Author Topic: Odds and Ends...  (Read 843 times)
Offline Dirty Steve
Odds and Ends...
« on: January 06, 2014, 04:26:36 PM »
Could anyone tell me the procedure for tightening up the triple tree? I want to make sure I don't have it too loose/tight.
Also, I bought the All Balls sealed wheel bearings for the front. I'm assuming they're already greased and I don't need to pack them, correct?
Thanks!
Riding motorcycles will make you a poet. Working on them will make you a philosopher.
1975 CB750K5 with stock airbox, exhaust et al...
Re: Odds and Ends...
« Reply #1 on: January 06, 2014, 04:33:40 PM »
are you asking about the steering head bearing adjustment?  you need to get a service manual of some sort.  Torque specs are in there too...and no All Ballz bearings do not come with grease in them, you will have to pack them yourself....oops just saw you were asking about wheel bearings, no idea on those
« Last Edit: January 06, 2014, 04:42:53 PM by seanbarney41 »
Offline krusty
« Reply #2 on: January 06, 2014, 04:38:29 PM »
From experience, I've found that many of these sealed bearings have stuff-all grease in them. Flick the seal off one side and check. If it looks like it needs more then repack it. You can leave that seal off if you want and fit the bearing with the open side facing inwards.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
