Author Topic: weisco piston trouble?  (Read 6958 times)
Offline BPellerine
« on: December 29, 2013, 03:36:04 PM »
just to satisfy my curiosity has anyone had problems with their pistons since installing them?I am wondering about weisco in particular and in the present day.thanks.bill
1978 CB 750K ard and webers
another anfob
Offline Big Jay
    • CBRzone
Re: weisco piston trouble?
« Reply #1 on: December 29, 2013, 07:18:59 PM »
I have sold 1000s of sets of Wisecos, and the only ones I have seen a problem with are in motors where the valve head fell off and got between the piston and head. They don't like that.
Seriously, Wisecos, when set up correctly, are a trouble free mod.
Offline bjbuchanan
« Reply #2 on: December 29, 2013, 09:37:20 PM »
Any "problem" with wiseco wouldn't be the pistons themselves, they are proven good mods for these engines. Like Jay said, chunks bouncing around or something else but they are good to go otherwise
Offline BPellerine
« Reply #3 on: December 30, 2013, 01:42:29 PM »
thanks for the replies guys ,I asked this question because I am going to use weiscos in my engine but read a post by hondaman telling a poster to stay away from ANY forged piston for the street I personally don't think weisco and others would be in business if they sold a bad product for this many years.again thanks bill
another anfob
Offline kghost
« Reply #4 on: December 30, 2013, 02:03:52 PM »
Are you asking about a standard piston or the 836 ones?
Stranger in a strange land
Offline bjbuchanan
« Reply #5 on: December 30, 2013, 02:32:06 PM »
I think the warning for forged is because you get a lot of piston slap until warmed up. You gotta set forged slugs loose than cast because of expansion.
Offline BPellerine
« Reply #6 on: December 30, 2013, 04:46:16 PM »
836 pistons.bill
another anfob
Offline kghost
« Reply #7 on: December 30, 2013, 07:56:15 PM »
I have an 836 Wiseco.
Now bear in mind......I run it in south Texas where its hot. like 100 F in the summer.
I was cheap on this one......I did not use HD studs nor did I bore the cylinders and install oversize liners.
Both of those things I would do if I were doing another.
I find that the stock bores get very thin.
The engine runs hot. I am running an oil cooler which helps.
However as stated thicker liners and HD studs would be the way to go.
« Reply #8 on: December 30, 2013, 09:00:29 PM »
Please let me clarify, All:
The person asking about the pistons (it started with a PM to me, asking to reply in his thread) was not an experienced engine builder, but a first-timer. The things that happen with forged pistons, especially big-bores on the SOHC4 engines, because of machine shops that have their own 'opinions' about how they should be built, can result in very expensive problems. The novice won't know to stop an unknowing machine shop from doing it wrong.
This is not to say that someone who knows how to use them would have troubles: far from it. But, they are quite different from the usual cast pistons, exhibit different operating traits, and generally do not go 50k miles trouble-free, in my experience.
What they do well is: make lots of torque, relative to similar cast pistons. This is partly due to the extra heat they generate with their high compression (usually 10:1 or more) and, once warmed up, their tighter fit in the bores. They also manage increased top-end pressures better than cast pistons, with less distortion and the attendant drag across the wristpins that can develop with, say, a turbo attached.
Here's what I have experienced with forged pistons in the 750 (so many times, now, that I actually shy away from them for inexperienced rider-rebuilders): the bores are supposed to be clearanced about .0022" to .0024" for the Wiseco 836 or [old] Powroll 836 forged units. This is 2x the clearance for Honda's own cast pistons, which use .0008" to .0012" - even the cast 65mm pistons use .0010" to .0014". If this is done precisely for the forged units, they work well IF broken in properly. And, they make for a very oil-sensitive performer, particularly during break-in. During this break-in cycle, my experience has shown the engine should not be run for short periods of time, then stopped for [very] short periods, and restarted (like a 2-mile ride to the gas station, and refuel-restart): rather, it should be started up and run for a while, at varying speeds (not idle), then allowed to fully cool down, and the cycle repeated a couple more times. If this is not done pretty well, the aluminum cylinders cool so fast, relative to the pistons, that they reduce the clearance considerably on the warm restart, often causing a difficult startup, which leads to scuffed-skirt problems. These issues lead to ring damage.
In the last 4 years here on these forums, I have been thru 3 instances with rider-builders who installed the Wiseco kits (not by me) and then experienced similar problems: they either fired it up at their shop/garage and ran it until hot, or rode to their local fuel stop, then let it cool just 5-10 minutes, and afterward found it impossible to turn over the engine, as if seized. After a much longer cool-down, it (they) started back up. This cycle was repeatable for 2 of these guys until the engines had almost 1000 miles on them: the 3rd one took it back apart and discovered his machine shop had installed .0040" clearance "because that's what forged pistons need" [sic]. This one had already fractured a compression ring, with less than 10 minutes run time. After being careful to run the [other] engines longer before shutoff and either keeping the shutoff very short (2-3 minutes) or much longer (20+ minutes), the other 2 engines settled down, but both are still hard to start if hot, on a cold day. They simply drag a lot on restart because the sleeves shrink so much faster than the pistons.
