Author Topic: 1976 CB750 Project to look like my '70's CB  (Read 49132 times)
Offline timbo750
Re: 1976 CB750 Project to look like my '70's CB
« Reply #100 on: March 31, 2014, 06:14:38 PM »
Should be minimal oil loss but someone with more experience will confirm
Project 1 CB750 - http://forums.sohc4.net/index.php?topic=126864
Thanks for info,
I just saw your project, WOW talk about rust, didn't realize the lost city of Atlantis had CB750 Honda's.
good work.
Thanks, its a challenge and tested my tolerance level a couple of times but I no longer have deadline just a hopeful time line.
Offline rtbmrgl
  • Got Points! Roseville, Ca
« Reply #101 on: April 03, 2014, 10:03:32 AM »
Speedo has no more noise, lubed the cable. I thought I installed a new cable, I didn't. My memory is a little lacking, good thing I have a wrist bracelet with my address.  ;)
Put the stock shocks on, rides much better.
thanks, Mark
Roseville, Ca
Got Points!
1973 CB500 back yard find 1243 orig mi,  http://forums.sohc4.net/index.php?topic=124285.0
1976 CB750 Restoring,        http://forums.sohc4.net/index.php?topic=132997
Offline rtbmrgl
« Reply #102 on: April 05, 2014, 09:30:01 AM »
My brakes on my CB500 have better stopping power than my CB750. They are both stock, all the air have been bleed. any suggestion other than dual disc, different pads or rotors?
thanks, Mark
Roseville, Ca
Got Points!
« Reply #103 on: April 05, 2014, 09:32:59 AM »
That has to do more with the 90 or so extra lbs. you are trying to stop on the 750.  Other than those suggestions, go with stainless steel lines, cross-drilled rotors and maybe a larger master cylinder.
Offline rtbmrgl
« Reply #104 on: April 05, 2014, 10:53:35 AM »
Thanks,
       Ive been reading about what your saying and they are are good suggestions. But I have ridden double up on my 500 and It seems like the stopping is about the same as me riding single on the 750.
I do like the idea of a larger master cylinder.
Do you think different pads i.e. EBC is better? Who makes a good rotor?
thanks, Mark
Roseville, Ca
Got Points!
« Reply #105 on: April 05, 2014, 11:45:30 AM »
I have tried several incarnations of 750 brakes:
Stock
Dual Disc
Dual Disc GL1000 cross-drilled (swapped front end to 76 GL1000)
EBC Dual Disc GL1000 with EBC pads
The GL1000 front end swap was the best mod I made yo brakes and suspension, especially after rebuilding the shocks with Race Tech internals (gold valve emulators and new springs).
The EBC discs are very well made.  They are floating rotors so they are MUCH lighter than any stock rotors (even if you drill the bejeezus out of them).  The stock rotors do not float and are bolted straight onto the mounts; this is why the stock rotors are so darn thick to prevent warping.  I don't think that the EBC rotors stop markedly better than my cross-drilled stock rotors, but they are MUCH lighter.  If you do not do the GL swap, you will have a problem because the only EBC 750 rotors available do not fit your model.
I think you can improve your stock brakes by cross-drilling and resurfacing (deglazing) them.  Anubis Cycle (El Cheapo) or Goddfrey can do this for you -- with Goddfrey you also get the bonus of having them thinned (and lightened even more).  Drilling alone with probably shed about 1/3 the weight, and you will definitely get better bite with the drilled brakes.
Bang for the buck -- I would recommend getting them cross-drilled.  You can do it yourself if you have a heavy duty drill press, a few drill bits, a pattern you can download from the forum (do a search), and lots of patience.  Anubis can do it cheaply for $45 and the wholes are chamfered (beveled) and you get a resurfaced disc (removes any worn in grooves).
Offline rtbmrgl
« Reply #106 on: April 05, 2014, 12:18:12 PM »
Stock
Dual Disc
Thank you,  I'll look into it,
BTW, I was born and raised in Bellflower, I still fly into LB airport for visits.
..........Love the weather!
thanks, Mark
Roseville, Ca
Got Points!
« Reply #107 on: April 05, 2014, 01:22:35 PM »
Stock
Dual Disc
It's a small world sometimes.
Good luck with your brakes.  I have similar issues bugging me with my stock 550 brakes (after upgrading the lines and the master cylinder).  I've decided to go to dual cross-drilled discs.
Offline rtbmrgl
« Reply #108 on: April 06, 2014, 05:12:41 PM »
An oil quickly developed, just took a look,  it wasn't the hole in the case leaking that I just repaired  8) (nice and dry).
Its the shifter side cover gasket, YIPPEE....... its a new gasket too,  ???
Better make sure the surface is flat.
thanks, Mark
Roseville, Ca
Got Points!
