Author Topic: Need BIMOTA tank and CB750 frame info  (Read 766 times)
Offline HB-1fan
« on: January 08, 2014, 08:42:40 PM »
Does anyone out there have a Bimota HB1 style tank that can make me a pattern of the bottom. Also, has anyone blueprinted the engine mount dimensions(as many views as possible) of the 750.
 Just collecting for the inevitable!
Thnx in advance,
HB
« Last Edit: January 09, 2014, 06:52:09 PM by HB-1fan »
"If you always expect the worst, you can never be dissappointed, only surprised"
Offline calj737
  • I refuse...
Re: Need tank and frame info
« Reply #1 on: January 09, 2014, 04:27:06 AM »
I think 754 has made some need 750 mounts, using a heavier than stock platform. PM him and he'll likely have your dims or drawings available.
Good luck on that Bimota find!
Offline HB-1fan
« Reply #2 on: January 09, 2014, 06:47:10 PM »
I was hoping someone out there had bought an airtech fiberglass tank . I want a template from the bottom, so I can make an aluminum one. Plus, it gives me some of the frame shape.
 Then the engine dimensions - mounting hole to mounting hole. As 3D as possible!
HB
Re: Need BIMOTA tank and CB750 frame info
« Reply #3 on: January 09, 2014, 11:12:27 PM »
There's a frame drawing in the Honda manual at the top of this page.
