Author Topic: Lift recommendations for CB500 Four maintenance  (Read 2381 times)
Offline HS
« on: January 09, 2014, 07:36:16 AM »
Finally got my paws on my 1972 CB500...she's a beaut!  Been sitting a bit long, though, and requires a fair bit of work to be made road worthy.  I've been looking at lifts, but obviously the four pipes are an issue.  Would appreciate recommendations on a good lift that would work with the bike.
Thanks in advance.
HS
Re: Lift recommendations for CB500 Four maintenance
« Reply #1 on: January 09, 2014, 07:59:56 AM »
Do you still have a center stand?  A lift table is very handy like this cheapie Harbor Freight. They also sell a cheap jack style also.  If you do not have a coupon they will honor just the code numbers under the barcode, at least around here.
« Last Edit: January 09, 2014, 08:03:21 AM by ekpent »
scrapvalue
« Reply #2 on: January 09, 2014, 08:12:54 AM »
I bought one of those lift tables and love it.   Well worth the money.
Offline HS
« Reply #3 on: January 09, 2014, 09:16:01 AM »
Thank you, ekpent...I'm a big HF fan.  You get what you pay for, but it's still a great option when you're not a professional wrench.
Yes, I've got a centerstand.  Looks to be pretty solid still.
I've seen the tables and I like them but I'm space limited.  My house was built in 1960 (old by Houston standards) and my garage is small.  That might be my best option, just not sure where I'm going to put the thing.  The center lift was my preferred route but then I pulled my head out of my arse and realized I'll have four pipes in the way...I'm new to the CB.
calj - I'm going to search the Pit Bull now....thanks for that.
Keep 'em coming, gents....much appreciated!  This place is a great source of info.  Hopefully I can contribute some once I get my head around the bike.
HS
scrapvalue
« Reply #4 on: January 10, 2014, 04:59:11 AM »
There is no need to "store" the lift table.  You can just park the bike on it.     I have several bikes in my garage and always have one parked on it.
It sets really close to the ground and comes with a nice removable ramp. Take s no effort to put the bike on it.
And as far as getting what you pay for, the only thing you will get for more money is a power lift.
I've had mine for 2 years and brother has one he bought used almost 5 years ago and it is in use pretty much everyday.
They are well made and a heck of a deal if you use the coupon.
« Reply #5 on: January 10, 2014, 05:59:36 AM »
Depending on what kind of vehicle you own and actually use a garage for vehicle parking (not here for a long time  :D ), if there is enough clearance you can drive over it and park with most of it tucked underneath.
Offline Vicman
« Reply #6 on: January 10, 2014, 06:06:20 AM »
The only thing I never liked about bikes was working on them. I got the HF lift and it is a game changer! Now I enjoy working on them almost as much as riding.
I promise the first time you change your oil or clean carby bowls you will call your buddy and ask him to bring his bike over just so you can do it again. It is that much difference.
That thing will be the best $300 you will ever put in your shop.
Fluent in three languages, English, sarcasm, and profanity.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=7fhlpb48efiqarj944fv74soj2&/topic,60973.0.html
« Reply #7 on: January 10, 2014, 06:19:41 AM »
lift table can be used for all types of work..mine have not mounts to hold the bike..but on center stand..and strap it down  front/back ....hveels can be taken of..
i have build a hydraulic power station of a wood breaker?? English word?? to power the table
« Last Edit: January 10, 2014, 11:19:09 AM by strynboen »
i hate all this v-w.... vords
Offline HS
« Reply #8 on: January 10, 2014, 07:12:22 AM »
You guys have convinced me...I need one of these!  Thanks for the education.
We have four bicycles in the way and I started the install on a mounting system to get them off the ground/against the wall and make room for the CB500.  I can place the lift in the cleared area and park the CB on it...great plan.
Now I just need to get the lawnmore into the shed...time to build a small ramp.
Thanks fellas!
 8)
HS
« Reply #9 on: January 10, 2014, 07:55:52 AM »
That does look like a very nice machine you have there. How about a few more pictures and details like how many miles it has, how you found it, have you had others and all those other juicy details.
In case no one said welcome to the forum,  Welcome to the forum.
Offline HS
« Reply #10 on: January 10, 2014, 01:19:21 PM »
Thanks, ekpent.  I've been racing and braking a dodge challenger stick car for a several years now.  Decided to mix it up with a bike.  Been a looooooong time since I had one.
The bike is a 1972 CB500 Four.  It's got ~6800 miles.  I literally got my hands on it this week....purchased from a gent in MI.  Lots to be done to get the bike in good working order.  Front caliper is bound, as an example, so that will be my first order of business.  I'll then turn my attention to cleaning out the fuel system, check out compression, swap plugs and check out the points, clean the air filter and then go from there.  She's in great shape given 41 years old, but needs some TLC.  I'll be learning as I go.