I used to have a box of these (broken) pistons that I kept around to show those who wanted to build with these pistons, to try to 'drive home' the importance of knowing that the old standard break-in routine needed to be modified for these types of pistons. This issue first came to my experience with the old Yosh forged 811cc 10.75:1 CR pistons for this engine (circa 1972), which would often get installed with too little clearance. They acted similarly, back then.
So, please know my comments are not a bash of Wiseco products: rather, they were intended as a note of caution to a rank beginner who doesn't understand [yet] the 'whys' and 'whats' of the clearances, materials, and combinations of parts that could make for a bad experience if not correctly synch'd. I build engines with these Wiseco pistons for quite a few folks, unless they are planning on long-distance touring with these bikes. For those, I caution them that, in my experience, forged, hi-CR pistons used under touring conditions lead to early oil leaks (like, less than 20k miles), and the thin Wiseco rings don't last nearly as long as the somewhat over-thick cast rings usually found on these pistons.
I am still wondering about the 'things not said' (maybe not understood?) about the CycleX debut of their super-"F" bike: if you read their story about the problems they had with hot startup on the track, it smacks of this very symptom. I haven't written to talk with Ken about it, as he doesn't know me from Adam, but I would be interested to know if their non-start was due to 'stuck' forged pistons. Often, this issue gets blamed on "too much compression" (which appears in the online articles about the event), but I wonder about that when even a Powroll 11:1 set can be whipped over (when cold) with the stock electric starter, unless it is 'caught' in this cooling-period situation?
Thanks, for listening... :)
Offline Big Jay
    • CBRzone
« Reply #9 on: December 30, 2013, 09:01:27 PM »
Wisecos are forged from 4032 high silicon aluminum. You do not set them up loose
« Reply #10 on: December 30, 2013, 09:43:18 PM »
The last Wiesco kit I built was in September, 2012: the instruction sheet that came with it demanded .0022" to .0028" clearance after honing. I still have that little sheet at my shop, I think. Is this the same material that you mention, or was this an old kit of some sort? Of note: these are not the "slipper" style pistons, but they are a little shorter on their skirts than the standard cast types.
This reminds me: one of those pistons came to me with a broken ring land, out of the box. When I contacted Wiseco they sent me a piston that was supposed to 'match' the Lot number of this set, but it was different, both in diameter (it was +.0003" larger) and in that it did not have oiling holes in the wristpin bosses, like the others did. After several back-and-forth calls to their tech guys, the surmise was for me to add the oiling holes into the new piston, which I did. Upon installing the top ring, as soon as I started to spread, it snapped in 1/3 - 2/3 pieces (2 halves). Close examination showed (both to me and Wiseco) that is had a void on the ID of the ring, which somehow passed their QC. They still charged me another $35 for a ring set, blaming me (I've never broken any other ring, ever, in 40+ years...) for "over-spreading it". If I HAD installed, it, it would have broken soon.
Since that experience, I have also not used another Wiseco kit.
Offline Music City Metalcraft
    • My Facebook page
« Reply #11 on: December 31, 2013, 07:13:33 AM »
I run a set of 810cc Wisecos in my 250hp NOS-turbo Kawa for more than 10 years now. No probs, and that bike had some serious abuse!
I do remember that the instructions called for a final "plateau" honing step with a finer grit stone. My engine builder had to look up what a plateau hone is and order the stones to do it. It seems that, if you don't do that step, they will start burning oil immediately.
Mine don't.
The part that needs the most upgrading is the nut holding the handlebars
Offline bjbuchanan
« Reply #12 on: December 31, 2013, 10:29:23 AM »
Every piston is different, it was a generic warning as to why the builder probably brought up the point
Offline BPellerine
« Reply #13 on: December 31, 2013, 03:52:52 PM »
mark I just get  a little wary when someone says to stay away from forged pistons but I see why you were saying what you did.just to reiterate I asked big jay on another thread and he said .oo15 was good for these pistons not the .0025 that you see a lot.bill
another anfob
« Reply #14 on: December 31, 2013, 05:16:46 PM »
This makes me wonder which Wiseco pistons it is that Big Jay has used so much? I know Wiseco makes a 'slipper' piston that looks like most of it was cut away into a "U" shape, and they are high-performance units. The ones I've been using since 1990-something look much like the usual pistons, but have shorter skirts and are shorter overall, just not radically cut away. They always come with a little instruction card that states what clearance should be used, which has always shown the .0022" minimum.
