Author Topic: Connecting rods and blue loctite  (Read 3913 times)
Offline danfr
    • Apollo Motorcycles
« on: December 28, 2013, 11:06:03 AM »
After reading this: http://forums.sohc4.net/index.php?topic=132672.0 thread, I went to bed and stared up at the ceiling. I started thinking about my own engine. I am doing a rebuild on my own engine and started to worry about my connecting rod bolts coming loose. I have the cases sealed up, but am wondering is do people loctite their connecting rod bolts? I torqued them down with a 1/4" drive princess auto (not the best quality) torque wrench.
I am starting to think I should split the cases before I go any further and retorque the connecting rods with some loctite. While I'm at it, I could install a new CycleX primary tensioner.
Thoughts?
Apollo Motorcycles
71 Commando
74 CB750K
74 CB350F
Offline Whaleman
Re: Connecting rods and blue loctite
« Reply #1 on: December 29, 2013, 02:28:58 PM »
I think proper torque is way more important than loctite. The bolts stretch just the correct amount to keep the nut tight. I also do not think the loctite hurts and might have some lube aspect to it to allow the correct torque to be obtained. Loctite and a nut not properly torqued will not keep it together. I have always loctited the cam sprocket bolts. Dan
« Reply #2 on: December 29, 2013, 02:58:59 PM »
^^^ +1 What he said... :D
Offline setdog
« Reply #3 on: December 29, 2013, 03:01:07 PM »
holy shnikies that engines looks great.
a nearby bmw motorcycle mechanic, says "never use loctite on anything"
and if it wasnt for the look on his face when he said it, i wouldnt have take him so seriously.
im sure there are some decent exceptions to his rule however, and he doesnt work on transmissions.
« Last Edit: December 29, 2013, 03:05:05 PM by setdog »
My toolbox consists mainly of hammers.
76 CB 200T. (sold)
75 CB 750 K5. (sold)
74 CB 750 K4. (current rider)
73 CB 750 K3. (build)
https://www.youtube.com/user/setdog100
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #4 on: December 29, 2013, 03:24:50 PM »
I've heard people say 'never use loctite' before, but they are generally refering to that orange gasket-making crap that welds mating parts together and blocks oilways, rather than the thread locking compound.
The dilemma I would have in this case, sorry to fuel your paranoia Danfr, would be whether to re-use the rod bolts, as has already been mentioned they are likely already stretched through torquing. So I think the belt and braces approach would be to order a new set of bolts and use loctite.
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline danfr
« Reply #5 on: December 29, 2013, 05:08:30 PM »
thanks for all the replies.
well, i received a little holiday cash, so I went for the CycleX primary tensioner. I'll crack the cases and retorque the nuts with some loctite. Peace of mind.
While I'm at it, I can be a bit more thorough inspecting the transmission.
Cheers
Dan
Apollo Motorcycles
71 Commando
74 CB750K
74 CB350F
