Author Topic: "The Basement Build!" 1973 Cb350F  (Read 67921 times)
Re: "The Basement Build!" 1973 Cb350F
« Reply #250 on: March 24, 2014, 07:26:24 PM »
who cares? worst case scenario, you may need to re-ring it. Plenty of these bikes run for over 100k miles if properly maintained. For $550 you aren't getting a stock, new condition bike.
Alright you all talked me into it! I set up a appointment 2 days from now with the guy!  Just worried someone else is gonna come along!
Appt??  Go get it now!  You think he's going to put it in "lay away" for you?
Did you read the ad, first one with $550 gets it....
Man if I were you I'd jump on that in a flash.
Jeeze Jezze!! Im going to pick it up Wednesday! Put a down payment on it already!  Happy now!!??  ;D ;D
That's more like it, yes happy now. And you can't chop it up.  That bike in original stock cond would be worth $2K plus.  Prob is, needs stock exhaust to get to that value, hard to find and or pricey.
But easily worth $1000-1500 with just minor work. Good score.
Offline 2strokeTrush
  • Can you get that back together sonny?
« Reply #251 on: March 24, 2014, 07:57:42 PM »
Thanks man I'm pretty excited, Thinking i will get it safe and running and ride it over the summer, and then it will become next winters Project!  now who has some spare parts for this thing!?
If You Aint First Your Last!!
 350F project-http://forums.sohc4.net/index.php?topic=133079.0
500F Project-http://forums.sohc4.net/index.php?topic=135660.0
« Reply #252 on: March 24, 2014, 08:03:43 PM »
few have been properly maintained...just sayin'
« Reply #253 on: March 24, 2014, 08:20:29 PM »
Lets hope this one has been!
Offline grcamna2
« Reply #254 on: March 24, 2014, 08:50:48 PM »
You may even find some Original exhausts for it(w/ a few holes) that need to be patched and it'll look Mint.
Did you say you offered the guy 200 ?
75' CB400F/'bunch o' parts'
« Reply #255 on: March 24, 2014, 08:59:15 PM »
Hoping eventually to find a nice set of pipes for it!  No I told the guy who had the 175 i would give him 200 and he said he could do that.  Im Obviously backing out of that now because this 500 is sweet!!
Offline grcamna2
« Reply #256 on: March 24, 2014, 09:07:59 PM »
You said ! it's the big brother to your 350/4; you and your Dad could take rides  ;).
« Reply #257 on: March 26, 2014, 07:02:39 PM »
Im going to make a proper Build Thread for her, but Gentlemen "Stella" has arrived!!!
Offline bjbuchanan
« Reply #258 on: March 26, 2014, 07:08:33 PM »
Bastard ;D
Offline timbo750
« Reply #259 on: March 26, 2014, 07:12:04 PM »
Well done, it looks from the photo to be in reasonable condition. Would of cost $2k-$3k here is Aus.
Project 1 CB750 - http://forums.sohc4.net/index.php?topic=126864
« Reply #260 on: March 26, 2014, 07:14:07 PM »
Congrats, Stella looks real good.
« Reply #261 on: March 26, 2014, 07:23:43 PM »
Would have cost more than that Tim..... ;)
« Reply #262 on: March 26, 2014, 08:29:20 PM »
Great looking bike.  Multi bike disease is catching!
Offline grcamna2
« Reply #263 on: March 26, 2014, 08:48:18 PM »
It would look Nice to restore it to Original stock,I think that paint could be cleaned up too...
« Reply #264 on: March 26, 2014, 09:30:44 PM »
Thanks for the Input guys.  Right now I'm just going to try and get her running.  Heres the link to the build thread I just made.  Pretty excited about it!
« Reply #265 on: March 29, 2014, 09:43:41 PM »
Sorry for the lack of updates, The 500f has been taking up my time!  Sent the Carbs out today to be rebuilt due to time constraints and I really need the bike running in abut 2 weeks, plus I won't have to worry about them.
Finally baked the parts in the Oven to cure
New Oil Filter installed, painted housing, looking good.  I love putting this stuff back together!
Will be back at it Tomorrow!
Offline grcamna2
« Reply #266 on: March 30, 2014, 06:11:29 PM »
Nice Job Tyler.  8)
« Reply #267 on: March 30, 2014, 06:26:15 PM »
After baking the parts I installed them, except the clutch cover while I'm still waiting for a gasket to come in.  Its not perfect, but its ok with me.  I used the high temp grey pain on the "Honda" on the plate.
Finally cleaned up the 4into4 getting ready to have my welder braze them over.  Just the Pipes and the carbs and she will be done.
Only thing I was worried about, I ( By Mistake ) moved the kickstarter spring and now I'm not sure I put it back in correctly.  Is it supposed to be wound up?  The manual is next to useless on this.
Hard to see in this picture, but the other prong on the spring is toward the middle of the picture.  Does the spring just sit in there or does it hold tight and not move at all? I feel like it just slid out no problem but now i have it sorta wound up in there
« Last Edit: March 30, 2014, 08:15:07 PM by 2strokeTRush »
« Reply #268 on: April 03, 2014, 12:22:42 PM »
Anyone got anything on that spring?
Offline grcamna2
« Reply #269 on: April 03, 2014, 12:41:01 PM »
Tyler,
Does the kickstart lever feel like it's got some initial tension on it ?
« Reply #270 on: April 03, 2014, 12:49:08 PM »
Tyler,
Lever isn't installed as I'm waiting on a gasket to arrive. I just don't wanna reinstall and then tear it back down
Offline grcamna2
« Reply #271 on: April 03, 2014, 01:03:50 PM »
I suggest that you install the lever just enough to tell how much tension is on that spring,that'll tell you if you have it in and wound correctly.
« Last Edit: April 03, 2014, 03:15:36 PM by grcamna2 »
Offline silentsvn
« Reply #272 on: April 03, 2014, 05:06:03 PM »
It looks like the inner spring isn't in the hole. There is a pocket just inside that it sits in the the outer spring clips on the casting shelf on the left and the right on the lower casting shelf like you have it.
1973 Honda CB350 Four
2004 BMW GS 1150 Adventure
1967 Honda CL 90
Stuff for Sale
« Reply #273 on: April 03, 2014, 09:15:30 PM »
Tyler - check out Dagersh's 550 resto build thread. He just went thru this issue. Now, different bikes obviously, but the same principles may apply. His pics are better too!  ;)
Thanks guys as always!  An what hole? I see a little notch, is that it?
Offline grcamna2
« Reply #274 on: April 03, 2014, 09:55:01 PM »
Tyler,
I've never removed one of those kickstarters on the CB500/550,but according to what the member says "the inner spring",it's possible that they're a double spring set-up in there.
