I don't think I can take a pic that small. These float needles are pretty new, and it started leaking after it sat for a few weeks. I screwed up and tried to clean it out with the wrong object, and now it leaks worse. I got a new needle today and tried it, it didn't help. I adjusted the float all the way up, and that didn't help. I wouldn't have #$%*ed around with the seat, except I thought I could replace them if need be. Not the case. I does close the flow if you hold it up with finger pressure , but not by using the float.
