Author Topic: Just toasted my 350T engine  (Read 5016 times)
Re: Just toasted my 350T engine
« Reply #25 on: January 12, 2014, 07:18:18 AM »
You ran it with no oil.....now face the music! It'll be all blued & scored everywhere.
EDIT...sorry man that was harsh.
« Last Edit: January 12, 2014, 07:38:29 AM by bwaller »
Offline Carver
« Reply #26 on: January 12, 2014, 11:31:46 AM »
any update on the carnage/lack thereof?
Cb 750 k3
Cb 450 dohc k4
Offline Roach Carver
« Reply #27 on: January 12, 2014, 01:52:12 PM »
the older I get the more I say the first thing that pops into my head. Usually truthful though.
Offline zeech
« Reply #28 on: January 12, 2014, 01:54:02 PM »
I see you both fall into the "point and laugh" category haha. Pistons seem okay, cams are locked up but not discolored.
Problem is I can't even disassemble it because I can't rotate the crank to get the 2 bolts out of the cam sprocket so it's all stuck together right now. Do I need to cut the cam chain? I don't see any other way.
« Reply #29 on: January 12, 2014, 01:57:00 PM »
I am no expert but that seems logical to me. And yes I am a point and laugh guy but I expect it when I screw up and have been on your end plenty of times. Good luck. Keep us posted.
« Reply #30 on: January 12, 2014, 02:25:34 PM »
If you can knock the cam end bearings out..puller might work.. , it may drop enough to get chain off sprocket.
 Not sure how stuck the cam is, and have not been inside s 350 twin for decades..
Offline KrautKoffin
« Reply #31 on: January 12, 2014, 02:34:22 PM »
My motto is 'always break the cheapest part if you have to break something'. Cam chain seems logical.
74 cb550
I now have Beastie Boys "Sabotage" stuck in my head after seeing your avatar.
Offline calj737
  • I refuse...
« Reply #32 on: January 12, 2014, 05:37:24 PM »
If the motor won't rotate, you'll probably have to cut the cam chain. Prevent it from falling in if possible. I had to do the same on my current motor (seized since 87). Only way I could get the head off, then jugs.
Sorry it's worked out that way for you.
Offline crazypj
  • I'm brill, me
« Reply #33 on: January 12, 2014, 09:17:19 PM »
If you can get the cam bearing off the points side you may be able to remove the tach side easier. Points side is furthest from pump so generally seizes first.
« Reply #34 on: January 12, 2014, 11:06:59 PM »
Once the end caps/bearings have picked up they are toast , usualy along with the cam.  If with all the screws removed there is no movement at all you will need another cam and both end bearings, I would source those first before going farther
