Author Topic: help with brake banjo bolt  (Read 835 times)
Offline b5rider
« on: January 11, 2014, 04:59:20 PM »
need help fitting my new steel braided lines. (they are not flexible) they were made with the bottom fitting offset. Is there anything I can use to make this fit?
thanks
1984 Honda Elite 150
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
1978 CB550 now 603cc w/sidecar
The key to life is to make sure the line to put flowers on your grave is longer than the one to piss on it.
Re: help with brake banjo bolt
« Reply #1 on: January 11, 2014, 05:05:53 PM »
I dont think there is a way. I had my stainless hoses indexed to fit properly when I ordered them.
You could have a block made to fit in between but nothing off the shelf.
« Reply #2 on: January 11, 2014, 05:48:34 PM »
A set I bought came with a plastic block that fits over the fitting in a vise and a pin to turn it.
Offline b5rider
« Reply #3 on: January 11, 2014, 07:05:53 PM »
I did find this adapter. What size/pitch threads are on the bike
http://www.centrallubrication.com/images/produkte/en-GB/adapter%2090%20degree.jpg
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #4 on: January 12, 2014, 01:05:51 AM »
Is there enough length in it to take it back and have a new end crimped in the right orientation?
Also, if you ordered them by bike model they have been made wrong and the supplier should replace them FOC.
Build threads:
1977 CB750 F2
1958 Norton Model 99
« Reply #5 on: January 12, 2014, 04:29:12 AM »
Offline b5rider
« Reply #6 on: January 12, 2014, 07:52:18 AM »
thanks guys.
Oldskoolnuts,
I ordered the correct lines but failed to mention I have an aftermarket master cylinder, which places the upper fitting in a different position. If I can't find a simple solution, I'll have him make me another upper line.
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
Offline xsmooth69x
« Reply #7 on: January 13, 2014, 08:02:44 AM »
this thing would work that B5 posted. why not use this thing?
1975 CB550 (FINISHED?!?!?)