Offline rtbmrgl
« Reply #109 on: April 08, 2014, 11:47:37 AM »
The leak seems to be coming from the oil galley plug, I found an old thread discussing this plug.
http://forums.sohc4.net/index.php?topic=99721.0
One person suggested an o-ring, another machined and interference plug,  I don't want to put any sealer under the plug so not to get in the oil galley.
The plug is soft but I suspect this is the cause of the leak not the gasket.
thanks, Mark
Roseville, Ca
Got Points!
Offline rtbmrgl
« Reply #110 on: April 12, 2014, 08:53:22 PM »
I got the tank paint finished, I decided to not make it like my old bike.
I wanted the similar colors and a 70's flair but I also want to keep a stockish look.
I liked the look of the early silver K bikes. Tomorrow I'll be fixing the oil leak then back on the road.
I can here ALL AMERICAN SPEEDWAY in the back ground, season just opened, plus next month FAST FRIDAYS Speedway races start up in Auburn.
thanks, Mark
Roseville, Ca
Got Points!
Offline BPellerine
« Reply #111 on: April 13, 2014, 04:51:26 PM »
nice looking tank ,did you paint the stripes or have them made?looks kinda old school in a good way.bill
1978 CB 750K ard and webers
another anfob
« Reply #112 on: April 13, 2014, 06:34:57 PM »
Great looking graphics.  Did you have ready-made decals or print your own?
Offline rtbmrgl
« Reply #113 on: April 13, 2014, 08:00:34 PM »
Thanks, I got the graphics from eBay, the blue pinstripe was from local auto parts store. They recommended clear coating over the decals. I didn't in case i decided to change later, they were cheap.
http://www.ebay.com/itm/400564858086?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
http://www.ebay.com/itm/221246237877?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
thanks, Mark
Roseville, Ca
Got Points!
« Reply #114 on: April 13, 2014, 08:56:13 PM »
I'd go with two coats of clear over the decals and stripes.
Offline rtbmrgl
« Reply #115 on: April 22, 2014, 10:42:43 AM »
Just got these, 2- HM341, 2-HM300,  the hm300 are cyld. 2-3
getting ready to clean them up
thanks, Mark
Roseville, Ca
Got Points!
Offline rtbmrgl
« Reply #116 on: April 23, 2014, 12:08:23 PM »
Well I'm finished, runs great, I've been riding back and forth to work for a few weeks and no oil leaks have developed despite the hole in the case from the thrown chain.
Before-
Case crack
After fix
thanks, Mark
Roseville, Ca
Got Points!
« Reply #117 on: April 23, 2014, 03:26:39 PM »
Mark,
Your bike turned out great.  Congrats!!
Don
Offline rtbmrgl
« Reply #118 on: April 23, 2014, 06:17:46 PM »
Mark,
Don
Thanks Don, when I discovered the hole in the case my heart sank. I started investigating and found others have repaired plus the fact the previous owners have been riding for years in this condition, the last owner didn't even know(so said).
My wife has always said I can fix anything, so what the heck, Ill re-fix it a little better. Only time will tell.
I did drop the oil pump screen cover and found no metal chunks, in fact it was fairly clean.
If I come across a good set on cases I'll consider replacing, but for now spring is here and the roads are dry.
thanks, Mark
Roseville, Ca
Got Points!
« Reply #119 on: April 23, 2014, 06:20:34 PM »
+1 great job, especially on that case repair.  Ride on!
Offline rtbmrgl
« Reply #120 on: April 23, 2014, 09:11:00 PM »
thank you,
thanks, Mark
Roseville, Ca
Got Points!
Offline rtbmrgl
« Reply #121 on: September 06, 2014, 11:21:35 AM »
I just scored a Russell Day Long Seat for $20. I know for the purist this is not stock and ugly, but for the rider these seat are the creme dela creme. Its old but the seats in good condition.
The company is near where I live in No Calif. and has been around long time. Several of my bikes in the past had them on, 1k mile day is not a problem.
thanks, Mark
Roseville, Ca
Got Points!
« Reply #122 on: September 06, 2014, 04:24:57 PM »
But, do you plan to do 1K Mike days? I've done 200 mile days on the stock seat with no complaints.
Offline BPellerine
« Reply #123 on: September 09, 2014, 04:59:48 PM »
I understand the reasoning behind this seat but the corbin is an awesome looking seat on these bikes!bill
another anfob
Offline rtbmrgl
« Reply #124 on: September 10, 2014, 08:45:46 PM »
Yeah that's true, the Corbin is a very good looking seat. And actually I like the comfort of a Corbin but not on this bike, I feel cramped, plus it didn't fit right on the bike.
And I was thinking on taking a trip  from Sacramento to LA, its not 1000 miles but if you count all the idiot LA drivers it feels like a thousand miles.
thanks, Mark
Roseville, Ca
Got Points!
