SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
High Performance and Racing Forum
(Moderators:
Sam Green Racing
mlinder
Topic:
brake caliper pistons
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: brake caliper pistons (Read 1453 times)
Dion
Full Member
on:
January 10, 2014, 10:27:55 AM »
I need new brake caliper pistons for the 750 sohc k2. I have some 6082 t6 and 6062 t6 aluminum stock on hand. I was wondering if I could use one of these to machine new pistons? Has anyone done this? If so, which would be the better material to use? What do u chaps think?
Logged
RAFster122s
I feel like a really really
Really Old Timer ...
SOHC4 member # 2605
Re: brake caliper pistons
Reply #1 on:
January 10, 2014, 10:41:44 AM »
Seen pistons out of stainless, chromed steel, and phenolic but haven't seen them out of aluminum.
As long as the expansion rate of the t6 is similar to the 3031? of the caliper body it should work. Is the T6 hard to machine easily?
Logged
Jim F
Need a bigger house for more toys
Master
go baby go
Reply #2 on:
January 10, 2014, 12:09:30 PM »
I think if you were to make the pistons out of the same material that the bodies are made out of then
you would have to have them plated to prevent the surfaces from galling up.
just my 2 cents worth
Jim
Logged
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
bwaller
Reply #3 on:
January 10, 2014, 02:45:45 PM »
Jim's right, i've replaced some of my Brembo pistons and they seem to be anodized aluminum.
Logged
Bill/BentON Racing
Ex Honda Service Manager, Cert. Honda Tech - Racer
Reply #4 on:
January 10, 2014, 02:53:44 PM »
+1!!Have to modify one surface for sure, Bill
Logged
BentON Racing Website
BentON Racing Facebook
Dion
Full Member
Reply #5 on:
January 11, 2014, 09:15:24 AM »
This is a bit of info about 6082.......
Alloy 6082 is a medium strength alloy with excellent corrosion resistance. Alloy 6082 has the highest strength of the 6000 series alloy. Due to the higher strength of Alloy 6082 it has replaced Alloy 6061 in many applications. Alloy 6082 is typically used in highly stressed applications. If is an aircraft grade material and is also used in marine applications.......
Logged
Jim F
Master
go baby go
Reply #6 on:
January 11, 2014, 09:29:16 AM »
I would at-least have them anodized or plated with hard chrome
There are some surface treatments for lubrication that also would work.
In some applications when I use to build plastic injection molding we would sent out
inserts or slides and have these coated with a lubricity type coating that would help with wear
again my 2 cents worth
Logged
turboguzzi
Old Timer
Reply #7 on:
January 11, 2014, 11:20:37 PM »
brembos have anodized pistons indeed, hence doable. more than anything you need surface hardness here and 60XX alloy is welding grade, certainly not the hardest out there, that would 70XX
Logged
Terry in Australia
So, what do ya wanna talk about today?
Reply #8 on:
January 12, 2014, 12:18:48 AM »
I've got alloy pistons in my CB750 dual disc setup. I bought them on eBay a few years ago from an ex-pat Brit racer who now lives in Spain. I bought 6 of them, they're 6061 T6 that have been hard anodized. They work fine. Cheers, Terry.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
(Moderators:
Sam Green Racing
mlinder
Topic:
