Hi 7fifty4,
Your carb settings are pretty much exactly what i am running, except that i am at 7/8 out on the mixture screw.
Just some random thoughts, as kghost has mentioned, your float levels have to be right, otherwise, nothing else in your carb will work in a calibrated way.
You should be getting some colour out of your plugs with those settings. Are they all coming out white or just one or two that you are checking? I'm wondering if you have air leaks, leaning out the mixture, or fuel starvation.
If your carbs are clean and carb boots are airtight & you are sure your fuel is flowing ok, then you might be suffering from weak spark at that point.
Another important & overlooked point can be old plug caps. Try starting your bike up at night, giving it a rev and seeing if you can see spark leaking at the caps. This happened on mine causing missing, and new caps fixed it.
Check also that your rubber trumpets are sealing on the rear end of your carbs. Mine worked a little loose and made funny pulsing sounds which didn't really affect performance, but made a bit of noise.
Check your spark gap as well, if your running points, set the plugs to the stock gap which is 0.6-0.7mm. With your dwell, err towards greater dwell by setting your points gap to ~0.012" rather than ~0.016". This should see better spark as well. I run an electronic ignition, but did this when i was on points.
Check electrical connections blue/yellow wires for good connectivity and all grounding for your ignition.
Also, don't rule out bad condensers if you haven't changed them.
I have never measured fuel rate, but if your petcock and screen are clean & you are running stock honda fuel lines or equivalent (5.5mm internal diameter??) and they are clean, then your flow should be fine.
When was the last time you cleaned the petcock screen?
