Author Topic: Cb400f front brake tube  (Read 744 times)
Offline plug1
« on: January 01, 2014, 05:51:24 PM »
Can the front brake tube be eliminated and a new brake line be threaded directly into the caliper? Thanks
Offline Bodi
Re: Cb400f front brake tube
« Reply #1 on: January 01, 2014, 08:58:50 PM »
Yes. You can find a matching fitting if you really want to go straight in, or just use a standard banjo fitting with the correct banjo bolt (M10x1 I think but not 100% sure, it's not the usual Honda banjo thread though) - however, the threads are not deep and you may have to shorten the bolt slightly. There's a steel flare seat sitting at the bottom of the hole, it's easy to pull out with a self tapping screw turned into the centre hole. You should remove this seat to use a banjo. Without machining the area around the hole you will need two banjo washers under the banjo itself to raise it above the counterbore but this isn't a big deal. A shallow angle (15 or 20 degree?) banjo fitting will point the flex line straight at the support loop.
« Last Edit: January 01, 2014, 09:15:07 PM by Bodi »
Online bryanj
« Reply #2 on: January 01, 2014, 10:19:25 PM »
Bodi, whilst that fitting seems to come out of a 750 caliper I have tried many times to get one out of a 500 (same as 400) and never suceeded
Offline Trevor from Warragul
« Reply #3 on: January 02, 2014, 02:37:53 AM »
1971 Kawasaki H1A
1972 Honda CB350F
1976 Moto Morini 3 1/2 Sport
1978 Honda CBX
1997 Suzuki Bandit 1200
1999 Ducati Monster 750
Offline plug1
« Reply #4 on: January 02, 2014, 11:51:41 AM »
This is the problem I'm having. I'm buying a new caliper from David Silver but I don't think I can salvage the old tube....it's really stuck in there. I figured I'll just get a proper sized line and eliminate that goofy thing. Thanks for the info.
Offline Runuv
« Reply #5 on: January 04, 2014, 04:46:14 PM »
On my 75 CB400F I put a 30 degree banjo fitting with the banjo bolt at the caliper. I went to all SS from the master to the caliper. Much better then the rubber but was a pain making the bends.
Almost there!
Offline plug1
« Reply #6 on: March 28, 2014, 01:23:23 PM »
As far as using 2 crush washers, the washer sits on top of the lip around the threads for the banjo. Tightening the banjo causes the washer to "cup" and I have brake fluid seeping out. I don't think I'll find a crush washer small enough to fit inside the recessed banjo hole in the caliper. I'm thinking I'll have to grind that lip down to create a flat surface for the washer to seal. Any suggestions? Thanks .
Online bryanj
« Reply #7 on: March 28, 2014, 05:43:24 PM »
See the pictures on the attached document , the fittings listed at "3" are the ones you need, but i dont have them any more and the prices are 6 years old!!
