Author Topic: Brake Preservative?  (Read 904 times)
Offline krusty
Brake Preservative?
« on: December 27, 2013, 11:02:49 AM »
I'll be rebuilding a couple of brake master cylinders for my Colleda 250TAs. It may be a while before I need to instal them so I was wondering if I need to use a preservative to prevent any corrosion and. if so, what should I use.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline jerry h
Re: Brake Preservative?
« Reply #1 on: December 29, 2013, 08:25:56 PM »
If you can find it locally    Raybestos Brake Assembly Lube    BAF-12   or similar type product.
http://www.summitracing.com/parts/agb-baf12
Offline krusty
« Reply #2 on: December 30, 2013, 02:53:12 AM »
Thanks jerry h. So I'm looking for 'Brake Assembly Lubricant'. I can't find a Raybestos supplier locally. I came across a product by Permatex who have have an outlet close by so I'll check them out.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline calj737
  • I refuse...
« Reply #3 on: December 30, 2013, 03:41:06 AM »
Fill the reservoir with fluid, pump some thru the MC, refill reservoir, and store. The damage to MCs come when they "dry" up with dirty old fluid.
Offline 78 k550
« Reply #4 on: December 30, 2013, 08:37:31 PM »
little fluid and a ziplock bag.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
