Author Topic: my 77 cb750f2 SS donor to boner  (Read 3643 times)
Offline Rinchnut
  • passion 4 2wheelz
  • polishin pavement
« on: January 07, 2014, 08:30:35 AM »
Someone said I should post pictures and so... heres the donor. Painted side covers cuz I hated lookin at em.
Not sure how I can post all the things ive done to it already.
Thread repairs on every carb float bowl.
House hold lightswitched removed
Took of stock killswitch made my own killswitch/start panel (which was for experiementing and now I hate it)
Had to back the idle screws out a LOT to keep it
from bogging out of idle off choke.
 This p.o. cracks me up- one  red wheel. One ...silver lol
maybe if I took enough PCP id do this to a perfectly good bike myself.
I can ride it. It starts right up. Sounds good. No popping. Still need to sync after I get the accelerator pump to work right. I had a missing o ring in the ejector on the bowl. Leaked gas
everywhere till now. The damn thing runs better without an airbox on it... so im thinkin pods down the road since its hungry for em.
Lots of work ahead...and one big engine overhaul when I win the lotto lol
missing a few head cover bolts filled in with a blsck resin or something.
Theres gasket sealant adhesive on almost everything.
Questions, comments or insults anyone?
« Last Edit: January 07, 2014, 01:57:48 PM by Bob Wessner »
__________________________
'77 cb750f supersport
'74 cb750K
72' cb750 k mono
'80,81,83 cb750C
'82 cb750 dohc ss
ts185
06 s40
06 c50
Offline Bankerdanny
  • Endeavor to persevere
Re: my 77 cb750f2 SS donor to boner
« Reply #1 on: January 07, 2014, 08:39:14 AM »
Insults? OK: your mother was a hamster and your father smelled of elderberries.
Offline Rinchnut
  • passion 4 2wheelz
  • polishin pavement
« Reply #2 on: January 07, 2014, 08:39:59 AM »
As.you can clearly see... I discovered DECKING screws and DRYWALL screws I  my CARBS.
this made me angry and I wish I could give the p.o. a $20 shot for doing this #$%*...
tapped out all holes.  Came up with two diff sizes but they are correct and metric baha. No gas leaks?? I thoughy fixing them might stop the leak... but then I discovered a missing oring on the accel. Pump. Ace hardware had one that fit perfectly for .49 cents.
'74 cb750K
72' cb750 k mono
'80,81,83 cb750C
'82 cb750 dohc ss
ts185
06 s40
06 c50
Offline Rinchnut
  • passion 4 2wheelz
  • polishin pavement
« Reply #3 on: January 07, 2014, 08:40:43 AM »
Elderberries?!?! Loving it. I love a good laugh
'74 cb750K
72' cb750 k mono
'80,81,83 cb750C
'82 cb750 dohc ss
ts185
06 s40
06 c50
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #4 on: January 07, 2014, 09:54:15 AM »
I recently worked on one that had that exact same bowl screw assortment. Maybe Honda slipped a couple "custom" SOHC/4's in there!   ;)  ;D 8)
Orrrr.... I found a botched experiment from the same P.O. (or his brother)  >:(
On a positive note, I have gotten quite proficient at the Helicoil repair of the float bowl screws.  8) I order the inserts by the dozen, since the PD carbs have twelve bowl screws. Haven't had to repair the threads below the accel pump crossover passage yet, and hope to never need to. I imagine it's only a matter of time though...  ::)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #5 on: January 07, 2014, 12:18:54 PM »
Out of deference to our black members and friends here you really should choose your words better. Leaving the letter "i" out did nothing for what you wrote excpet maybe get it posted. I don't mind your thoughts, they are solely your's but please refrain from spewing ones like that in our public forum.
Back to your bike, it's coming around really nicely.
« Last Edit: January 07, 2014, 12:21:13 PM by Jerry Rxman Griffin aka MuthaF'er »
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #6 on: January 07, 2014, 01:59:01 PM »
Original post edited to remove racial slur.
