SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
Project Shop
Topic:
crankcase seal replacement
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: crankcase seal replacement (Read 1272 times)
cbx1260cc
Full Member
on:
January 15, 2014, 09:25:45 AM »
New member but lurker for some time-so apologies if this is posted incorrectly.
Help Please with this question / issue.
On my 1975 CB400F the Right side (when seated) crank oil seal is weeping / dripping.
I am wondering if this seal can be replaced withOUT splitting the cases. From what I can ell it is a "press in" fit-unlike the Left side seal which has a definite lip to it.
I'd really like to NOT have to split the cases to do this--so if anyone has previously accomplished this please direct me to a link-if available--or provide some advice / encouragement on tackling this issue.
In advance my sincere thanks for any help / input.
Ricardo
Logged
kmb69
Master
Re: crankcase seal replacement
Reply #1 on:
January 15, 2014, 10:11:33 AM »
Ricardo,
If your are referring to PN 91201-323-005, the crankshaft seal behind the points, you have to split the crankcases to replace it. That seal has a lip because it has to hold oil pressure on the outside main to feed the rod journal.
Keith
Logged
cbx1260cc
Full Member
Reply #2 on:
January 16, 2014, 08:55:13 AM »
Keith,
Thank you for the courtesy of your reply and input.
I am in fact referring to OIL SEAL (30X42X8) 91201-300-003 which is part #7 on the parts locator diagram and on the RIGHT side of the bike when seated.
The part you referenced is OIL SEAL (30X45X8)91201-323-005 which is part #8 and is on the LEFT side of the bike when seated. Parts diagram clearly shows a "lip" but unknown about part #7 which is the one I have the issue with.
Thank you for your time and the courtesy of a reply.
Anyone know if part #7 OIL SEAL (30X42X8) 91201-300-003 can be replaced without separating the cases?
Thank you
Ricardo
Logged
flybox1
My wife thinks I'm a
Really Old Timer ...
Reply #3 on:
January 16, 2014, 09:25:58 AM »
Its got a lip. This is the seal behind the points plate.
This should be posted in the SOHC/4 Bikes pages... jump on over to this thread already going.
http://forums.sohc4.net/index.php?topic=133497.0
Last Edit: January 16, 2014, 09:28:19 AM by flybox1
Logged
'78 750K (F3 engine) PD42b's, Modified airbox w/K&N filter, 40/110 jets, 1 needle shim, IMS@ 1 turn out. Kerker + Cone 18" QuietCore
"This is my CB. There are many like it, but this one is mineā¦"
kmb69
Master
Reply #4 on:
January 16, 2014, 10:06:27 AM »
Ricardo,
Sorry, you are correct. I misstated that. However, on a CB350F and a CB400F, both seals are "lipped" and require splitting the crankcases.
Keith
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
Project Shop
Topic:
