Author Topic: Front Wheel and Forks off a CB250N or T and rear wheels, do they fit the CB400F?  (Read 499 times)
Offline Peter K
Gentlemen and Ladies,
I'm sure that I have read somewhere that it is a straightforward swap for the front and rear wheels and the forks from a CB 250 or 400 T or N (late seventies, early eighties) to a 1978 CB400F2. Does anyone know if this is true? Obviously if you do a straight change from one of the 400's you need to change the forks at the same time because of the dual discs. I'm not looking at this as being a permanent change so would only consider doing it if it is relatively straightforward.
Any comments would be most welcome.
"you don't know what you don't know, but someone else probably does"
Offline Tim2005
Nope, it isn't a straightforward swap. Rear end- you just need to modify spacers, add the 250n/400n brake plate & find a 400f-size sprocket (tricky). Front end - you need N forks, yokes, caliper(s) brake hoses, disc(s), speedo drive, mudguard, spindle. And you end up with a 400F with too soft forks and a 19" wheel. And a speedo that doesn't read correctly. As you can tell, I'm not a fan of this....
If you can get an 18" CM400 wheel, an CB250RS speedo drive, uprate the fork springs, fit last model CB400N-C yokes, make up clock mounts, change the master cylinder, add a CM250 mudguard, get reverse (black) comstars and play with the oil, you do end up with a 400f with twin discs & tubeless tyres,  but it's not exactly worth the effort in my experience.   An interesting learning experience though!
Offline Peter K
Thanks for your advice, its much appreciated. You have obviously looked into this in some detail or have done it yourself. Invaluable experience, thanks again.
