Author Topic: Vintage Speed Part Mashup - 1976 CB750F  (Read 66907 times)
Offline calj737
  • I refuse...
Re: Vintage Speed Part Mashup - 1976 CB750F
« Reply #275 on: January 22, 2017, 02:30:31 PM »
If I'm not mistaken, Jim uses a laser welding rig, but the filler material is no different. And the parent material (your cover) won't change. It's been my experience that what you're encountering is par for the course with welding in these old cases/covers. Maybe he knows a different trick...?
Curious though, did you grind down the welded cover after he sent it to you? Is that when the porosity was revealed? I can't imagine he would have allowed it to leave with it showing. Doesn't seem like him by his reputation.
Offline slikwilli420
  • Master of Disaster
« Reply #276 on: January 22, 2017, 05:01:39 PM »
The air pockets showed after I ground it down. The welds Jim did were great so there was no issue with his work. He really went above and beyond for me. It's not the end of the world to go without vapor blasting on the cover.
« Last Edit: July 11, 2017, 09:45:05 AM by slikwilli420 »
Offline calj737
  • I refuse...
« Reply #277 on: January 23, 2017, 04:04:37 AM »
That's what I suspected. You can almost never see the porosity while you're welding, so it doesn't surprise me it got past him either. I don't know the man, but everything I've heard about him and everyone who has dealt with him has nothing but the highest regard for him. I've seen some of his work posted on here, and it surely does live up to his reputation.  :) Plus I hear he's a helluva a great guy too.
« Reply #278 on: January 23, 2017, 06:00:48 AM »
He is a great guy to work with. In the past he looked at some work for me and wasn't able to weld it due to the material being destroyed previously, and he didn't charge me for his shop time or return shipping, since he wasn't able to provide the service. He really is an asset to our forum.
Offline JoeCooley
  • Long time lurker, but now I'm a
« Reply #279 on: January 23, 2017, 04:21:42 PM »
Just finished reading this build from the beginning. You have some skills and this bike will no doubt be one the coolest I've seen here. I can't wait to see it all finished up. I aspire to someday do a full rebuild on my 78k and will definitely take use of some of your ideas and methods.
Joe in San Diego - Quick Cyles
78 CB750K 836cc Highway Racer - http://forums.sohc4.net/index.php/topic,162264.0.html
Rickman CR750 Restoration (SOLD)
« Reply #280 on: January 23, 2017, 05:12:41 PM »
Feel free to borrow with pride. I have done so on multiple occasions although each piece is slightly modified to reflect my vision for the bike. Happy to hear there was enough good content to keep you here for 12 pages!
« Reply #281 on: February 10, 2017, 06:05:40 PM »
Still making headway on the valve cover which I am pumped about. Got the holes drilled and counter bored and started making the inserts. All but one are done. It will be headed back to Jim for one more round of welding and it should be all wrapped up. Once back I will finish drilling out the holes for m6 screws. I pre-drilled with an 1/8"but just so I have center.
Also just about finished on the stator cover that will be engraved by JLeather just like the ignition cover I had done a while back. To prevent leaks I'm going to use long SS set screws or studs into the field coil sealing the threads. The cover will be held on by nuts.
Lastly just because they are effing cool and super rare I wanted to show these off. One day they will go on a superbike tribute I have in my mind along with some other goodies like Astralite wheels I got from 754.
The brake master is totally NOS and the clutch looks like it was used a VERY short period of time. Both still in original bags/ boxes.
« Last Edit: July 11, 2017, 09:48:49 AM by slikwilli420 »
Offline calj737
  • I refuse...
« Reply #282 on: February 11, 2017, 02:33:20 AM »
Have you been using cutting oil while machining that up? If so, you've just made poor Jim's job that much harder  :(
Forgive my memory, whats the function/purpose of the modifications to the cover?
« Reply #283 on: February 11, 2017, 05:04:21 AM »
Only a few drops of oil for the holes. No oil on the outside for machining. Modern extruded aluminum is a lot less porous than old cast so a proper clean on each one should be sufficient.
They were a70s mod designed to keep the cam towers in place on engines with upgraded springs since they were much stiffer than needed vs today's modern springs. At this point is not necessary but looks period.
Offline SF
  • I burn gas very well
« Reply #284 on: February 11, 2017, 09:18:03 AM »
Cool build with all the period performance race parts and mods. Ive been collecting for quite some time and it can be real bummer with all these nice parts in boxes waiting till the day
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
« Reply #285 on: February 11, 2017, 09:30:27 AM »
I totally agree. This one has been a real exercise in patience since almost nothing is off the shelf new and has taken years of hunting to obtain.
