Author Topic: "The Basement Build!" 1973 Cb350F  (Read 67938 times)
Offline grcamna2
Re: "The Basement Build!" 1973 Cb350F
« Reply #225 on: March 19, 2014, 08:23:06 PM »
These work really good for removing old gaskets. The threaded part is 1/4". I take a long 1/4" bolt and cut the head off. Thread it into the roloc adapter and use a 3/8 hand drill for the stud you just made. wa la you have gasket grinder. If you go this route BE CAREFUL with these things!! They will take aluminum off in a hurry and ruin your cover.
http://solutions.3m.com/wps/portal/3M/en_US/3MIndustrial/Abrasives/Products/~/3M-Roloc-Gasket-Removal-Disc-Pad-Assembly?N=7581717+3294228578&rt=rud
That wheel looks good for Hard gaskets,I usually suffer along w/ a few safety razors and take my time;once the Old gaskets are history I know I'll never have that problem w/ that engine again.
75' CB400F/'bunch o' parts'
Offline thirsty 1
« Reply #226 on: March 19, 2014, 08:29:33 PM »
Ya these things can make good parts into junk if a person isn't careful! I use a utility knife a lot too.
Offline bjbuchanan
« Reply #227 on: March 19, 2014, 08:57:40 PM »
I use an exacto knife with the pusher style blade. It is flexible enough to get up under the gasket and stay there. It isn't strength you need but the flexibility to really work the blade end around and keep under the gasket.
Offline 2strokeTrush
  • Can you get that back together sonny?
« Reply #228 on: March 19, 2014, 09:07:25 PM »
The paint near the oil filter on the frame looks great.
Thanks man! I Rattle can'd the Frame a couple pages back!
Most likely the route i will be taking.  Just don't want to destroy a good cover.
« Last Edit: March 19, 2014, 09:12:20 PM by 2strokeTRush »
If You Aint First Your Last!!
 350F project-http://forums.sohc4.net/index.php?topic=133079.0
500F Project-http://forums.sohc4.net/index.php?topic=135660.0
Offline Nick0
« Reply #229 on: March 20, 2014, 04:48:21 AM »
I recently had to do this on my cb350f, I found the solvent was useless. I wouldn't waste your time with the solvent. I bought the 3m gasket remover pads for the drill and that worked for me. Good luck
« Reply #230 on: March 20, 2014, 05:22:06 AM »
You're not using enough beer.
« Reply #231 on: March 20, 2014, 08:38:56 AM »
thanks for the input guys!
Offline dagersh
    • Photos
« Reply #232 on: March 20, 2014, 09:44:34 AM »
Amen!
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline timbo750
« Reply #233 on: March 20, 2014, 01:59:07 PM »
Stev-o you always seem to have the right answer.  Lots of experience.
Project 1 CB750 - http//forums.sohc4.net/index.php?topic=126864
Offline silentsvn
« Reply #234 on: March 20, 2014, 05:45:12 PM »
If you have a dremel you can get get these. They are hard enough to eat the old gasket but won't damage the aluminum at all. http://www.dremel.com/en-us/Accessories/Pages/ProductDetail.aspx?pid=EZ471SA
1973 Honda CB350 Four
2004 BMW GS 1150 Adventure
1967 Honda CL 90
Stuff for Sale
« Reply #235 on: March 20, 2014, 06:46:16 PM »
Thanks for the tip! Ill pick that up!
« Reply #236 on: March 20, 2014, 06:55:27 PM »
Hey Timbo - the link you provide is not valid
Offline timbo750
« Reply #237 on: March 20, 2014, 07:35:23 PM »
Stevo thanks,  should work now
Project 1 CB750 - http://forums.sohc4.net/index.php?topic=126864
Offline skidooextreme
« Reply #238 on: March 21, 2014, 12:52:35 PM »
I live in a small town, so all i do is make a call to the police station and they come out to my house and provide the vin check
Offline grcamna2
« Reply #239 on: March 21, 2014, 03:15:50 PM »
That's very Nice.
« Reply #240 on: March 22, 2014, 07:57:34 PM »
Spent most of today painting and running wires and connecting everything back up in the headlight bucket.  And it all works! The rebuilt switches work perfect and the new bulbs in the gauges are very bright!  Maybe not vintage, but they are good looking!  Installed a new turn signal relay and the new ones flash when my old ones didn't.  Its just nice to know all these little things are working!  Also used my Dremel to remove what was left of the old gasket. Don't have any pictures of how it turned out, because it went right to painting after that.
Anyone know where this wire connects?
« Reply #241 on: March 24, 2014, 08:25:09 AM »
Seriosly about to pull the trigger on that 175 when i see this a hour away from me!  Looks a little rough but its a bigger bike in fair condition.  What about those high miles though?
http://york.craigslist.org/mcy/4389556031.html
« Reply #242 on: March 24, 2014, 09:36:09 AM »
Lets Go! Someone tell me what to do before this guy sells it!!
Offline dagersh
    • Photos
« Reply #243 on: March 24, 2014, 10:45:35 AM »
If he has a title, buy it. The missing parts are pretty available and loads of those bikes about
+1
If you don't buy it I will!!!!!  That is a restoration candidate though, looks very nice.  I have a '72 in those colors, until a fire broke out next to it at a shop.  Now its burnt and rusty....  Soon to be known as project "Kemuri"
Also, that brown wire would hook into a European Front Parking light, which you probably do not have on your Headlight bucket.  So it does not attach to anything.  You can check to see if the power switched on when the Key is in the Parking Position.
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
« Reply #244 on: March 24, 2014, 11:19:14 AM »
What About the 48K??
« Reply #245 on: March 24, 2014, 11:43:18 AM »
who cares? worst case scenario, you may need to re-ring it. Plenty of these bikes run for over 100k miles if properly maintained. For $550 you aren't getting a stock, new condition bike.
Alright you all talked me into it! I set up a appointment 2 days from now with the guy!  Just worried someone else is gonna come along!
Offline dagersh
    • Photos
« Reply #246 on: March 24, 2014, 12:18:44 PM »
J/K - all yours!
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
« Reply #247 on: March 24, 2014, 04:19:18 PM »
Appt??  Go get it now!  You think he's going to put it in "lay away" for you?
Did you read the ad, first one with $550 gets it....
Offline thirsty 1
« Reply #248 on: March 24, 2014, 04:55:24 PM »
Man if I were you I'd jump on that in a flash.
« Reply #249 on: March 24, 2014, 07:20:26 PM »
Jeeze Jezze!! Im going to pick it up Wednesday! Put a down payment on it already!  Happy now!!??  ;D ;D
