Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Coming along nicely Roland, keep it up. Is the lower case actually cracked through or just chain rub lines from a loose chain?
Quote from: tweakin on January 05, 2014, 07:34:33 amComing along nicely Roland, keep it up. Is the lower case actually cracked through or just chain rub lines from a loose chain?Thanks, it was actually cracked through. That little pick is actually poked all the way through into the motor. As you know the metal is pretty thick right there but it was still pretty damaged on the inside. The JB Weld got us through the summer with no more leak but now that crack has been welded closed.
Cool. I was going to offer a lower case for the price of shipping if you wanted it. Since you welded it up you probably no longer need it.Quote from: Roland on January 05, 2014, 07:43:43 amQuote from: tweakin on January 05, 2014, 07:34:33 amComing along nicely Roland, keep it up. Is the lower case actually cracked through or just chain rub lines from a loose chain?Thanks, it was actually cracked through. That little pick is actually poked all the way through into the motor. As you know the metal is pretty thick right there but it was still pretty damaged on the inside. The JB Weld got us through the summer with no more leak but now that crack has been welded closed.
I was able to make little progress yesterday afternoon, hopefully by the end of the weekend I will have this bike mostly together.
