Author Topic: cb750 Rear shocks for dummies?  (Read 2632 times)
Offline Rinchnut
  • passion 4 2wheelz
  • polishin pavement
« on: January 12, 2014, 10:00:19 AM »
So this is humbling lol.
Has any shock savvy dudes here posted a nice how-to for servicing rear suspension??
Two specific questions :
1. How do I adjust the preload knotches at the bottom?
2. Can I shorten to 1" or remove the spring cover??
Id like to remove it.
__________________________
'77 cb750f supersport
'74 cb750K
72' cb750 k mono
'80,81,83 cb750C
'82 cb750 dohc ss
ts185
06 s40
06 c50
Offline edwardmorris
  • Youngish
Re: cb750 Rear shocks for dummies?
« Reply #1 on: January 12, 2014, 10:34:26 AM »
Have you looked in the Tips and Tricks section?
http://forums.sohc4.net/index.php?topic=112903.0
Offline Johnie
« Reply #2 on: January 12, 2014, 11:16:25 AM »
1.) There is a spanner tool in your tool kit to adjust the load.
2.) You can shorten the shock with a add on aftermarket part.
3.) You can remove the spring cover, but takes either a spring compression tool or I do it with 2 people. You need to compress it and remove the 2 inserts on the top of that spring cover.
Good luck with your project.
« Last Edit: January 12, 2014, 11:19:08 AM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Rinchnut
  • passion 4 2wheelz
  • polishin pavement
« Reply #3 on: January 12, 2014, 03:08:06 PM »
Awesome thanks.
my bike did not Come with a tool kit. Do i just turn the knotch preload adjuster with something?
'74 cb750K
72' cb750 k mono
'80,81,83 cb750C
'82 cb750 dohc ss
ts185
06 s40
06 c50
Offline Johnie
« Reply #4 on: January 12, 2014, 03:47:18 PM »
Yes, something with a hook on it works good.
Oshkosh, WI  USA
Offline Rinchnut
  • passion 4 2wheelz
  • polishin pavement
« Reply #5 on: January 13, 2014, 04:32:07 AM »
Ok. So no one really answered my spring cover question... can I remove, or shorten thenspring ccer can?? I would enjoy seeing more spring action.
'74 cb750K
72' cb750 k mono
'80,81,83 cb750C
'82 cb750 dohc ss
ts185
06 s40
06 c50
« Reply #6 on: January 13, 2014, 04:45:03 AM »
From what I remember, you should be able to at least shorten the spring cover.  The top of the cover holds the two retainer halves in place, you need that.
« Reply #7 on: January 13, 2014, 05:28:11 AM »
I have ran them without the cover on a pre 1976 750 so yes they can be removed. You can also use a pair of channel locks and a piece of scrap rubber inner tube or such to prevent gouging to turn the bottom adjustment.
Offline Rinchnut
  • passion 4 2wheelz
  • polishin pavement
« Reply #8 on: January 13, 2014, 06:00:56 AM »
Awesome. Anyone need a 21" upswept Mac can?
'74 cb750K
72' cb750 k mono
'80,81,83 cb750C
'82 cb750 dohc ss
ts185
06 s40
06 c50
