Author Topic: dimensions of this air box part  (Read 600 times)
Offline MIKE550/4
« on: January 02, 2014, 10:16:48 AM »
http://www.cmsnl.com/honda-cb550k3-four-england_model14671/partslist/F16.html#results
no 19
cant seem to get one anywhere so going to make a temp one while I find one
uk based 550 k3 england
anyone got the dimensions or at least a pic of one
not sure if its really needed , anyone help ?
Offline LesterPiglet
  • 1977 CB550F2
Re: dimensions of this air box part
« Reply #1 on: January 02, 2014, 11:08:38 AM »
That's basically a frame. The darker part on top is a rubber seal and part #18 rests down on the seal which in turn rests on the sponge element when it's all assembled.
You could easily knock something together to do the job.
Offline MIKE550/4
« Reply #2 on: January 02, 2014, 11:54:37 AM »
yeah I think your right, is it just a square plastic frame the air element sits in with a lip ? and then a square section of rubber ?
« Reply #3 on: January 02, 2014, 12:22:33 PM »
Element seal.
This keeps the two metal parts 18 and 21 from rubbing each other, as well as seal the element compartment the two parts form when assembled.  The foam actually fits inside #18.
It is a U shaped formed rubber part.  You'll need two if original.  They expand something fierce during use, and are quite difficult to get back on and reassemble properly.  If left to dry out they shrink back to proper size.  So, it's one in use and one hung out to dry between service intervals.  The one in the pics is dry.  It might be a tad smaller than when fitted onto the edge of #18.
Offline MIKE550/4
« Reply #4 on: January 02, 2014, 02:00:03 PM »
thanks mate, cant get one over here though never mind two
I will be using original air filter set up, but have to think of something else to use while I source one
thank you for photo though it will help  8)
