Author Topic: Speedometer trip meter knob screw kaput  (Read 1205 times)
Offline whizzer
  • Be safe
« on: January 04, 2014, 03:38:23 PM »
CB350F speedometer trip meter knob screw was rusted and phillips slots crumbled.  so head was drilled off. I think this is common. Coming up with a replacement is hard to imagine. Small, long, fine threads.
Besides glue what can i use to hold the knob on the shaft?
« Last Edit: January 05, 2014, 05:27:45 PM by whizzer »
72 cb350f
66 cb77 sold
72 Suzuki gt750 given away
59 Vespa given away
06 Whizzer sold
Offline edwardmorris
  • Youngish
Re: Speedometer trip meeter knob screw kaput
« Reply #1 on: January 04, 2014, 03:47:14 PM »
CB350F speedometer trip meeter knob screw was rusted and phillips slots crumbled.  so head was drilled off. I think this is common. Coming up with a replacement is hard to imagine. Small, long, fine threads.
See if you can find a replacement here
http://www.motogrid.com/pages/OemParts?aribrand=HOM
Offline whizzer
  • Be safe
Re: Speedometer trip meter knob screw kaput
« Reply #2 on: January 05, 2014, 05:51:52 AM »
I'll try to find a very small generic metric machine screw. Will post size that works.
72 cb350f
66 cb77 sold
59 Vespa given away
06 Whizzer sold
Offline Schnell
« Reply #3 on: January 05, 2014, 09:59:48 AM »
I was thinking about using a twist on electrical home wire connector. Or the type with a set screw.
Then I got a used replacement part from a friend. Thanks Reid!
primary: 1974 Honda CB750
project: 1971 Honda CL350
project: 1974 Honda CB450
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
« Reply #4 on: January 05, 2014, 11:44:36 AM »
I had the same idea, but could never find one that fit...finally ended up finding a smashed up speedo at a swap meet for cheap and stripped it for parts...
Offline whizzer
  • Be safe
« Reply #5 on: January 08, 2014, 05:29:49 PM »
screw size M2-.04 4mm works, it could be longer I think, like 6mm or maybe 8mm.  Went to hobby shop and got several that did not work.  these came from Amazon for about $4.  now can fit 99 more gauge knobs.
72 cb350f
66 cb77 sold
59 Vespa given away
06 Whizzer sold
Offline Supermex01
« Reply #6 on: January 08, 2014, 05:33:41 PM »
I used a table lamp switch knob
You can get them at home depot in all kinds of shapes and colors
They work wonders
Offline whizzer
  • Be safe
« Reply #7 on: January 08, 2014, 07:15:49 PM »
M2-0.4 4mm is too short.  Knob hole depth is 3 mm-4mm and shaft hole is 8 mm so screw can be no more than 12mm.  Ordering 8mm since that is what's available on amazon. 100 count for $3.30.  Should work with locktight.
The lamp knob idea is a good one.
72 cb350f
66 cb77 sold
59 Vespa given away
06 Whizzer sold
Nic
« Reply #8 on: January 08, 2014, 10:17:45 PM »
I went to return my trip meter to zero after filling up today and the bastard knob is gone. CB750 faces  has em for $19.50 plus shipping, in Oz money that's $35, I bought it  ::)
Offline whizzer
  • Be safe
« Reply #9 on: January 10, 2014, 05:52:49 PM »
M2-0.4 8mm worked well.
72 cb350f
66 cb77 sold
59 Vespa given away
06 Whizzer sold
