Author Topic: Whaddya think? Plug chop results after rebuild...  (Read 1854 times)
Offline alacrity
  • Ride, Optimize, Repeat
« on: January 19, 2014, 05:58:13 PM »
This was a cb550k with a farked piston
Now it has a new top end with 3mm over pistons kit from cruznimage on ebay in japan.
Cylinder block was decked a couple thou at machine shop so there is a teensy weensy increase in compression.
Carpy's 4-1
emgo cheap as dirt pods.
pd46a carbs fully disassembled and refurb'd.
105 main
42 pilot
stock needle in stock position
2 turns out on the magic screw.
bench synched then manometer synched
I had stock airbox and uni filter on it. It was starving for fuel with the stock 90 mains, and I didn't have any sizes till 105, and it was too rich with those and the stock set up. So that's why the pods. Plus, the airbox now makes a supergreat compartment for tools and a lock etc.
She pulls HARD -- like "Holy Crap Batman" hard, right from the bottom.  I'm loving it.  But unlike previous bikes I've done, on this one I can feel the transition between components in the carbs (from pilot to needle especially).
I am getting some intermittent crackle/gurgle sounds and every few mins one little pfft-pop back through an intake. You know what I mean? I hear it on idle and just off idle. It's rare.
Plug-chop done with Engine hot. In fact, earlier in the day it was running what felt like too hot after 20 mins on the freeway.
So my thought is maybe I am running a bit lean in the midrange... like I need to shim up the needles or (somewhere?) find another profile for this setup? Plugs are almost devoid of tan color.
I will follow this with a link to a video of it running.  :-)
I recently restored and sold a 77 cb750f, and am nearly finished with a (former basket case) cb750k5.  This is a place to share, learn and enjoy.  I am grateful to and for 99+% of this site's membership.
Re: Whaddya think? Plug chop results after rebuild...
« Reply #1 on: January 19, 2014, 06:18:03 PM »
Devoid of tan color. Richen until it runs worse and the plugs get dark\wet\foul then fine tune.
Offline alacrity
Offline alacrity
« Reply #3 on: January 19, 2014, 06:45:32 PM »
Oh yeah, and it has the cb650 cam in it!
Offline goldarrow
  • one day, i'll be an
« Reply #4 on: January 19, 2014, 06:48:44 PM »
Sounds great!
CB550 K0
Offline alacrity
« Reply #5 on: January 19, 2014, 09:08:32 PM »
Thanks goldarrow. I got it done just in time to miss the vvmc ride this morning.  :-(.  Oh well
And jerry rxman- there is some tan on the plugs just not enough of it.  I think I am gonna go out to the garage and try raising the needles a pinch with shim under
« Reply #6 on: January 20, 2014, 04:17:07 AM »
Sounds awesome!   Makes me wanna change the exhaust on my 550.
Offline alacrity
« Reply #7 on: January 21, 2014, 01:33:05 AM »
 ;D.  And that was recoded with the tiny mic on my phone.  I think I will try to do a higher quality recording later this week
Offline lucky
« Reply #8 on: January 22, 2014, 12:14:54 PM »
You just can't run pods with the stock needle setting.
Go one step richer.
Remember that the needle controls 1/4 throttle up to 3/4 throttle,
otherwise almost all of your driving.
Offline alacrity
« Reply #9 on: January 23, 2014, 09:49:16 PM »
yep.
done.
thanks
other probs to chase now... like it never ends.