Note to OP, please don't repeat it.
Offline Steve_K
« Reply #7 on: January 07, 2014, 03:53:09 PM »
When I worked in a BSA/English bike shop, I found sheet metal screws, metric and SAE screws in Witworth or British Standard threads.  They did what ever it took to "fix" the bike.
Always an adventure!
Steve
Steve_K
Offline Rinchnut
  • passion 4 2wheelz
  • polishin pavement
« Reply #8 on: January 08, 2014, 07:27:20 AM »
So... its been quite interesting repairing all 12 holes on the carbs.
They are now clean, snug and secure.   i had to do some thread repairs before and used Heli coil brand. I found one called Powercoil that has a nice set up and better tools in the kit at the same price range or a little less. If I had to recommend a brand it would be Powercoil so far.
 Today im makin a small bracket to relocate my bulky keyswitch. Im gonna tak it onto the frame. Left side just below the front of the tank. Any other ignition ideas that dont involve the dash area???
'74 cb750K
72' cb750 k mono
'80,81,83 cb750C
'82 cb750 dohc ss
ts185
06 s40
06 c50
« Reply #9 on: January 08, 2014, 08:00:11 AM »
You could buy a earlier generation frame mounted switch (from a K-K6 model) which is far less bulky, but you will need to weld a mount, since your F frame doesn't have one stock.
Offline Rinchnut
  • passion 4 2wheelz
  • polishin pavement
« Reply #10 on: January 08, 2014, 08:06:00 AM »
I have a k4 switch but it has four wires. The 77 f2 has more.  So im not sure ab the technicalities there.
I can weld. Making a custom bracket today to weld to frame. Will relocate this for now.
Ill have more room when I get the pods on the carbs.
'74 cb750K
72' cb750 k mono
'80,81,83 cb750C
'82 cb750 dohc ss
ts185
06 s40
06 c50
« Reply #11 on: January 08, 2014, 12:54:19 PM »
Eliminating the parking light function (extra wires) from the original switch shouldn't present any issues other than no parking lights. Has anyone really used this function?! By the time you get back with a can of gas the battery is shot anyway. You'll lose the steering stem lock but that a non-problem too.
Doesn't really look like you'll need to do too much to it. Do you know what has been done to the engine? It's been out of the frame to get that silver head.
« Reply #12 on: January 08, 2014, 02:46:53 PM »
Jerry has a good point about the earlier ignition switch.  I've NEVER EVER used the parking light function on my K7, and if you wouldn't miss it if you were used to a K0-K7.  The bracket fitted on K-7-K6 bikes is an extremely simple loop with a hole for the switch, or you can weld on something similar.
Offline Rinchnut
  • passion 4 2wheelz
  • polishin pavement
« Reply #13 on: January 09, 2014, 08:34:10 AM »
The bike was layed down at some point. Theres some very minor bending on the right side corner of the heads. The valve cover head is missing two bolts and the holes r filled in with some blsck resin stuff.  The valve covers have what could be sealant under them all which is pretty concerning. Got a very slow oil leak under the head gasket. Between the silver and black underneath.  I do not like the silver persay... but I cannot afford what I need to tear her apart and rebuild correctly. Its running good for now after I took down those carbs and rebuilt them.
Im not too sure what will happen whenst I open said engine...
 But Im pretty sure... itll be interesting. And we'll all see it happen here first hand when the day comes.   I bought the bike to use for commute so I can get a job.  With money will come parts and ill rebuild it [the engine].
'74 cb750K
72' cb750 k mono
'80,81,83 cb750C
'82 cb750 dohc ss
ts185
06 s40
06 c50
Offline calj737
  • I refuse...
