Author Topic: Vintage Speed Part Mashup - 1976 CB750F  (Read 84217 times)
Re: Vintage Speed Part Mashup - 1976 CB750F
« Reply #250 on: January 22, 2017, 10:52:12 AM »
Are the cooling fins you deleted on the cover which were designed to increase cooling area really of much worth?  Nice button holders. Are they much of a stretch to reach?
Have you considered hard anodizing the bars or are they steel?  It would make the controls all blend together from any distance with a glance...
Are you going to use some MBlaze signals on her too?
David
Offline slikwilli420
  • Master of Disaster
« Reply #251 on: January 22, 2017, 11:45:46 AM »
David
I would say the fins on the cover provide no detectable level of cooling so I wasn't worried.
The buttons are a bit on the far side but the farthest ones are for turn signals which I don't have any immediate plans to add but wanted the option. The next closest on the three button control is the horn which I will eventually add but in my opinion can do more harm than good on the street.
The bars are vintage aluminum Tommasellis. I have not thought about anodizing rise as well since I want to keep them in an original state. Even going to get a new sticker for the one bar.
For signals I would get something more period looking so the m blaze would be out.
« Reply #252 on: January 22, 2017, 02:26:53 PM »
What about filling with laser weld? It will go back to Jim for the cam tower stabilizers so it might be worth doing then. I wanted to have it vapor blasted but now I'm thinking that the weld material will stick out and the finished product won't be acceptable.
« Reply #253 on: January 22, 2017, 05:01:39 PM »
The air pockets showed after I ground it down. The welds Jim did were great so there was no issue with his work. He really went above and beyond for me. It's not the end of the world to go without vapor blasting on the cover.
« Last Edit: July 11, 2017, 09:45:05 AM by slikwilli420 »
« Reply #254 on: January 23, 2017, 06:00:48 AM »
He is a great guy to work with. In the past he looked at some work for me and wasn't able to weld it due to the material being destroyed previously, and he didn't charge me for his shop time or return shipping, since he wasn't able to provide the service. He really is an asset to our forum.
Offline JoeCooley
  • Long time lurker, but now I'm a
« Reply #255 on: January 23, 2017, 04:21:42 PM »
Just finished reading this build from the beginning. You have some skills and this bike will no doubt be one the coolest I've seen here. I can't wait to see it all finished up. I aspire to someday do a full rebuild on my 78k and will definitely take use of some of your ideas and methods.
Joe in San Diego - Quick Cyles
78 CB750K 836cc Highway Racer - http://forums.sohc4.net/index.php/topic,162264.0.html
Rickman CR750 Restoration (SOLD)
« Reply #256 on: January 23, 2017, 05:12:41 PM »
Feel free to borrow with pride. I have done so on multiple occasions although each piece is slightly modified to reflect my vision for the bike. Happy to hear there was enough good content to keep you here for 12 pages!
« Reply #257 on: February 10, 2017, 06:05:40 PM »
Still making headway on the valve cover which I am pumped about. Got the holes drilled and counter bored and started making the inserts. All but one are done. It will be headed back to Jim for one more round of welding and it should be all wrapped up. Once back I will finish drilling out the holes for m6 screws. I pre-drilled with an 1/8"but just so I have center.
Also just about finished on the stator cover that will be engraved by JLeather just like the ignition cover I had done a while back. To prevent leaks I'm going to use long SS set screws or studs into the field coil sealing the threads. The cover will be held on by nuts.
Lastly just because they are effing cool and super rare I wanted to show these off. One day they will go on a superbike tribute I have in my mind along with some other goodies like Astralite wheels I got from 754.
The brake master is totally NOS and the clutch looks like it was used a VERY short period of time. Both still in original bags/ boxes.
« Last Edit: July 11, 2017, 09:48:49 AM by slikwilli420 »
« Reply #258 on: February 11, 2017, 05:04:21 AM »
Have you been using cutting oil while machining that up? If so, you've just made poor Jim's job that much harder  :(
Only a few drops of oil for the holes. No oil on the outside for machining. Modern extruded aluminum is a lot less porous than old cast so a proper clean on each one should be sufficient.
They were a70s mod designed to keep the cam towers in place on engines with upgraded springs since they were much stiffer than needed vs today's modern springs. At this point is not necessary but looks period.
Forgive my memory, whats the function/purpose of the modifications to the cover?
Offline SF
  • I burn gas very well
« Reply #259 on: February 11, 2017, 09:18:03 AM »
Cool build with all the period performance race parts and mods. Ive been collecting for quite some time and it can be real bummer with all these nice parts in boxes waiting till the day
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
« Reply #260 on: February 11, 2017, 09:30:27 AM »
I totally agree. This one has been a real exercise in patience since almost nothing is off the shelf new and has taken years of hunting to obtain.
