Author Topic: cannot get my front brake from squeeling like a stuck pig!!!!!!  (Read 3064 times)
Offline Short Round
« on: September 05, 2006, 11:06:37 AM »
My front brake keeps squeeling like a stuck pig on my CB550.  I have adjusted and adjusted it and nothingb is working.  Any tips would be great.
1974 CB550
Offline Blind Bob
Re: cannot get my front brake from squeeling like a stuck pig!!!!!!
« Reply #1 on: September 05, 2006, 11:27:52 AM »
Lots of answers on the forum for this, pays the money etc. Hacksaw a groove  down the radial line of the pads , coat the back of the pucks with copper grease, use EBC pads, grit sand the existing pads. All work to some degree. Keep the puck and the pivots well lubricated with silicone grease and she will stop but never as good as a modern six pot caliper bike. Consider a dual disc conversion which will improve matters somewhat.
Me I've doe all the above and she she still squeals but the thing stops. Fellas in tin boxes hear me comiing so I guess thats a plus.
Ride safe
Blind Bob
78 CB550/4 F2
Manchester UK
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #2 on: September 05, 2006, 11:42:02 AM »
My brakes squeal like a pig as well.
I got EBC pads - still squeaked.
Cut a X into each pad - still squeaked.
Lubed everything as I was told - still squeaked.
Someone said the dual -discs dont squeak as bad - Squeak's now twice as bad
I have learned to live with it, as everything I have tried/done hasn't worked.
The thing stops - that's all that matters to me...
johnny-from-bel
« Reply #3 on: September 05, 2006, 11:51:18 AM »
You are fighting a lost battle. I have been trying to stop mine from squeeling for 10 years now. Tried everything no result.
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
« Reply #4 on: September 05, 2006, 12:04:26 PM »
Mine squealed like a banshee, I pull the pucks, they already had the saw cuts, and put brake grease behind it.  It still squeaks if just lightly touched but not bad.  I can go down a hill and not sound like a freight coming into town :P
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
johnny-from-bel
« Reply #5 on: September 05, 2006, 12:11:10 PM »
James
I use copper grease. It has greately reduced the squeel but it is still there.
Offline number13
  • 1973 CB500, 2002 VT750DC
    • Sound Exchange
« Reply #6 on: September 05, 2006, 12:15:41 PM »
Try removing, dissasembling  and greasing the
caliper hanger. It must pivot freely, if not you will
get constant rubbing and squeaking.
Bikes parked out front mean good chicken-fried steak inside.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #7 on: September 05, 2006, 12:47:36 PM »
Mine squeaks too.
Not in the rain though ;D
Offline JohnK6
  • I'm NOT Crazy, says the crazy man
« Reply #8 on: September 05, 2006, 12:56:31 PM »
don't forget to check the pin-calliperholder (the one with 2 small o-rings) if it has to much room,  the breaks will squek, every little thing will help it  >:( to squek more
owner of: cb750k6(76), cb750k7(78), cb750K7(79)(sold), zwolle, netherlands
Offline ProTeal55
  • Est1968.com
« Reply #9 on: September 05, 2006, 12:57:12 PM »
Mine squeaks too.
Thats the first thing I noticed while I was riding in the rain was the lack of brake squeak.
It was nice  ;D
Offline petersan
« Reply #10 on: September 05, 2006, 01:21:21 PM »
Mine used to squeek bad.
I pulled brake apart - and pulled off pad.  Using a light abrasive (scotch brite - or fine steel wool) I cleaned the outside of the pad; around the perimeter - and the corresponding surface inside the brake - where the pad sits.  Reassembled, and - cut the squeek down almost completely.
I think that light corrosion was keeping the pad from retracting with the caliper piston - and cleaning out the little bit of corrosion encouraged more freely moving brake pad.
Offline ProTeal55
  • Est1968.com
« Reply #11 on: September 05, 2006, 01:32:02 PM »
If before i go for a ride take a scotch-brite pad and go over both rotors, the first few stops are as quiet as a new sportbike  ;D
As the stops increase, the squeaks come back >:(
Offline GroovieGhoulie
  • I have to return some videotapes.
« Reply #12 on: September 05, 2006, 01:42:13 PM »
I put a liberal amount of "Disk Brake Quiet" on the back of both pads.  It's a red-orange goop that sets up as a cushion.  Get it at auto-parts stores.
Zero squeal on both my 400F and my 750F.  The 750 especially would have dogs three miles away howling in pain, but now it's quiet.
On the 750 at least, I think the problem was the off-side pad.  The caliper and pad are there with metal-to-metal contact without any kind of buffer.  Perfect recipe for squealing.  Glopped that goo on there and no more squeal.
Hop on a Honda
« Reply #13 on: September 05, 2006, 02:17:26 PM »
Mans inhumanity to man is to have squeeling brakes on a bike.
it has a couple of pluses.
One is that the driver of the vehicle definitely knows your behind him and that IS a plus.
two is to know that the brake pads are actually getting pressure onto the disc (sic)
Now to get rid of the the gahstly noise.
Polish the disc with Autosol a metal polish do not rub it off then drive the bike around the block using the brakes consistently in a  on off situation.
This will help de glaze the disc.
Take the disc off and get it "stoned" or resurfaced
Get a new disc rotor as the thickness of the old one may be passed the thickness minimun requirement.. I have even used a thin rubber backing (1MM) placed behind the master pad.
Also very important is to make sure that the caliper is adjusted  by the small horizontal screw behind the caliper, so as the two pads are gapped evenly on either side of the disc surface. This will ensure that the pads will contact and have even pressure on the disc. This will illiminate the one pad doing all the work and applying all the pressure and making the noise.
Good luck with the ear plugs.
Dave
Offline cben750f0
« Reply #14 on: September 05, 2006, 02:22:36 PM »
there is only one way to fix it..... EAR PLUGS!!!!!.... sorry but its one of those things you will probably have to live with.....
 ;Dpeace
eldar
« Reply #15 on: September 05, 2006, 02:40:48 PM »
I cleaned my pads and rotor, cut the groove into the pad and put a bevel on the edge of the pads. BARELY any squeak, after a while it does come back and I clean again. The pads are not new and I cant even remember what brand they were. I think a lot has to do with adjustment and the bleed on the brakes.
Offline toycollector10
« Reply #16 on: September 05, 2006, 02:57:12 PM »
My new ones squealed like hell. I used to put Brakleen (CRC product) which quietened them down for a while. Then I was going to take my bike for a Warrant of Fitness test so sprayed the stuff on except I grabbed the wrong CRC can and sprayed CRC lubricant all over them ha ha ha...Sh*t I thought I was stuffed. So then I blew a whole lot of Brakleen over them and rode a few miles pulling the brakes off and on hard until I had burnt all the product off. Guess what, no squealing brakes anymore. Might be worth a try dude....
1969  CB 750 K0
1973  CB175
1973  Z1 Kawasaki
« Reply #17 on: September 05, 2006, 05:09:34 PM »
My CB750K4 brakes squealed in May, I put some high temp silicon grease behind each bad and squeaks all but dissappeared. By end of August still relatively squeak free with the odd squeak but nowhere near as bad as before. If you keep replacing the grease every few months should be trouble-free.
cheers
Andy
Offline volz1fsu
« Reply #18 on: September 05, 2006, 05:42:43 PM »
Guess I am lucky ;D, my CB550 brakes have never made a bit or noise.  Is it a problem with all the bikes or just the 750s
johnny-from-bel
« Reply #19 on: September 06, 2006, 05:20:54 AM »
The 750 K series are nutorious sqeelers :) It's a way of knowing that they actualy work.
My F2 is very silent.
