first I used Harbor Freight’s Abrasive Ceramic Polishing Media
with a bit of all purpose wheel cleaner and water. Not a good idea – the abrasives break down and get stuck in the larger orifices of the Carb. So I cleaned out the tumbler bowl and used the Dri-Shinell and mixed in a some Walnut Shells as I wanted to make sure the Carb was covered completely in the bowl. I let this go for about 4 hours, mixing in a bit of the Simi-chrome here and there. We have success!!!
So encouraged, I put Carbs one and two in and left them overnight and most of the next day. They still need another day or two, but I am not up at the garage, so they will have to wait until this weekend. But here are the results so far.
That said, when they are done, I will run them a few cycles in the Ultrasonic cleaner to make sure that the polishing media is cleaned from the all the orifices, and them hit them with brake cleaner and compressed air for certainty.
These are some quick pics with my phone. When you see the third carb in the pic, that is the REALLY clean #3 that I got from Harisuluv for reference – and it looks old and cruddy next to the others.
Next up, the Exhaust and then the Engine have to come off. The Cases will be PC’d Aluminum Gray from Powder by the Pound and the Cylinder, Head and Head Cover will be sent out for Vaporblast. The Breather cover will be polished on my wheel as it has a bunch of blemishes that need to be worked out. All the engine internals will be cleaned, and I will give her a valve job upon reassembly.
I will of course post pics as I go along!
Thanks for watching!
Gersh