HS
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #11 on: January 10, 2014, 02:14:02 PM »
What he said. The lift is the best money you can spend on tools.
I have a motorcycle problem.
Offline rtbmrgl
  • Got Points! Roseville, Ca
« Reply #12 on: January 10, 2014, 02:30:04 PM »
I have a lift like this one, the ride rails come in handy for quads or other wide things.  Lifted my Goldwing ok. Be sure when you roll the bike of the ramp that the side stand is up, almost lost my Vstrom. The stand hit high center when rear wheel was off the ramp.
http://www.ebay.com/itm/Tuxedo-M-1000C-1000-lb-Air-Operated-Motorcycle-Lift-/171057953378?pt=Motors_Automotive_Tools&hash=item27d3d93a62&vxp=mtr
thanks, Mark
Roseville, Ca
Got Points!
1973 CB500 back yard find 1243 orig mi,  http://forums.sohc4.net/index.php?topic=124285.0
1976 CB750 Restoring,        http://forums.sohc4.net/index.php?topic=132997
scrapvalue
« Reply #13 on: January 10, 2014, 02:41:03 PM »
+2 for the side stand issue. I know from experience.
Offline rtbmrgl
« Reply #14 on: January 10, 2014, 02:45:10 PM »
I take it back, it was my CB500 that just restored that I almost lost, the gas tank was heading straight for my vice!!!!
That would have popped my bubble.
thanks, Mark
Roseville, Ca
Got Points!
Offline HS
« Reply #15 on: January 10, 2014, 03:04:45 PM »
Yikes....good to know!  The tank is in pretty good shape on mine and that would be a heartbreaker.
 :o
HS
Offline rtbmrgl
« Reply #16 on: January 10, 2014, 03:27:13 PM »
 :o
HS
Yeah, looking at your icon pic it looks nice.  I had a body shop tank paint to look original, it was pricey.
thanks, Mark
Roseville, Ca
Got Points!
Offline HS
« Reply #17 on: January 11, 2014, 07:02:47 PM »
WINNING!!!
....and thanks for the coupon, ekpent!
 8)
HS
Offline HS
« Reply #18 on: January 11, 2014, 10:39:38 PM »
All set up.  I purchased a proper wheel chock at HF as well as the one that came with the lift doesn't look sturdy.  Drilled holes where they needed to be and mounted it.  Cocktail hour...
 ;D
HS
« Last Edit: January 11, 2014, 10:43:02 PM by HS »
Offline faux fiddy
  • bike in a box
« Reply #19 on: January 11, 2014, 11:52:00 PM »
Looks like you're set up, but none the less I'm going to add a shameless plug for Lance's product.
SPEED TV Features PegLift on Greg's Garage.wmv
« Last Edit: January 12, 2014, 12:33:12 AM by faux fiddy »
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
« Reply #20 on: January 12, 2014, 06:47:40 AM »
I bought the same wheel chock as you when I picked mine up, pretty common upgrade for this set up.  One other thing I noticed when I was reading up on them, and the Guy at the store suggested it also was to check and or fill the hydraulic oil in the pump.  Some have been know to ship out not totally filled up  ;)   Enjoy your new toy, your back may Thank-you someday.
  What kind of cocktail did you celebrate with ??
« Last Edit: January 12, 2014, 06:49:35 AM by ekpent »
Offline HS
« Reply #21 on: January 12, 2014, 08:10:39 AM »
ekpent - spot on.  The hydraulic fluid reservoir was not full and I'll purchase some proper fluid today.
Rum, sir....I'm a rum drinker.  Sippin' tequila Friday nights only to blow off some steam from the week.  Otherwise, Gosslings is my daily  ;D
Tree Fiddy - nice looking product.  I could definitely see that coming in handy.  I didn't get a warm fuzzy from the Pit Bull folks on product fitment (i.e. which one of theirs would work on my bike).  Clearly Lance's is flexible.  How much does he sell those for?
HS
scrapvalue
« Reply #22 on: January 12, 2014, 08:29:29 AM »
I built this other work table for my project bikes.   I but the bike on the lift, raise it up to the same level as the table and then roll it on.
The table has a large storage area under it for all the parts for the project and it is on casters so it can be easily moved out of the way when not being used.
It was about $40 in material, not including the casters.
Offline HS
« Reply #23 on: January 12, 2014, 09:10:30 AM »
That looks slick.  I can't open up the picture to make it bigger so I can't see it well...but great idea.
HS
« Reply #24 on: January 12, 2014, 09:21:34 AM »
Hey Scrap I notice in your bench picture a large quantity of trophies up on a shelf. Somebody must be good at something ??
