Author Topic: honda 550 big bore pistons 61mm HC pistons in a stock bore 750?  (Read 8034 times)
Offline hondaman750
  • The value of life can be measured by how many times your soul has been deeply stirred.
Re: honda 550 big bore pistons 61mm HC pistons in a stock bore 750?
« Reply #25 on: June 13, 2014, 05:44:29 PM »
How do you all feel about 4th over cb350 pistons (65mm) in a cb750?
Don't let the little red bar on the tach stop you from reaching 12k they love it! Mine does
« Reply #26 on: June 14, 2014, 08:00:42 AM »
You will, have to trim the skirts, and remachine the domes, and maybe the valve pockets... Then they work..
Offline hondaman750
« Reply #27 on: June 14, 2014, 08:02:10 AM »
OK I found a set of 4 that have already been in a 750 I was just curious about what the estimated CR would be
Offline turboguzzi
« Reply #28 on: June 17, 2014, 06:30:09 AM »
check the whole kawasaki 650-750 (and big bore kits) fours family: 15mm pins, bores in the range of 62mm to 69 (wiseco 810), gave a set of stock 66mm off a gpz750 to try to paulages, ask him about them :)
« Reply #29 on: June 17, 2014, 11:08:26 AM »
This was one of the first 'big bore kits' out there in 1969 (using modified 350 twin pistons). The compression comes in at 175-185 PSI on a compression gage, so it's close to 11:1. If you can install a Megacycle cam like their 125-00 with the longer dwell, it helps to bring it down to about 10.6:1 so the engine isn't so finnicky, hot, and leaky.
The pistons are considerably heavier than "proper" 750 big-bore pistons, so don't expect it to be real smooth: it won't be. The crank weights are a bit light for the heavier pistons. You will also need some strong rods for this much compression.