Most of the folks I do work for are those who never worked on an engine, it seems. Once in a while I see someone who has, and we knock around how he might do it, and sometimes that's how it goes. I don't have a "fixed" method, or anything like that: heck, you'd never learn anything new if you did that! :)
I do have my favorite methods, though, which are biased toward getting maximum life from the engine in use. I've built a bunch of high-perf engines in the past, but today it's easier to go fast(er) with a modern design, if you're going racing. And, it's probably cheaper to make more HP from a modern engine, as the parts are not vintage, and thus more 'valuable' to sellers. Because of this, my bias may be showing? ;)
Then there will be the 750 Performance Book: it will contain things like forged pistons, cast pistons, slipper types, big-bores, gas porting, valve issues, etc., for the 'serious' performance rider of these bikes. It does seem a little strange to be contemplating such a book today, when a modern 250cc engine can approach the 60-something stock HP of these bikes, yet almost every week someone else wants to know when it's coming out.
I sure wish I could lay my hands on a mid-1970s Yosh 90 HP cam, though. :)
Offline Bailgang
  • Scott
  • Indiana
« Reply #15 on: January 01, 2014, 05:10:20 AM »
Not strange at all IMO in fact I'm surprised such a book doesn't exist already. I guess I got spoiled during my performance car days because there was so much info available. I remember when Smokey Yunick came out with his "how to hot rod a small block chevy" that book was literally a must have for SBC enthusiasts back then. A book like that for our SOHC's would simply give us another reason to keep them alive. I've already got your 750 book so I'll be looking forward to your performance book.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline BPellerine
« Reply #16 on: January 01, 2014, 10:53:53 AM »
these are the pistons I am going to use they are the same as the kits being sold today under the same part no.mark I mean no disrespect I have your book and could recite the the high points from memory.I don't have a bunch of knowledge on other weiscos but these have been in production for years.bill
another anfob
« Reply #17 on: January 01, 2014, 09:09:27 PM »
That 4016 number sounds familiar: I have the little 'spec sheet' at work, I think (I get to use the empty corners of the shop for engines there, sometimes). Tomorrow I'll try to find it and take a picture of it, maybe it has the part number on it?
No offense [ever] taken: heck, I don't know everything! I do get e-mails sometimes that seem to think I do, but no...  :-[
Offline BPellerine
« Reply #18 on: January 02, 2014, 06:30:04 PM »
thanks mark I am not new to engines and bikes but kind of new to the mods avail for these bikes I am building this engine purely for the fun and I find it interesting but I want to do it right and worry about things a little too much sometimes.I am not trying to build the fastest 750 but something a little more fun than the 74 I owned in about 78.bill
another anfob
Offline Big Jay
    • CBRzone
« Reply #19 on: January 03, 2014, 12:06:09 AM »
I use the standard 836 kits. I set them up at .0015 to .002 max. I am pretty sure I have probably done more of these than anyone. Got some in the shop as we speak.
There is never any issues with the blocks we set up.
Offline EnginebyAdam
« Reply #20 on: January 03, 2014, 08:43:20 AM »
Hey Bill,
I've used a lot of Wiseco's all different applications. I was the engine builder and the head of the block department at the old gig. Wiseco's seem to be able to be set up a little tighter than say a JE piston. Big Jay knows his stuff but pick up the phone and talk to Wiseco yourself on clearance. That has saved my ass once or twice. Least then you got another opinion.
Who's boring the block Bill?
Better Rodded Than Rotten
« Reply #21 on: January 03, 2014, 09:48:09 AM »
So I got to ask Jay, if the customer. Told you he was going bracket racing as soon as he got it back, you would still run it at .002?
 Sure wish I knew what my buddy had for clearance, rode his well used 836 to Sturgis, raced it there, and rode it back. On the way back running at high speed on highway he seized it, or it did when he stopped. At any rate, when it cooled off it went again and he rode it home.
Offline BPellerine
« Reply #22 on: January 03, 2014, 10:17:02 AM »
just for those who don't know we don't have the extreme heat that you would have in the southern us but we do have extreme cold!my bike will not be raced but I do want to have some fun with the right hand!bill
another anfob
Offline Big Jay
    • CBRzone
« Reply #23 on: January 03, 2014, 03:33:23 PM »
Absolutly.  Might go up to .002, but certainly not over.
We sell a LOT of Wiseco kits, along with JE,  CP, and MTC.  We have about 50 Wiseco kits over in the warehouse right now. Everything from 65mm to 75 mm and they all say .002" clearance right on the label.
Offline BPellerine
« Reply #24 on: January 03, 2014, 04:35:36 PM »
well there it is right from the man who designed these pistons or at least that is what I understand when I asked about install direction as these pistons are not cyl specific like the partial set of rcs that I have.bill
another anfob
