Author Topic: 16 or 18 gauge wire?  (Read 4561 times)
Offline slowjo
« on: January 05, 2014, 03:40:37 PM »
Hello all, its been a while since I have been on this site and since its winter in the northeast I have the bug to work on my 1971 CB750 project. What gauge wire should I use to rewire my motorcycle? 16 or 18?  Not for a restoration but to upgrade the electronics. Thank you.
Offline lucky
Re: 16 or 18 gauge wire?
« Reply #1 on: January 06, 2014, 05:53:12 AM »
The wire size depends on the load being carried.
The larger wire is always good insurance.
Offline Van Johnson112
« Reply #2 on: January 06, 2014, 10:08:00 AM »
Pretty nice easy to read chart to help you out in a pinch. As long as you can get a general idea or close to number on current draw of the circuit/circuits.
Offline slowjo
« Reply #3 on: January 06, 2014, 02:16:35 PM »
Thank you.
Offline sniper1
  • SNIPER1
« Reply #4 on: January 06, 2014, 08:20:58 PM »
I just rewired my 550. 18 gauge.
Online Bodi
« Reply #5 on: January 07, 2014, 06:15:23 AM »
The OEM harness wire is, being Japanese, not AWG (American Wire Gauge). Their metric wire size is rated in square mm of conductor: as I recall the harness wires are 1.5mm² which is a bit larger than AWG 16 (1.31mm²), and a bit smaller than (basically unobtainable) AWG 15 (1.65mm²). Using AWG 14 (2.08mm²) would have the wires looking rather large, generally people use 16ga because the wires look about the same size as stock. If you don't care about looks - go with AWG 14.
Very important!!! Use high flex wire. You don't need the "wet noodle" stuff available at hobby shops for wiring R/C cars but using 7 strand wire will lead to metal fatigue and wire failure from the vibration. I recommend MTW "robotic" or "machine tool" wire at the last. Auto store hookup wire is still a bit stiff for my liking. I look around surplus shops for large multiconductor cables from scrapped machine tools - the have a lot of individual wires all color coded. You won't find exactly all the wire colors Honda used but you will almost always find the 10 NEMA solid colors and there will be some system of coding the rest, usually colored lines added.
Offline Toxic
« Reply #6 on: January 07, 2014, 06:58:32 AM »
Thanks Bodi ... that was informative
Printed and saved in my binder
Offline zeech
« Reply #7 on: January 07, 2014, 01:36:30 PM »
I just rewired my entire bike using 16 everywhere except a few places for power where I used 14.
