Author Topic: CB450 DOHC info?  (Read 2651 times)
VTCMart
CB450 DOHC info?
« on: September 03, 2006, 07:39:10 PM »
There is one for sale around me I was thinking about getting.  I know this site is dedicated to the SOHC CB's but does anybody have any opinions on the DOHC CB450?  It is a '72 model.  Thanks.
Offline Pinhead
  • 1979 CB652-ST
Re: CB450 DOHC info?
« Reply #1 on: September 03, 2006, 08:04:08 PM »
Honda made DOHC's in '72? That's new to me...
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #2 on: September 03, 2006, 08:26:47 PM »
they sure did. the 450 twin was a bit ahead of the game in a lot of ways. as i understand it, it had a bit of honda's 1960's racing legacy behind it, much like the 750 did when it came out. not sure when the styling switched over, but the 60's models had german style tanks like a beamer but didn't go ever so well, so they were revamped with the british look that all of the other '70's hondas had.
not sure about a site, but if you look through the "thoughts of hondaman" in the FAQ's, he talked about this one for a minute.
« Last Edit: September 03, 2006, 08:29:33 PM by paulages »
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
upperlake04
« Reply #3 on: September 03, 2006, 09:28:19 PM »
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #4 on: September 03, 2006, 10:03:02 PM »
try here -  http://www.cb450dohc.com/
upperlake,   You beat me to it buddy. I just now found this and was prepared to send him to the 450
           site. Oh well, ya done good.
pinhead, the 1st 450 DOHC came out in 65' and was in production (as a 450) until 74' and then was increased to a 500 for 75' & 76'. Just thought you'd like to know.
 VTCMart,  In My Honest Opinion, they were and still are a pretty decent bike, all in all.
                                                     Later on, Bill
Member # 1969
« Reply #5 on: September 04, 2006, 04:20:51 AM »
Only problem they had was the starter clutches gave up
Offline bill440cars
« Reply #6 on: September 04, 2006, 05:51:22 AM »
                I wonder if any of the other Honda starter clutches would swap out or what might could be
       done to solve this problem. Some have converted the valve torsion bars over to conventional
       springs but, I intend to keep the torsion bar setup myself.
                                                        Later on, Bill
Member # 1969
« Reply #7 on: September 04, 2006, 06:57:11 AM »
Bill, Dontknow of any other fittment apart from 500 twin, but i do know that if it starts to go bad you need to either fix it or remove it as it can "grenade" and total bothe the stator and rotor. I think its something to do with the "big" twin kickback and compression. The K4 250 used to ocassionaly wreck the starter as well
Offline bill440cars
« Reply #8 on: September 04, 2006, 08:13:22 AM »
                Well, if I can't figure out a way to make it better, I may end up just taking the whole starter
        system off. I sure don't want to get some damage due to a starter clutch coming apart. That
        would help loose some weight anyway. I kinda like being able to push a button to start but, all
        things considered, might be better off. I'll let you know if I do come up with something though.
                                                              Later on, Bill
Member # 1969
Offline mack808
« Reply #9 on: September 04, 2006, 03:32:52 PM »
Why not just repair the starter clutch? Its a easy fix.  Only three spring, caps & rollers and a rotor puller to remove the rotor on the L/S of the engine.  these were problems on all the twins from the 175s they to the later 500Ts.... Once parts in hand this is about a 60 minute job.....
CB350 twin vintage road racer, CB350F project, GS750es daily rider, NS400r play bike, 2 MB5s, Z50r project, CB500/590 vintage racer built for friend, CT200 project, and a Gina (Gilera copy made in Argentina)...  And ?????
Offline Clutch Cargo
« Reply #10 on: September 04, 2006, 05:34:47 PM »
The CB450 is a great bike - very good for urban and back road hops.   Perhaps my next project......
Mike
1976  CB750K6
1976 GL1000
1994 - ST1100
1985 - HRS21
Offline bill440cars
« Reply #11 on: September 04, 2006, 08:50:46 PM »
                          I'll tell ya, I really did like being able to just push a button, instead of a kick starter, to
              get a bike going. I'll check into that thing before I decide to do any chunking.
        Later on, Bill
Member # 1969
« Reply #12 on: September 05, 2006, 05:02:28 AM »
On the 500 twin, which was more common in UK than 450, the starter usually needed the starter clutch outer(cos the screws broke and damaged the screw seats) Also the big gear as the ground diameter that the rollers work on got lots of "flat" spots. Now these two bits were mega expensive then and i believe are nearly unobtainium now.
