Author Topic: Leaking Tachometer seal  (Read 3885 times)
Markcb750
« on: January 07, 2014, 06:10:24 PM »
If the seal around the Tachometer leaks, try packing the cavity with wheel bearing grease prior to connecting the cable.  Some will ooze from the capture screw if it is fully packed.
Repack when the oil is changed.
Works better than replacing the seal.