« Reply #14 on: January 09, 2014, 02:46:50 PM »
Sounds like sheared bolts filled with JB Weld. Good luck getting that cover apart... Have a drill handy and LOTS of aspirin. Not that removing the cover will be too difficult, but what you find beneath the cover will undoubtedly be a minefield of rigged, botched, and butchered fixes equal to Spearmint gum and bailing wire.
Best hope that bike runs really well until you can afford a lot of repairs... Or a spare engine that runs while you properly rebuild the one in the frame currently.
Offline Rinchnut
  • passion 4 2wheelz
  • polishin pavement
« Reply #15 on: January 10, 2014, 08:19:56 AM »
RL=http://s1309.photobucket.com/user/jaydnland/media/Mobile%20Uploads/20140109_125226_zps7994a35a.jpg.html][/URL]
Couldnt find the keys to my k4 switch so I shaved the stock key switch down.
Bolts onto the switch mount I welded on. A little paint... and a wire extension.
'74 cb750K
72' cb750 k mono
'80,81,83 cb750C
'82 cb750 dohc ss
ts185
06 s40
06 c50
« Reply #16 on: January 10, 2014, 02:27:08 PM »
Nice fix.
Offline Rinchnut
  • passion 4 2wheelz
  • polishin pavement
« Reply #17 on: January 10, 2014, 03:16:06 PM »
thanks !
Heres a seat level shot of the right side tank up.  Custom mount to side
mount tach. I love it when I ride. Idk y.  To each his own.
'74 cb750K
72' cb750 k mono
'80,81,83 cb750C
'82 cb750 dohc ss
ts185
06 s40
06 c50
Offline Rinchnut
  • passion 4 2wheelz
  • polishin pavement
« Reply #18 on: January 10, 2014, 03:22:48 PM »
This is the switch panel I made. Will work till I clean out under thenseat and relocate all electronics
'74 cb750K
72' cb750 k mono
'80,81,83 cb750C
'82 cb750 dohc ss
ts185
06 s40
06 c50
« Reply #19 on: January 10, 2014, 06:04:07 PM »
You're on a roll. Some nice ideas. And I like THAT switch better then the light switch  :)
Offline Rinchnut
  • passion 4 2wheelz
  • polishin pavement
« Reply #20 on: January 11, 2014, 08:00:28 AM »
Yes im glad it worked out so far.
Does anyone know where to sell my kerker style can? Baffled 21" never used before.
need to sell it asap.  It looks just like a kerker but no print or engraving of any kind. Hmmm.
'74 cb750K
72' cb750 k mono
'80,81,83 cb750C
'82 cb750 dohc ss
ts185
06 s40
06 c50
« Reply #21 on: January 11, 2014, 08:26:52 AM »
Post up some pics and price. That bad boy oughta go pretty easily.
Offline Rinchnut
  • passion 4 2wheelz
  • polishin pavement
« Reply #22 on: January 11, 2014, 08:48:56 AM »
FOR SALE  heres the exhaust muffler. This bad boys never seen smoke yet.
chrome is flawless. Kept in my bedroom.  Before that it sat in some dudes garage I  bought my donor from
. Looks like a brandless. No markings or numbers. But its built well :)
SOMEONE BUY THIS i dont even have space in the garage anymore.
I do have pix of the insides too :)
'74 cb750K
72' cb750 k mono
'80,81,83 cb750C
'82 cb750 dohc ss
ts185
06 s40
06 c50
Offline Rinchnut
  • passion 4 2wheelz
  • polishin pavement
« Reply #23 on: January 11, 2014, 08:51:56 AM »
I honestly cant find this thing anywhere to appraise it. But ive seen very similar go brand new for 70 bucks or so. Any body seen this nameless/markless can before?
21" long. 2 /12" OD on header end. 4" OD on can end. Im open to offers!!
 Send me a PM if you want it! I got a shorty im keepin on mine
'74 cb750K
72' cb750 k mono
'80,81,83 cb750C
'82 cb750 dohc ss
ts185
06 s40
06 c50
