Author Topic: Float valve test.  (Read 480 times)
Offline Vinhead1957
Float valve test.
« on: January 09, 2014, 07:09:27 PM »
I have read some on the mikuni carbs and wonder if testing float valves could apply to these honda quad system. Little cold out right now but I plan to pump 5 psi into the fuel delivery hose and see how long it holds the pressure. It should indicate how well they hold as well as leakage in the tee between the carbs. Any opinions on the subject?
